Sign in to follow this
Mike
Su-25UB/UBK Upgrade Sets (for Smer 1:48)
Su-25UB/UBK Upgrade Sets (for Smer)
1:48 Eduard
Smer's kit isn't new by any stretch of the imagination, the originals having their roots in the 1980s.  Over the years the basic sprues have been updated, adjusted and reboxed in other people's boxes from the initial OEZ through Kopro and even in some Eduard special editions, from where these sets probably began.  Eduard's new range of sets are here to improve on the kit detail in the usual modular manner.  Get what you want for the areas you want to be more of a focal point.  As usual with Eduard's Photo-Etch (PE) and Mask sets, they arrive in a flat resealable package, with a white backing card protecting the contents and the instructions that are sandwiched between.
Interior (49835)
Two frets are included, one nickel plated and pre-painted, the other in bare brass, plus a small piece of clear acetate with a blast screen shaped pre-printed for cut-out.  A complete set of new layered instrument panels in both cockpits and side consoles are the primary parts on the painted set, with sidewall inserts; new rudder pedals; ejection seat details; HUD on the coaming, and canopy internal structure also supplied, which facilitates splitting the twin-opener canopy into individual sections for posing open, with sill inserts and bulkhead details added.
Zoom! Set (FE835)
This set contains a reduced subset of the interior, namely the pre-painted parts that are used to improve on the main aspects of the cockpit, as seen above.  Whatever your motivations for wanting this set, it provides a welcome boost to detail, without being concerned with the structural elements.
Seatbelts STEEL (FE836)
In case you don't already know, these belts are Photo-Etch (PE) steel, and because of their strength they can be etched from thinner material, which improves realism and flexibility in one sitting.  Coupled with the new painting method that adds perceived extra depth to the buckles and other furniture by shading, they are more realistic looking and will drape better than regular brass PE.  As well as the two sets of crew belts, you also get seat cushions; headbox details; leg-restraints, and a set of pull-handles either side of the pilot's knees that gets him out of there in case of an emergency.
Exterior (48926)
This larger bare brass set contains some important upgrades, such as a complete new section of the nose gear bay that is squared off, rather than rounded like the kit part, as well as detail parts for the remaining forward section; fuel tank fillers; a mass of additional and replacement aerials, sensors and panels around the nose, under the chin, and at the rear of the aircraft; an entire set of nose gear bay doors with shaped and folded hinges; chaff and flare details on the tail, plus additional panels there and around the engine exhausts; a new bay doors for the main gear in the engine sponsons, and finally, enhancements to the wingtip pods.
Masks (EX553)
Supplied on a sheet of yellow kabuki tape, these pre-cut masks supply you with a full set of masks for the canopy, with compound curved handled by using frame hugging masks, while the highly curved gaps are in-filled with either liquid mask or offcuts from the background tape.  In addition you get a set of hub/tyre masks for all the wheels (including the out-riggers), allowing you to cut the demarcation perfectly with little effort.
Review sample courtesy of
