Christer A
Airfix Sea Vixen, with some aftermarket help
James FYI, Royal Mail or whatever alternative they use down in locked down Salisbury, have the missing links coming to me
:thumbsup2:
Whenever I manage the pilgrimage to Telford, I'll definitvely buy a round or Four.
You guys are awesome!
Edited by Christer A
:thumbsup2:
...just don't lick your fingers after handling the package!
Now when the wingsituation seems to be clearing up (fingers oh so crossed, or as we say in swedish: Jag håller tummarna! (I'm holding my thumbs) it's time to look at the lustrous Vixen.
It seems that I was sanding, filling, sanding same more and scribing lines.
Bah!
Let's shoot some grey UMP on it to see how it looks.
Ok, now some minro sanding and scribing still to do on this side, and also polishing.
A nice smooooth surface is the goal.
And maybe order those Quickboost arials and a metal refueling nozzle.
Time to spend that company bonus!
Its a prime example of what makes BM the outstanding community that it is.
Martian
OK, this afternoon this arrived
A question for Crisp
Is it OK if I separate each section to make the casts?
Another
Do you want any copies too?
Yet againly
Do you need the 'e!evator?' cast too?
I'll get on with this !ater, once the answer is in. 😉
Yes, OK to separate as required.
No copies, thanks; just the originals back in due course.
Over to Christer re the third question - but my understanding is that he just needs the two wing panels.  I sent it because I wanted to keep the sprue together, not for any other reason.
That is fine then Crisp thank you
Separated and preliminary 'stuff' done to enable 'two part' moulding
Three little legs added to the sprues so the wing panel can be sat in a small sea of latex and the moulding can begin
Crisp's nautical eye will surely notice a small stress bend on the inner leading edge corner of the far away item this has been de-bent and levelled
I may have to advise on slightly more rigid packaging to Crisp but maybe I should shaddap until Crisp gets these safely back home
It isn't anything that will show once these are safely nestled in the mainplanes of their aeroplanes  :)
When I was planning this part of the casting I considered doing both halves at the same time but with the setting and pot times of a mix of resin being so short I have decided 'no short cuts' so the equal height criterion has evaporated
Still a picture shows that something has been happening
and maybe why a double fill isnt a good idea
These are close but get no cigar
more tomorrow but as its our offspring's 51st too not a lot will get done whilst we're in Sandiacre for lunch
ciao
I'm waiting with bated breath for the next update!
Regarding the elevator, the picture in Post #104 shows it in the installed position, so I have no need for any extra.
(yet!)
A little update
Crisp's bravely volunteered wing sections adrift in a sea of pale violet
Fear not, the small dots of rust did not come off my creaky old fingers
Honest, they came off a handy old exhaust clamp I needed to use to hold the pieces in place whilst I sorted out some more weights
Paint jars I think
The rusty flakes have now gone fear away, its 'bin day' here today
I have to get new stocks in to make castings, couple of days probably which will give this all the cure time it will need
When this is set I will be spraying the whole thing with a silicone release agent which will be drying ready for part two's mould to be cast.
Well I don't go out much...
Edited by perdu
Paint jars I think
Alclad I'm guessing?
Bated breath is indeed what is happening out here! Keep up the good work Bill!
Terry
Sorry, No Vixen-y update from me today.
"Real life" (Sorry, I should probably say Battletech was released for PC) has had a nasty habit of getting in the way.
Fear not, some modelling activities hae been performed anyway.
We had our annual Speed Modelling competition at the local club, which was the usual fun & games, even though we did only have 6 starting members.
This years kit was this
32222628_10208883749729716_1918375850319
1 Hour an 53 minutes later I had my Admiral Barge done
32260887_10208887137334404_4716716982634
32258094_10208887137854417_2498381462470
I failed to make a good wingfold, and there was no time for weathering, but I did add seatbelts!
I finished at second place, just one point behind the winner...
Sorry for the threaddrift guys
Yes, I've just acquired that to relive my teenage years. Scary how much I recall!
Nice to see you and your build here, Christer! :)
Nice speed build! :)
Håkan
Get thee behind me Satan!
Gondor
Well this has taken me some time, but I think we can go ahead and cast from that mould
Firstly Christer I am sorry this has taken such a long time but waiting for fresh materials is only part of the saga
(Other parts of the excuse are available on my builds of Gannet and Buccaneer, I have been significantly old...)
Anyway yesterday I attempted a trial run of one panel, slow me to present the inner part of the port wing under side
Before I proceed I will have to admit it isn't pretty, a zillion mini air bubbles were unable to get out from under the surface as the latex cured against, sadly the outer skin face
Here though is a view of the upper in the mould, inner section which is not intended to travel across the North Sea
A couple of unattended air bubbles were trapped inside my full panel casting
The next run will have none of these
If I was making this in a hurry I think I could actually use this given some added filler, anyway it seems I 'got' the inner ribs reasonably well
The myriad of bubbles doesn't show very well in these low-res (taken on my tablet) pictures but a wash of Mr Dissolved putty may be all they need to be usable
In all cases the white piece is of course, the resin piece
Anyway, as a test of concept this will do for me
Christer will it work for you?
Update
Just gave the bubbly surface a gentle rub with fine abrasive paper and it polished up nicely
Its going to be "GO, ALL SYSTEMS" I think
Well, it's a lot better than what I can produce, so I'll gladly take it!
Thanks a bunch!
PM with address inbound!
I will get the new panels going today, I shall try to trim them to match Crisp's kit pieces so you don't get too much guesswork
On ‎11‎/‎7‎/‎2017 at 7:37 PM, massimo said:
maybe another Sea Vixen , but this time black nosed with Alley cat conversion for FAW1 ???
You did a great job with those seats!!!
ciao
Massimo
Please Massimo,
Do stop giving me such weird ideas, My head is already well distorted !!😄
Faw 1 Hum and Alley cat conversion ??
May be adapting the alley cat to my Dynavector Vixen….
Aaaaargh too late !
What a great bunch of modellers here !
Very glad for Christer's wing panels, I didnt try these 2 parts mouldings !
Must try it one day !
good job Bill !
Sincerely.
CC
Second shot at these
Abject failure, holes everywhere and a massive lesson learnt
I moulded both halves within a discarded ice cream tub to save on latex
Yesterday I just attempted to mould inside one of the sections
Kinda worked but a little more care needed (it cleaned up nicely when I de-flashed the casting)
Today I thought I'd be cleverer, cast both halves at the same time
Not clever, both half sections ended up too thin by miles
Back into foundry once more chaps, one at a time please.. 😕😠😬😕😠😢😣😥😦😨😩😰
Here's the wreckage, but fear not Christer all will go well
As you see too thin and lots of missing thickness. 😕
Not something I can claim, I get thicker by the hour. :(
IMG_20180522_122341.jpg  This lunar landscape comes from tiny trapped bubbles, luckily it is very shallow and easily smoothed lived without losing the engraved detail
The other piece of trash ready for the bin...
Laters folks
That might take a few swipes of the sanding stick to smooth out...
Maybe a belt sander?
Let's hope that the next batch comes out a little better :smile:
The surface actually looks worse than it is, quite a bit of it comes off with a light abrasive paper
Shall I treat the surface for you before I post it off?
