DaveJL Posted January 13, 2018 Posted January 13, 2018 I'm looking forward to this release, though i'll have to get some AM decals as i'd quite like to do the dark grey over light blue scheme.
Homebee Posted January 14, 2018 Author Posted January 14, 2018 (edited) Pre-order at HE: http://www.hobbyeasy.com/en/data/2gtw7pte7yawsgorv9kb.html?t=1515932377 LM: http://www.luckymodel.com/scale.aspx?item_no=GW-L4820 HS: http://www.1999.co.jp/eng/10513465 HLJ: https://hlj.com/product/LORL4820 Dawngrocery: https://www.ebay.co.uk/itm/GreatWall-1-48-L4820-Russian-Su-35S-Flanker-E-/173120462687?hash=item284ec89f5f With expected release date on February 12th, 2018. V.P. Edited January 27, 2018 by Homebee
ya-gabor Posted January 16, 2018 Posted January 16, 2018 Well this is what one can expect in the box of the G.W.H Su-35S kit. Hope you like it. First of all The box main sprues cockpit parts Cockpit tab tires The canopy sprue Best regards Gabor 7
Marlin Posted January 16, 2018 Posted January 16, 2018 WOW. I know what I'm buying come payday......... /Bosse
exdraken Posted January 16, 2018 Posted January 16, 2018 On 14.1.2018 at 1:21 PM, Homebee said: Pre-order at HE: http://www.hobbyeasy.com/en/data/2gtw7pte7yawsgorv9kb.html?t=1515932377 LM: http://www.luckymodel.com/scale.aspx?item_no=GW-L4820 HS: http://www.1999.co.jp/eng/10513465 HLJ: https://hlj.com/product/LORL4820 With expected release date on February 12th, 2018. V.P. oh my god.... with shipping costs like these (over 30 €!! ) they will not sell many! probably the box got too big?
vesthepes Posted January 16, 2018 Posted January 16, 2018 4 hours ago, exdraken said: oh my god.... with shipping costs like these (over 30 €!! ) they will not sell many! probably the box got too big? Ooh, 36,8 € to my place. I really like the kit, but that's just ridiculous... 1
ya-gabor Posted January 16, 2018 Posted January 16, 2018 Over on ARC some questions were raised on what some lines look like, different panel lines and engraved lines going nowhere. Here are few views with some explanation on what is what. The overlapping panels are authentically reproduced which on most kits would be a simple engraved panel line. There are different service panels all over the aircraft as well as joint lines of surface panels. In some cases they are represented in a different way as required to reproduce the real surface. The same applies to rivets, screws (round head or flat), fast locks, they are all different size! Have to admit that I have no idea how many versions were used in the end, have to count the variations which were incorporated into the kit. Yes, you are right, on the bottom surface a lot of panel lines, rivet lines go into nowhere. The reason is simple, what you see here is just part of the kit, it is a sub assembly. When all the different parts find their place it will be clear where those “renitent lines” go to. Best regards Gabor 3
ya-gabor Posted January 17, 2018 Posted January 17, 2018 On ARC question was asked about the curved surface and how different the details look on it in comparison to completely flat surfaces of the kit (the ones shown above). Well here is a bit about it: Last time I have said that I can show only what I have. Be patient please. Here is a curved surface with all sorts of details on it. Lines, rivets looks consistent even at the base of the curve. Here are the “other” sprues. All the bits and pieces and missiles. The engine cover one piece parts made with the “primitive” slide-mould technology. Of course you will see a hairline joint on the surface which should be easy to sand off without damaging the surrounding area. The nose gear door with place marked out for the de-icing alcohol container which is fitted to the current production airframes and retrofitted to most early production one. To go with it a de-icing sprinkler in front of the windshield is provided as a decal. Here there is a choice for the modellers if they want to make the earlier electric de-icing version the alcohol container should be left off and the heater filaments added on the windscreen in the form of a decal. Nose gear bay Best regards Gabor 4
DIO Posted January 18, 2018 Posted January 18, 2018 I am amazed! But I will be waiting for a two seater :-)
salomon Posted January 18, 2018 Posted January 18, 2018 I can't wait to buy one. the cockpit looks really amazing, and the rest too.
exdraken Posted January 18, 2018 Posted January 18, 2018 7 hours ago, DIO said: I am amazed! But I will be waiting for a two seater :-) I guess you will wait long..... there is no two-seater of a current Su-35S in real life! only the old one, that is more Su-27 actually.... 1
DIO Posted January 18, 2018 Posted January 18, 2018 1 hour ago, exdraken said: I guess you will wait long..... there is no two-seater of a current Su-35S in real life! only the old one, that is more Su-27 actually.... Doesn't have to be a su-35. A 2 seater from that company and that quality is welcome :-) 1
ya-gabor Posted January 20, 2018 Posted January 20, 2018 If anyone is still interested in the G.W.H Su-35S kit. Here is a quick test build of the parts. It is almost a dry build, a real Weekend build done in few hours. What do you think? All photos by Haneto. But first here is a bit of the fuselage after the cockpit which had some questions. So here is the test build of the kit The cockpit with open canopy Best regards Gabor 4
ya-gabor Posted January 20, 2018 Posted January 20, 2018 More of the quick test build of the new G.W.H Su-35S kit. All photos by Haneto. Here is the Hibinji electronic warfare container on the tips of the wings. There is a left and right side version and it is now a standard fit of the Su-35S when it goes to war. On a Russian TV program an officer was giving a quick description of the pod saying that it is for countermeasure and is fully effective below the 6000 m level. There was no time to add some notes to the instruction sheet in the kit. If one takes a better look at the pods then it will be visible that some pods have a much darker grey cover (from the nose cone and other dielectric panels). In fact the covers are fairly frangible and many of them were replaced after breaking. In the latest version the blunt end of the pods was replaced with a new sharply pointed front cover, but this was visible only on Su-34’s till now. Anyway have a closer look at the reference photos of the particular aircraft you are building and could find that the Hibinji pod cons are of different colour. And a bit of the undercarriage bay with all the pipes added as separate parts from Sprue I. Best regards Gabor 3
Uncle Uncool Posted January 20, 2018 Posted January 20, 2018 (edited) Noooiiiceee...!!! The double curvature on the LERX surface looks spot on. I've been checking out the Kitty Hawk kit two days ago and was positively surprised at how good this feature was also caught by the design team; that, and especially the rounded fuselage section on the cockpit area, which the blokes at Hobby Boss botched on "they're" Flanker family of kits. First 1/48 kit in the Flanker family having finally achieved it. Say, Gabor; how does the GWH kit compare to the Kitty Hawk kit with regard to these two features I've pointed above? Oh, and please, don't give me your "this-thread-ain't-about-the-Kitty-Hawk-kit" line 'cause it'll just make me go bonkers. It's just a simple question in order to see whether I'll get yet another Flanker E kit in that scale. Cheers now, Unc2 Edited January 20, 2018 by Uncle Uncool Typo; the pirate in me wants to take over once again
ya-gabor Posted January 21, 2018 Posted January 21, 2018 15 hours ago, Uncle Uncool said: Noooiiiceee...!!! The double curvature on the LERX surface looks spot on. I've been checking out the Kitty Hawk kit two days ago and was positively surprised at how good this feature was also caught by the design team; that, and especially the rounded fuselage section on the cockpit area, which the blokes at Hobby Boss botched on "they're" Flanker family of kits. First 1/48 kit in the Flanker family having finally achieved it. Say, Gabor; how does the GWH kit compare to the Kitty Hawk kit with regard to these two features I've pointed above? Oh, and please, don't give me your "this-thread-ain't-about-the-Kitty-Hawk-kit" line 'cause it'll just make me go bonkers. It's just a simple question in order to see whether I'll get yet another Flanker E kit in that scale. Cheers now, Unc2 Sorry, I don’t have other kits of the Su-35 family, so there is no basis for comparison! It was never a research goal to observe and analyse what anyone else is doing. We had our own priorities and ideas of what we want to see in our kit. Research and design was based on this. The final decision in each case was up to the manufacturer, all we could do is make suggestions from a modellers point of view. Some of them where incorporated, some not. A personal note, I don’t think it would be too ethical for me to say anything about other kits since I am deeply involved in this one. Please ask people who have both kits and I am sure they will be able to say far more. And yes, this thread is about the G.W.H Su-35S kit. All I can do is to show what the kit looks like, what the different details are which were important for Haneto and me. It is up to everyone else to make a decision based on the images. This is not “HYPE” as someone has pointed out, simply showing the kit! You are all grown-ups to make a decision and based on your own taste make a choice between different kits. Best regards Gabor 1
Uncle Uncool Posted January 21, 2018 Posted January 21, 2018 1 hour ago, ya-gabor said: Sorry, I don’t have other kits of the Su-35 family, so there is no basis for comparison! Please ask people who have both kits and I am sure they will be able to say far more. Fair enough; thanks.
ya-gabor Posted January 21, 2018 Posted January 21, 2018 A bit more on the engine covers, the engine exhaust and the intake ducting all the way up to engine compressor stage. Best regards Gabor 3
ya-gabor Posted February 1, 2018 Posted February 1, 2018 I think enough has been shown of the new 48th scale GWH Su-35S kit in the past months. Now it is time to add few drops of paint and do the second test build, this time here in Europe. It is here: Best regards Gabor
Uncle Uncool Posted February 4, 2018 Posted February 4, 2018 On 20/01/2018 at 1:02 PM, ya-gabor said: But first here is a bit of the fuselage after the cockpit which had some questions. Good Lair! What's with that awful trench of a panel line running across the fuselage at the level of the slats? That's a turn-off to me. What happened?
Homebee Posted February 4, 2018 Author Posted February 4, 2018 (edited) Chinese in box review: http://www.moxingfans.com/test/other/2018/0202/4442.html Kit released in China. https://www.ebay.fr/itm/GreatWall-1-48-L4820-Russian-Su-35S-Flanker-E-/173120462687?hash=item284ec89f5f https://item.taobao.com/item.htm?id=563514389412&clk1=8c27ef9734b3e0cefa78c321119f7b52&upsid=8c27ef9734b3e0cefa78c321119f7b52&clk1=8c27ef9734b3e0cefa78c321119f7b52&upsid=8c27ef9734b3e0cefa78c321119f7b52 Some pics of the final product V.P. Edited February 5, 2018 by Homebee 1
madcop Posted February 5, 2018 Posted February 5, 2018 9 hours ago, Uncle Uncool said: Good Lair! What's with that awful trench of a panel line running across the fuselage at the level of the slats? That's a turn-off to me. What happened? It doesn't look like that on the pics of the parts appearing on the Chinese in box review. An early test shot part maybe ? Madcop
Uncle Uncool Posted February 10, 2018 Posted February 10, 2018 On 04/02/2018 at 9:44 PM, madcop said: It doesn't look like that on the pics of the parts appearing on the Chinese in box review. An early test shot part maybe ? Yeh, it does look like that one every kit. Anyways, madcop; I feel that arguing with you regarding any subject is like this:
