Shar2 Posted September 11, 2017 Share Posted September 11, 2017 Mitsubishi A6M Zero Detail Sets 1:32 CMK The Hasegawa A6M Zero has been around a long time, from 1978 in fact and that boxing is still available, as well as a couple of more recent new toolings. The six resin sets reviewed here can be used on any of Hasegawas releases, with a greater or lesser amount of preparatory work required by the modeller, depending on the kit used. While some of the sets are drop in replacement with more finesse than can be achieved with plastic, others will require the modeller to take a knife and sanding stick to the kit parts to fit the resin. All the resin parts will need to be removed from their moulding blocks and cleaned up, but this is a pretty simple task, with any cleaning up required only on surfaces that will not be seen once fitted. 5117 – Flaps. This set includes the moving section of the flap as well as the interior roof of the flap bay. To fit requires the kit flap to be cut away on the lower wing and the upper wing section thinned down until the roof section fits snugly. The moulding blocks are on the leading edges of each section and will not take much to part it off and clean up. The time will be taken up with thinning the roof down I’d imagine. But will look great when all is down and the resin fitted. 5118 – Tail Cone. This set requires the modeller to take a saw or knife to the kit and cut off the tail cone, beneath the rudder. In its place are resin parts for the rear bulkhead, tail wheel assembly, with separate shock absorber and wheel, and new tail cone halves. 5119 – Main Undercarriage Bays. These are almost drop in replacements as once the moulding blocks have been removed, and the upper wing plastic reduced in thickness, they are just glued into position. A little more work than using the plastic parts, but the detail is so much nicer. Do be careful when removing the moulding blocks though as some areas of the bay roof are quite thin already. 5120 – Undercarriage Doors. The main gear doors contained in this set are direct replacements for the kit parts, only much thinner and accurate. They include both outer and inner doors, as well as their respective actuators and clamps, but also require a couple of smaller kit parts to be used as well. 5121 – Wing Fuel Tanks. Now, this set is purely for those who want to go that little bit further with detailing their model and allowing diorama possibilities. The set includes two bays, two fuel tanks with some nice detailing, as well as the wing skin covers. You will first of all need to identify and remove the correct areas of the lower wing, which, looking at the kit isn’t that easy, fit the bays from the inside, fit the tanks and place the covers where you want within the diorama. Q32 277 – Wheels. This set is part of CMK Easy Line of resin replacements, and consists of just the two main wheels with a slight bulge tow show the aircraft has a bit of weight to it. Just remove the moulding blocks from the contact point of the wheel, clean up with a couple of swipes from a sanding stick then glue to the axle of the kit main legs. Job jobbed. Conclusion Care and patience will be needed to achieve a good fit will be the order of the day with some of these sets, whilst the others a more plug and play. A great selection of items from CMK, of course you don’t have to use them all, just whatever you feel comfortable with doing or what you want to achieve, so great for all abilities in one way or another. Review sample courtesy of Link to comment Share on other sites More sharing options...
