harveyb258
Fiat 806gp full-scratchbuild 1:12
Incredible work I'm always gobsmacked by your work.
Hello everyone.
Time again for an update on the proceedings.
The pulleys were relatively straightforward to fabricate. After turning a couple of grooves into some 3mm ali tube, I inserted and glued some 2mm brass tube and then cut to size.
The casing and attachment brackets are fab'd from tin-plate steel and soldered. Finally, a 1mm brass rod (piened) holds it all together. The pulley wheels spin freely.
Once the pulleys were bolted in place (M0,6), I could finally fit the axle...and boy, oh boy, what a fiddly and frustrating task it was, too. Inevitably, some paintwork became damaged, as you can see, but, I'm not overly concerned at this stage.
Well, that's all for now, folks!!
I hope you enjoy and thanks for watching.
Cheers, H
The next step will be to strip the rear end to repair and re-paint the rear axle. Then, wheel and tyre fabrication time...I can't wait!
You keep amazing me Harvey. I just don't know what else to say 🙂 .... This thing is beautiful.
Me too!!
Olivier
I hope your left frontal wheel won´t start to jump once it is installed ! 😄 Your model is very close to the original .Great , realistic work !   Hannes
Thanks guys!
Me too. It probably will do, though.:D
From the Complaint Department:  :nono:
I thought we agreed a while back 'No Paint'. Unless I missed something.  Although the finishes are distressed and lovely I was under the impression that all parts would be in their natural material finish. Like artwork.
But --- Oh Heck! Ignore me ... this thing is magnificent even if it was pink. :mental:
Carry on -- Mr H....
Thanks Chas.
Apart from the wheels, that's the last paint to be used  on this car. Only the running-gear was painted on the test car.
Harvey, a pulley with a late is easy to made. Without, it's a feat!
Congrats, but you need a lathe my dear... I use an UNIMAT 3, you can got one, it's really cheap!
Be careful! Your radiator leaks:
Dan.
"The pulleys were relatively straightforward to fabricate."
Not for us mere mortals.
Just wonderful.
Harvey, if you don't own a lathe, it's possible for some of us, me for instance, to fabricate pulleys for you, if you want....🤔
I've actually just bought a  mini-lathe to turn the wheel rims, hubs and tyres.. I just need to clear some space in my man cave to  set it up and bolt it firmly in place.
I'm looking forward to getting stuck-in.:D
Stay tuned.
Cheers, H
Good news Harvey! What kind of lathe?
If I can help you, feel free for any question!
Dan.
2 hours ago, PROPELLER said:
What kind of lathe?
One of those cheap Chinese ones.....more than ample for my turning needs at this moment in time.
I don't have any questions just yet, Dan, but I'm certain there will be at some point in the near future.
Cheers, H
Hello all.
Not much of an update, this time, chaps..... more of a back-date really:D
After quite a bit of faffing around, the remedial works to the rear axle have been completed : all new/stronger spring and damper hangers, with the addition of  hanger blanks(?) on the frontal section (as per drawings).
With the axle repainted and installed, I added the reserve fuel line to the bottom of the tank before its installation (previously forgotten:doh:).
Then I finally added M0,6 hardware to the flares and secured the floor-pan with M1 hardware. The nut and studs were drilled with a 0,2 bit and wired with 0,1.
Slowly, but surely, the to-do list gets shorter, so I'm a happy-chappy!!
Thanks for watching, more soon!!
Cheers, H
Accurate safety wiring in 1/12 scale ----ON THE BOTTOM OF THE CAR no less ! You are a seriously possessed man !:mental:
BRAVO !
Thank you my good man.
But, at least I haven't got a nut loose....:D
Shameless Confession: We're kindred souls: I wired the 22 bolts on the oil pan, scatter shield and the competition gas filler on the Cobra....:confused:
As it seems this car was not constructed for 007 James Bond .If the nuts would become bullets they could help to beat back the persecutors !🤪
Very well done !   Hannes
