Mike Posted September 3, 2017 Share Posted September 3, 2017 Bf.110F Update Set & Masks (for Eduard) 1:48 Eduard We've just reviewed the new Profipak boxing of this kit here, And as seems to be the case of late, Eduard have also prepared an additional upgrade set, and the masks in a separate package to cater for an upcoming Weekend edition, no doubt. As usual with Eduard's Photo-Etch (PE) and Mask sets, they arrive in a flat resealable package, with a white backing card protecting the contents and the instructions that are sandwiched between. Upgrade Set (49833) This set contains a small pre-painted and nickel-plated fret in the front of the package, giving the (mistaken) impression that there isn't much to it. Flip the pack over and you will see a large bare brass set for the airframe however, which will add lots of additional detail to your finished kit. Starting in the cockpit, additional details are added to the gunner's station, including perforated cooling jackets for the guns; more detailed trigger and guard; ammunition belt, as well as lots of extra interior details to the canopy, some of which is pre-painted. In the gun bay all the ammo feeds have detail added to the tops, wiring between the guns, and for two bottles in the bulkhead area. The engine nacelles are modified with replacement cooling gills, and a central strut in the oil-cooler intakes, plus a substantial reskin of the gear bays, which includes an additional lightened horseshoe shaped frame in the rear, and radiator meshes in the oil cooler baths. Additional ribs are added to the length of the bay sides, and a strip of hinges are laid along the lip and folded into shape. The engine's cooling is also treated to a wafer thin cooling flap with actuator, the bay door actuators are added to the front of the gear bay, and the struts are detailed, one of which is a pre-painted data plate for the damper to which it is applied. The main legs are fitted with brake hoses to complete the area. Other areas that are treated are the bomb tails, which receive new in-scale fins; mesh inserts for the nightfighter exhaust dampers; additional parts for the gear bay door linkage; more detailed actuators for the tail feathers; a new DF loop and aerial base, and a couple of small inspection panels on the top of the nacelles. Masks (EX555) Supplied on a sheet of yellow kabuki tape, these pre-cut masks supply you with a full set of masks for the canopy, with compound curved handled by using frame hugging masks, while the highly curved gaps are in-filled with either liquid mask or offcuts from the background tape. In addition you get a set of hub/tyre masks for the wheels, allowing you to cut the demarcation perfectly with little effort. If you have the Profipak edition, you won't need these unless you have stuffed up the sheet included in the box, which is functionally identical. Review sample courtesy of 1 Link to comment Share on other sites More sharing options...
