F-111C Aardvark RAAF , Academy upgrade boxing 1/48 - finished!
F-111C Aardvark
RAAF
Academy 1/48
 -Cutting Edge seamless Tripple Plow I intakes
- Eduard seatbelts
- Eduard detail for the nozzle shrouds (for the HB kit actually)
- Montex masks
- Academy BRU rack with Mk-82 bombs (from the E model kit I just received for this purpose.... :banghead: )
Eduard Mk.82 bombs
originally started in the great F-111 STGB, but not finished for many reasons:
I will continue here, hopefully for not too long!
as a summary, just some WIP pics, for more info please refer to the above link!
content of the greatly updated Academy F-111C boxing!
would do the other boxings good as well!
If you go though the GB builds, the newer HobbyBoss kit does not live up to its price and superficail detail unfortunately!
cockpit base color
seats improved with Eduard steel belts :)
Edited by exdraken
Cutting Edge Tripple Plow I intakes :
 the instructions are a badly copied piece of paper, bit the necessary steps to be done are quite easily understood.
IMG_5609_1_1_zpsky421z8p
the intakes are made up of several parts. the main one in white resin, that will ease painting enormously!
IMG_5619_1_1_zpsxt2ivuyl
not the best photo, but the best I could get tonight :)
IMG_5620_1_1_zpsvvtfwtx4
the marked area has to be cut in order to slide in the intakes.
and some minutes later:
IMG_5622_1_1_zpsq25tlmis
only some sanding and fitting was necessary. (the edges of the undercarriage bay needed to be rounded a bit  e.g. )
IMG_5625_1_1_zpsibal9jx2
fit is good, no glue yet!
IMG_5626_1_1_zpsla9wl3pe
intakes glued in, no major problems here :)
IMG_5769_1_1_zpsnvrqxqwz
IMG_5770_1_1_zpskarib07v
engine faces painted as well with a white center hub? at least I found a foto online showing this, and it adds detail :)
engine faces could be a bit cleaner, but this is quite old resin, so lets say it is ok ;)
IMG_5767_1_1_zpsgpysrca6
IMG_5772_1_1_zpsm2wwu20z
wing sweep, wings, an so on....
I will try to make the wing swiveling mechanism work AND look decent on a model... I have succeded on a Tornado and a MiG-23, so why not here as well ? This time pylons come into play though....
20170620_214519_1_1_zpsykkzyuai
swiveling mechanism:
I used super glue instead of the proposed screwdriver and plastic melting process...
20170621_232308_1_zpsgewjpaip
20170621_232330_1_zpsiewqjzgd
top surfaces glued on:
20170621_233102_1_zpsv9ir9haf
that is what we can expect later on:
20170621_233116_1_zpsvo2yt17v
20170621_233138_1_zpstkokpnek
I glued the top fuselage part and front section together first in order to improve the dreaded joint...
not sure if successful!
20170620_214538_1_1_zpsxgbydxfs
and finally, i am thinking of gluing the upper main fuselage section to the cockpit section first, in order to have a better joint at the most visible part....
20170620_214742_1_zps4crbwy0r
20170620_214821_1_zps3o5nekjh
cockpit section and upper main body section GLUED here! but not sanded yet ;)
20170621_235320_1_zpsibmxlf9e
20170624_190133-1_zpsu1rgsdcg
http://i1379.photobucket.com/albums/ah144/exdraken1/F-111C/20170624_190149_1_zpslflexx4c.jpg
wing sweep faring....
better than a hole at least ;)
20170624_174643_1_zpsgrihgecn
not correct, but better?
http://i1379.photobucket.com/albums/ah144/exdraken1/F-111C/20170624_190322_1_zps3iwj4wyf.jpg
engines need a lot of improvement....
no depth ...
IMG_5575_1_1_zps4waqfsfq
and something has to be done to this nozzles and shrouds.... anybody nows how many petals these shrouds actually have? I counted 18 on an F-111C.... HB / Eduard provide 12 outer and ~14 inner petal details.......
IMG_5776_1_1_zpsov0gkann
IMG_5777_1_1_zpsujwotqyf
no glue yet, but it gets more interesting like this...
IMG_5779_1_1_zpsyrxfgb58
some crude afterburner section added, some old tomcat turbine parts did the rest
model complete, and ready for painting:
taking photos of a dark grey beast without good contrast is a bit difficult....
whatever:
gunship grey is a bit toooooo dark imho....
20170808_184339_120170808_184201_1
so,
and some small update as well.....
at least some reason to put up this thread here:
20170815_223046_1
I broadened the main wheels in order to represent the heavy duty ones from the FB and C models
20170815_223122_1
the landing gear part are kit parts! :)
20170815_223503_1
gunship grey lightened, but under a coat of clear coat too dark again.... :(
I lightened the paint again...
looks better now I think!
20170820_160848_1
20170820_160920_001_1
20170820_161023_1
20170820_160938_001_120170820_161044_1
hope you like it!
next: painting the radome black - something in between shiny and flat.... and wing leading edges and "leading edge" extensions....
4 hours ago, Hewy said:
Nice contrast you've  achieved there werner  looking very nice in the closing stages
Glynn
thanks,
looks better in real live an sun light though ;)
no gloss coat yet, so I still see some additional darkening
20170827_222420_1_1
yesterday night I work for considerable time on 12 MK-82 resin bombs from Eduard....
20170814_234838_1
I hope the additional effort pays off!
20170827_224704_1_120170827_234857_1_1
  • 1 month later...
work on the bombs lately:
(there are some Matra bombs in the picture as well, but that is for the Mirage GB :))
20170929_183531_120170929_184632_1
a clear coat was also added this weekend, so time for decaling is not far hopefully!
that is waht is on my workbench (or table for drying actually ;) ) currently:
20170929_183432_1
link to the Mirage GB WIP  if anybody is interested:
Edited by exdraken
decaling time!
20171006_223429_1
many long and difficult to correctly put on small walk ways....
as hey are Cartograf printed, no real problem though!
20171006_235435_120171007_003302_1
those gunship grey Aussi Aardvarks were mostly immaculate, the walkways and markings did really stand out and bring the jet to live!
Edited by exdraken
  • 1 month later...
wheels, are upgraded by Academy and do not really need resin replacements! some weathering though!
20171108_215117_1
decaling time in the Armory shop:
20171108_221451_120171108_223209_21
thanks for feedback!
it is quite quiet lately here ;)
:jabber:
Sorry to bud in I saw your work on this fine model,sure doing this aircraft proud,I worked in a school,were 2 of the students became pilots,and they used to tell us when they were flying over,was always a great sight.Cheers.
Edited by Jim Wasley
Coming along nicely! I must say, I did prefer them I'm the SEA scheme and, pleasingly, many of those on display now were repainted in the original scheme. A8-132 was even repainted in the ARDU colours (SEA camouflage on top and white under) for display at Edinburgh.
20171108_215117_1
:jabber:
G'day ED, outstanding work going on there!
One small point which is a nitpick, the tail configuration is wrong for MK.82s fitted to the BRU-3A/A (bomb rack). On F-111s, MK.82s should have the tail in a "+" configuration when viewed from the rear instead of the more typical 'X' configuration (as you have them), however when a  Mk.82/84 was suspended as single store directly beneath the wing pylon, the tail configuration was the typical 'X' configuration.
Looking forward to seeing this one finished,
cheers,
Pappy
cheers,
Pappy
Hi, thanks for pointing out the bomb issue! Quite late to correct this unfortunately.... will see .... hmmmm :speechless:
Thanks everybody for your feedback and small stories! Unfortunately I never saw one fly.... the closest I came to one was at Duxford where they have an E I think....impressive nontheless!
Edit,
Looking at photos
It seem that this x or + configuration is even more complicated!
Front left and right as well as rear bottom only are in +, the rest is in x...or is that due to the mounting on the BRU and they are indeed all +?
Edited by exdraken
Edit,
Looking at photos
G'day ED, they are all '+'.
At first glance the bombs may appear to be 'X' but this is an optical illusion as the LODE14 suspension points are located on the sides of the shoulder mounts (the top rows) which are  angled inward. If you look at the lower mounting points, the suspension points are directly beneath the rack and the bomb tails appear in the '+' configuration,
Pappy
Edited by Pappy
Pappy
Thanks, changed them all meanwhile!
Hope joints will not be too visible ...
