JOCKNEY Posted August 27, 2017 Posted August 27, 2017 Ok here we go, I can't put this off any longer ! Some pictures before I started to extract the parts from the Resin puddle, the final one showing my start time. This kit is displaying all the typical Unicraft traits, i.e. Fuselage is banana shaped, wings look different sizes and you are left to decide where the parts go, as there are no real instructions or alignment points for the parts, however this may be the way things are done with Resin, I wouldn't know ! Right here we go with parts cut out and sanded a bit, but managed to mislay the missiles already ! Good luck everyone, and congratulations to those already finished ! cheers Pat 7
Valkyrie Posted August 27, 2017 Posted August 27, 2017 Never seen anything like that before, il be intrigued watching this...and nice watch too 1
SleeperService Posted August 27, 2017 Posted August 27, 2017 Sorry to say but some companies aspire to instructions as detailed as that. A very interesting looking plane although honking great lumps of resin on resin u/c legs may not be good. 1 1 1
SeaPlane Posted August 27, 2017 Posted August 27, 2017 Looking Good Pat Those pieces seem to have buffed up well and come away from the blocks reasonably well. Must agree with Sleeperservice though, those main undercarriage legs won't take the weight for very long. Might be better to do wheels up, drill a hole in one of the jet exhausts and stuff a rod up the back for an inflight moment. As you know I find metal coat hangers bent accordingly work very well!! Good Luck 1
Angus Tura Posted August 27, 2017 Posted August 27, 2017 As the proud owner of one completed Unicraft model, which took me about six months, I'd say that that is pretty challenging! But also very neat. Are you planning on mottling it? Alan 1
JOCKNEY Posted August 27, 2017 Author Posted August 27, 2017 Hi everyone Thanks for all the encouragement, I have gouged out the middle of the fuselage with a grinding stone to try and keep the weight down, so plan to try the undercarriage, it only has to last till one minute past midnight Monday night Yes I plan on doing a paint job simular to this Calm down it's not a "Blue Peter" moment with the one I did earlier ! This was done by someone who knew what they were doing ! Fuselage took some persuading, had to use the big grips, wings are as good as I can get them, the rest is looking a real challenge Anyone know how to get a Vacform canopy to fit without wrecking it PLEASE ! cheers Pat 5
SleeperService Posted August 27, 2017 Posted August 27, 2017 Oh for the love of God! (Other deities may be substituted.) Vac-form canopy. New scapel blade, next to no pressure you drag the blade along the line don't, whatever you do, push the blade in, it'll end badly. Fill the canopy with blue tack or plasticine before touching it, or even looking at it too long. They'll give you the best chance. Under and over engines and Me163 wings. I bet that would have been interesting and rather short ranged. When you've removed all you think you can from the big lumps keep going another hour. Then you'll be in the right ballpark Hey I've got one of those E.555 thingys. I think I have an idea (not in 24 hours though or maybe....) 3
JOCKNEY Posted August 27, 2017 Author Posted August 27, 2017 1 minute ago, SleeperService said: Oh for the love of God! (Other deities may be substituted.) Vac-form canopy. New scapel blade, next to no pressure you drag the blade along the line don't, whatever you do, push the blade in, it'll end badly. Fill the canopy with blue tack or plasticine before touching it, or even looking at it too long. They'll give you the best chance. Under and over engines and Me163 wings. I bet that would have been interesting and rather short ranged. When you've removed all you think you can from the big lumps keep going another hour. Then you'll be in the right ballpark Cheers SS I destroyed my Supermarine 224 canopy / windscreen on my first Vacform so don't want a repeat of that here. Im not sure I have enough filler, I've just glued the nose section on and it looks like it was fitted in the dark ! The bad news is the rear end is even worse..... why didn't I listen when I was told not to build this cheers Pat 1 1
Valkyrie Posted August 27, 2017 Posted August 27, 2017 1 hour ago, SeaPlane said: Looking Good Pat Those pieces seem to have buffed up well and come away from the blocks reasonably well. Must agree with Sleeperservice though, those main undercarriage legs won't take the weight for very long. Might be better to do wheels up, drill a hole in one of the jet exhausts and stuff a rod up the back for an inflight moment. As you know I find metal coat hangers bent accordingly work very well!! Good Luck Is that wat you can do? Brilliant, I WILL give that a go 1
SleeperService Posted August 27, 2017 Posted August 27, 2017 8 minutes ago, JOCKNEY said: Cheers SS Im not sure I have enough filler, I've just glued the nose section on and it looks like it was fitted in the dark ! The bad news is the rear end is even worse..... why didn't I listen when I was told not to build this cheers Pat Because you are a will-full young man who won't take instruction. Possibly the end pieces are from another kit, I believe this has happened before from certain bijou suppliers of Gentlemen's Resinous Essentials. 3
JOCKNEY Posted August 27, 2017 Author Posted August 27, 2017 1 minute ago, SleeperService said: Because you are a will-full young man who won't take instruction. Possibly the end pieces are from another kit, I believe this has happened before from certain bijou suppliers of Gentlemen's Resinous Essentials. I think you are beginning to know me too well ! Well these bits will have to be made to fit, so if it ends up as rough as a badgers bottom, I have my excuses all ready 3
Mrs PlaStix Posted August 27, 2017 Posted August 27, 2017 will be watching with interest (when I get chance) 1
JOCKNEY Posted August 27, 2017 Author Posted August 27, 2017 Lots of filling later, it looks like this The observant will notice the underwing pylons, which I found when the missiles reappeared, naturally no idea where they go but here looks right and it wouldn't have been hit by the undercarriage, always a result when you are flying something ! Now recovered missiles below under construction This shows the colours I'm going to use, and give an idea of scale. Lichtblau 76, H247 overall Granviolett 75, H246 mottling RLM 02, H240 wheel wells etc RLM 66, H67 cockpit, air intakes and exhausts If this choice isn't correct I apologise, but let's see how it turns out shall we cheers Pat 8
TonyTiger91 Posted August 27, 2017 Posted August 27, 2017 Well done Pat ! What a challenge ! It's looking quite tidy now. The main thing with the canopy is not to rush. It takes quite some time, but vac form canopies often look really good and they're worth the extra work Looking forward to the colours going on. Best regards TonyT 1
JOCKNEY Posted August 27, 2017 Author Posted August 27, 2017 15 minutes ago, TonyTiger66 said: Well done Pat ! What a challenge ! It's looking quite tidy now. The main thing with the canopy is not to rush. It takes quite some time, but vac form canopies often look really good and they're worth the extra work Looking forward to the colours going on. Best regards TonyT Thanks Tony Despite scrubbing the parts in cleaner, the first coat of H247 looks a shocker, so leaving to dry and watching "Match of the Day 2" on the telly with a nice dram of Bowmore and the dogs snoring on the sofa 1
AdrianMF Posted August 27, 2017 Posted August 27, 2017 58 minutes ago, JOCKNEY said: Now recovered missiles below under construction On my phone, your file handle with the red and dark green looks very like a Luft46 engine, so if it doesn't work out you could always stick a couple of files together and call it a Flettner/Horten 234 or something... But it looks like you are winning with the resin. Good luck! Regards, Adrian 3 3
JOCKNEY Posted August 27, 2017 Author Posted August 27, 2017 Thanks Adrian, Really sorry you run out of time with the Phantom, given the size of it and the number of parts it was always going to be ambitious but you can't let it beat you let's get it done before this GB closes. The cat has knocked the drying aircraft off the kitchen counter and broken the front undercarriage off, one step forward two back ! cheers Pat 3
AlexN Posted August 28, 2017 Posted August 28, 2017 Ye gods and little fishes! A twin-engined Me 163 with a snout-put-on-a-diet! Or through a mangle. Looking good there Pat - the instructions that I have for the (untouched) resin kits wot I got (MDC, Fisher Models, Planet Models) are definitely bulkier than yours! Good luck with the u/c legs - and the clock! Cheers, Alex. says good luck, too 1
SeaPlane Posted August 28, 2017 Posted August 28, 2017 Going well Pat Unfortunate episode with the cat - never work with children and animals. Does a broken nose-wheel now move you towards a wheels up version?! Looking forward to the results Andrew 1 1
JOCKNEY Posted August 28, 2017 Author Posted August 28, 2017 Right, this is it, all or nothing for midnight. Just taken a better look at the decals and wish I hadn't, quality control must have had the day off I have some Frog Me262 ones somewhere I think they will do instead. photo above shows bits drying ready for attachment, the rest of the aircraft is in the airing cupboard trying to dry it after having to give it a 3rd coat of paint ! Still haven't mottled it yet, this is going to be a close call, might have to result to using Mrs Jockney's hairdryer when she's not looking. The bluetac tip earlier in this thread is brilliant, even I have managed to extract a canopy from the deformed plastic bubble supplied by Unicraft - result Good luck to everyone still building cheers Pat 6
TonyTiger91 Posted August 28, 2017 Posted August 28, 2017 Great stuff Pat Keep at it; I've a strong suspicion you will complete this! All the best TonyT 1
JOCKNEY Posted August 28, 2017 Author Posted August 28, 2017 Thanks Tony Keep everything crossed, but don't do yourself a mischief in the process. cheers Pat PS I see you are co-hosting the flying boat and floatplane GB as well so see you again soon ! 2
JOCKNEY Posted August 28, 2017 Author Posted August 28, 2017 Right, time for some progress photos The blue has been a complete, swine to do followed by mottling Found the Frog 262 Decals, wonders will never cease Starting to take shape 8
