AIM-4G Super Falcon
1:32 Brassin
Contained within the standard blister pack for those items, that aren’t quite so fragile, are a set of four AIM-4G Super Falcons. The body and fins are moulded in one piece, whilst the seeker heads and protective “Noddy” caps.  There is also a small etched brass fret that contains the rear nozzle ring and a pretty comprehensive decal sheet. Although still attached to their moulding blocks, they are only held to the block by thin webs, therefore easily removed and cleaned up with just a swipe or two of a sanding stick.  With etched rocket ring fitted it’s just a matter of painting, adding the supplied decals, and weathering, (The “Noddy” caps should then be painted and fitted to the nose of each missile, covering the seeker head, although this is entirely up to the modeller how they should be used.  The only fly in the ointment is the lack of Remove Before Flight flags for the caps, which is a shame, but they are readily available elsewhere.
Conclusion
It’s a shame that the only kits available that can make use of these lovely missiles are the Combat Models vacforms, even though there are still rumours that a major company will produce one of these aircraft as an injection moulded kit. I guess they can still be useful to some modellers.
Review sample courtesy of
