Ridgeline
1/144 Eastern Express/MikroMir MD-11 Build Log
A journey of one thousand miles begins with a single step... I began modelling airliners back in 2006, and ever since have wanted to build one of my favorite designs: the MD-11. I have seen the Welsh kit, but didn't want to deal with vacuform. I have seen the authentic airliners kit, but didn't want to deal with resin. I have seen the DC-10 conversions, but didn't want to deal with essentially scratch-building the whole model.
Today, though, today I received this:
uljfMuW4MXUzHMpB7M4T2mFXzo1XjXoU2qixXrDd
You're probably familiar with the kit by now... This is the Eastern Express/MikroMir MD-11 in the "American Airlines" packaging. Feel free to ignore the Atlantis sticker covering the original MikroMir logo. This packaging includes decals and masks for the Varig MD-11 shown on the box art, as well as a TAM and a World Cargo option. I am planning to build the Varig MD-11, though that will depend heavily on the quality of the kit decals.
Anyway, on to the build... The fuselage comes in five main pieces with panel lines and no windows: perfect for my style of airliner modelling!
SoOLh4S-CzYjQ3stOM0pM_JowQAFmjRmKsDzGCns
The parts had a lot of flash and excess plastic along the edges, and the main components were lacking in locating pins. While locating pins almost always fail to properly align fuselage halves, they do help to at least start the process and hold various pieces in place. On the other hand, I have done enough type conversions before to be comfortable with cutting and re-gluing fuselage components. My preferred method involves applying strips of styrene behind the joint for reinforcement and alignment, and it seemed that same process would work well on this build.
tB3r6-NQBzHUCpAniifQLHKeBEw9om4_oNb5hRMx
AACdBeGmBuBItdUHR-J1cMbcStHXWwh51GS8EDDg
1Bf0nTfTVPN1V14mTQ-tWzXm1lLq3xUfzSxyK5XP
TTBFDFz8FHg1AHo8LlHdG1OPZ27qLiiU_Rnrx2xP
T1oo81dzXmd-xnpeAdRAQGspIi4OR8xJpaynQqDA
A feature on this build is the availability of a flight deck... I love flight decks! They always provide a convenient place to mount my weights:
SeanvIwnU2FE1PkX-CbMPMP13Hc2VX6PK0gYQ9ao
At issue next was the nose wheel bay. The kit instructions call for installing the nose wheel strut prior to closing the fuselage... No, thank you. Instead I decided, after studying the drawings, that I MIGHT be able to get away with simply cutting a notch in the wheel bay and installing the struts later. I don't actually know if this is going to work, but it has worked before and I see no reason why it shouldn't work here. I will let you know once I try it, of course.
CrhRzFtDtL3DQwwF2KsPufe4ve0RMfdeHB5uuhdy
CYCLy8Nvnd5ZP0LFH1OiGUDVUcz50W1OlWOQ3yQ2
Also worth noting is that the locating holes for the horizontal stabilizers are covered over... I opened these up prior to closing the fuselage.
TOQKPqjgGPCQZIh_Dvn6saRdt350lR5qq5dScde5
From here, then, a final dry-fit before taking the plunge and closing the fuselage... One can see that the roof already has very good alignment, so I did not expect any particular difficulties.
524jM4iz13S8C-cZxoiBPhS5l1P24CVvCxdi5xNm
Having said that, though, I was not surprised to see this misalignment pop up where four of the fuselage parts meet... There are a number of curves on the fuselage that exert force on this particular area of the model, so extra care will be required to get the pieces properly aligned. In my case, I applied solvent glue and then pushed one side, pulled the other side, and squeezed both sides. The resulting joint was, I think, good enough.
9tBIj7T3nA2EaQY_rzv_DmPVnZYEBDaysrNBGro9
Xe9aC7Sc5gYYRz20aqD0IQdBKTYOD6_Pqj46vcf9
The bottom of that same area, though, is a tragedy! On the other hand, this area of the fuselage tends to present a problem, for me at least, on most of the airliners I build. The solution is a simple matter of applying elbow grease and reshaping these curves... No worries.
vLlmNVQn_ahmfEN5AZDvpUb2OCYhY1CHsHYIMOHx
Also worth noting is that the cockpit glass is every-so-slightly smaller than the opening in the fuselage, and so pressing the clear plastic down into the slot results in a step along the roof line. Instead, I glued the cockpit part in at its front, aligning it with the nose, and then glued the part at its roof line. This process, I believe, properly aligns the piece along the roof but leaves a small gap at its base. Again, no worries. Filling the base will be significantly easier than reshaping the roof line.
7oW_sQYlEUshLjuFFqewW1PRgsWk7JObp6TqdGk1
jofGIawLkZLjiwIv3wEyf7j0tN77msi7zKZeoRe5
And this is where she sits so far! I've heard a lot of moaning and groaning about the quality of this kit, but I am excited to hit it with full-steam. None of the issues I have encountered to this point are particularly unreasonable, in my opinion, and none of the issues that I see coming have concerned me yet. What problems have I not foreseen, though? I guess we'll find out! In the meantime, I have, for the first time in 11 years, an MD-11 fuselage sitting on my table... and we're just getting to the good part! I will work next on the wings and stabilizers, and then will progress to the engines...
Until then, comments are welcomed... Thanks for looking!
7CKdDO5YeWcglgdyobc5Bw7Io9f1RIKLcrOih8lH
Edited by Ridgeline
Wanted request removed
A good positive start with a good positive attitude too - If things don't fit perfectly, try using a bit of modelling skills to make it fit...amazing!!.
I can't offer the Varig decals as mine are both KLM (one from Eastern Express and the other from 26decals). On my first EE sample the rear fuselage is sharper radiused and so fits inside the corresponding tail section but as you shown a little bit of plastic card to reinforce and set the joint works well.
With the clear flight deck cap, could you have shimmed the join with thin plastic card? I had to do similar on Minicraft 737 recently and it gave a very good even all round fit that just required a bit of filler around the joints to finish it off.
Looking forward to your next updates.
Jeff
Excellent start and I look forward to following progress. I have one at about the same stage as yours but I ended up putting it aside because I was totally fed up with it. Jeff would probably say I'm lacking in positive attitude :winkgrin: but I'll get back to it eventually once you show me how to fit the wings :wall:
Dave G
Ha!! No Dave definitely not lacking positive attitude at all and sorry if it came across that way😟. Believe me I've got a whole shelf of models for which my positive outlook and enthusiasm to see them through has all but gone!
In fact after I posted my comment above I remembered from various comments and observations, yours being amongst them, that it's the wing/ fuselage joint that causes problems.
The fact that anyone has started their MD-11 is a huge advantage over me as my stash just seems to multiply but the finished shelf remains the same.
Looking forward to see how ridgeline tackles the wingy bits.
Jeff
Jeff and Dave, thanks for chiming in! A positive attitude is the right way to call it.... Or, perhaps, hope? Like you guys I have a stash of models that have lost hope, too! :worry: I definitely want to finish this one, though. The profile, the curve of the wings, the MD-11 is too sexy for me to let this model fail.
Adding a shim under the cockpit glass would have been a different path to the same solution, I think. The gap was very small, though, so perhaps a .005" thick strip of styrene would've been enough. To be honest it was just quicker to glue two points and fill it in afterwards. I'm not exactly a precision modeller, you know? I kind of just "eyeball" it...
By the way, what's wrong with the fit of the wings...?
GnYQ0pqnr8CZvLci5dNiwogaAtaHCpPG65FbjosN
MlPcGDhuVCUufD4KZfPVZS7eiqSw2gal6TJ8DV0k
PO50rmJ4zS1lbqrAwWm5TE1JPxCtElCNq-h2W_Ic
I'm kidding!! I actually spent a fair bit of time working on the wings and trying to get them to fit flush. Obviously there is some cleanup work left to do, but I am happy now with the fit and dihedral. My solution mostly involved modifying the wing spar component. It seemed to me that the slot for the wing to drop into was too thin for the upper wing piece, so I cut it at an angle to allow the wing to be pressed in. From here it is only a matter of sanding down the wing edge to make it fit properly. The current fit is actually very tight, and there is only a little play in the wings when they are installed. At this point my plan is to build and paint the wings separately and attach them only in the final steps.
1DuZ-jnUDS_TYSojRJDC8sf918_xWeQ0hEYzHkOY
But we're going a little out of order here... Getting back to the update, I drilled out and then glued together the wing halves. I started the gluing process in the main gear wells, and then aligned the ends of the wings before going back along the leading and trailing edges. This process resulted in very poor alignment of the leading and trailing edges, but correct alignment at the wingtips. Fixing the leading edge involves the usual process of sanding/filling/sanding. The trailing edge will require a bit more work, but essentially involves filing down the lower half of the trailing edge to thin and then rebuild it.
qnfgmid5W87G5HjYJw1v2IF3C2MMt8fJ0UXoQxu4
kHemxOiuR4F-U4N7O2Fd6VGILdBQU78dxnjnGx9U
2_Q5IB8bC527SYncVep4_zhM9Uc9Qc7AOex1n6CT
hGDBa0XvElZT5f8WPTYztn_Hd-6TiE_SQAbUbEgc
I also began the sanding and filling process on the horizontal stabilizers and the fuselage itself. Regarding the horizontal stabilizers I only inserted the front locating pins. The model has supporting structures for the stabilizers, so I felt having the second pin would hinder alignment more than it would help. On the fuselage I used 180 grit paper to reshape the identified problem areas, but not too much effort was needed. The critical alignments, in my opinion, have been very good so far!
IdxD16kmMZlZ1iA7xCm7QdEbGfM77yTzdeIs8xqc
Hct1IZv5XBNVHJZ8Ocgs2fOXhvcqrk3rOk-XsIlR
LdQqLQ2A8Xn9fPJORo9WIzAANNGuPuLc6iky-dvb
Finally, the fuselage has been primered to check for flaws. I think one more round of sanding and filling will get it done. Having said that, I will clearly need to install the tail engine before I primer again, so that will be my next step. Thanks for checking in!
0iU_uqVhKPvm2gx-eVeCD5Ms4C8ZjkbdKfhsr3Jz
vKEccJUFUC0ApR1D6irOesWzKWFFnjB-HHwrQlXa
mvV8xVIKh-ap9rIWpdgM_0l6pJWAnFFkB-MR_Jkh
Edited by Ridgeline
My apologies for double-posting, but I decided to spend some more time on the wing-fuselage joint. After staring at it some more, I figured the best solution would be to add a shim to the lower wing halves. In this case I used .020" styrene strips and sanded to shape. As always, there is more cleanup yet to be done, but I'm VERY happy with the fit now. The wings are very tight on the fuselage, and any play has been eliminated. I will likely add some putty to the wing end for an even tighter fit, but for now I will proceed with the balance of the construction...
gmhob3Oto_uW4CQF6x1uC1GAvO_StvaUpSINnUCr
bk0qEoxw9QmCAKUp60kqhSLAk7cYGrzwund4oZZU
1d-4BpoNj-OnweSun9CWxpdo1b86Upztul97NQsp
YcrTjiu5yLA_4Jn89-Ntc0MRR-_HNOODHhtuyQCK
wUfRWR0RmPq7ulAKlteJs4IP4aD3XkXveyanaw5F
tq2ju1uu0jCnWr6JYJ99eB9xyjt0W7WP3bkU4HMy
SxBATtOfpWdOt_r9AQHFrOiCI0Wk9-dSM92UOhnm
And you will have to forgive the indulgence, but I absolutely wanted to see how she looks with the major parts dry-fit:
16w1SYT7QVZI8rQ24_7nEP1IzJa-BpBouMCTgx6u
:D
Edited by Ridgeline
Thanks for sharing such an in depth build thread Andrew, I have a couple of these and a Welsh Models MD-11 to build.
Just a note, the second last post (Post #5) has lost its images :(
Ray, thank you for the heads-up brother! Please let me know if the images continue to be a problem... They are showing up on my screen, so I hope that means they're working now.
Hi , still not seeing the images. And I'm eager to see how you've tackled the wing join 🤓
Jeff
My apologies, guys! I checked the thread on my tablet and confirmed that the images were not showing up. Perhaps they were cached on my laptop, and that's why they were working for me.... I checked my google account, and it looks like I uploaded this album to the wrong one.
For now I have changed the sharing setting on the album. Hopefully they are working now for all of you! When I get back to my studio I will migrate the album over to the correct account. I still can't figure out why the images in the first post were showing up, but the images in posts 5 and 6 were not..... The magic of the internet, I guess!
Edited by Ridgeline
Well Andrew, looks like the carpet monster is at your images, now the last lot you posted plus a single image from your first post have disappeared.
No doubt they will show up when the build is finished! :D
Oh, boy... It's funny in the Shakespearean sense now! I knew this build was going along way too easily!
I've migrated the album over to my regular posting account... But, honestly, if you guys don't WANT to see my images just let me know... :lalala:
Seriously, though, they are working on my tablet after the migration. I'll check again in the morning... If they are still not showing up I will try hosting them on a different site.
Thanks for your patience and your humor, guys!
Hi Andrew
Firstly, I can see the images.
Secondly, thanks for a very informative build thread - having the KLM version in my stash I'm very interested to see any potential pitfalls.  Also have a Tristar, so if a DC10 comes up on a certain auction site at the right price was thinking of a Tri jet tri-build!
I can see all the pictures as well again Andrew. Glad you got it sorted.
Now where did I put my MD-11 kit(s)
That's absolutely brilliant Andrew. Thanks so much for coming up with a practical solution to fitting the wings. A reviewer on Airliner Cafe described the method of attaching the wings as "screwy". I could come up with a few other words which would cause this post to be deleted. The only other kit I've seen with a comparably daft wing fitment is the Amodel Lancastrian.
I will certainly pinch your ideas when I get back to my own model. There's no doubt that once you get the thing assembled it really looks the part. It's the getting it assembled that's the hard bit!
Dave G
