Sign in to follow this
Shar2
British Pre-Dreadnought HMS Lord Nelson. 1:350
HMS Lord Nelson
1:350 Hobbyboss
History
HMS Lord Nelson was a Lord Nelson-class pre-dreadnought battleship launched in 1906 and completed in 1908. She was the Royal Navy's last pre-dreadnought. The ship was flagship of the Channel Fleet when World War I began in 1914. Lord Nelson was transferred to the Mediterranean Sea in early 1915 to participate in the Dardanelles Campaign. She remained there, becoming flagship of the Eastern Mediterranean Squadron, which was later redesignated the Aegean Squadron. After the Ottoman surrender in 1918 the ship moved to the Black Sea where she remained as flagship before returning to the United Kingdom in May 1919. Lord Nelson was placed into reserve upon her arrival and sold for scrap in June 1920.
HMS Lord Nelson was laid down by Palmers Shipbuilding and Iron Company at Jarrow on 18 May 1905 and launched on 4 September 1906. Her completion was greatly delayed by the diversion of her 12-inch (305 mm) guns and turrets to expedite completion of Dreadnought, and she was not fully completed until October 1908. Although she was not the last pre-dreadnought laid down for the Royal Navy, she was the last one commissioned.
Lord Nelson displaced 17,820 long tons (18,106 t) at deep load as built, with a length of 443 feet 6 inches (135.2 m), a beam of 79 feet 6 inches (24.2 m), and a draft of 26 feet (7.9 m). She was powered by two four-cylinder inverted vertical triple-expansion steam engines, which developed a total of 16,750 indicated horsepower (12,490 kW) and gave a maximum speed of 18 knots (33 km/h; 21 mph).
She was armed with four 12-inch guns arranged in two twin gun turrets, one turret each fore and aft. Her secondary armament consisted of ten 9.2-inch (234 mm) guns, eight in twin gun turrets on each corner of the superstructure, and a single gun turret between them. For defence against torpedo boats, Lord Nelson carried twenty-four QF 12-pounder 18 cwt guns and two 3-pounder guns. She also mounted five submerged 18-inch (457 mm) torpedo tubes for which 23 torpedoes were stowed aboard
The Model
We’ve yet to see many British ships in this scale from WWI, but it’s great that we are at last seeing some pre-dreadnoughts being released, and long my it continue as there are some great subjects that I’m sure we’d all like to see on our work benches at some point in the future. This kit of HMS Lord Nelson comes in a relatively small box, as these weren’t the largest of ships compared with later battleships. Inside there are nine sprues, one separate part and the deck all produced in light grey styrene, four sheets of etched brass, a length of chain and a medium sized decal sheet.  Now I hope you’re all sitting down when you read this, as it appears that Hobbyboss have got the hull pretty much spot on with this kit, well, certainly according to R A Burt and his excellent books on British battleships and also the constructors model which used to be on display at the Science museum.  The rest of the parts are very nicely moulded with plenty of detail, although there will be some who will want to add even more. There are no signs of flash or other imperfections, but there are quite a few moulding pips, which means a little extra cleaning up of parts.
Construction begins with the two piece hull being joined together and strengthened with the three bulkheads and two end beams. The single piece deck is then attached, making a pretty solid and strong hull. On the underside, the tow propeller shafts, A frames and propellers are fitted, as is the single rudder. With the hull upright, the three piece, fully PE, Admirals walkway is fitted to the stern, followed by the PE rails fore of A turret barbette and aft of X turret barbette. The myriad of windlasses, cleats, bollard and ventilators are then glued into their respective positions, as are the Jack and Ensign staffs and their supports. Amidships there are seven deck houses to be fitted along with four cable reels and three winches.
The superstructure is made up from a single piece item to which twelve supports are glued to the underside before being glued into position over the previously fitted deck houses. Remember to add the pair of foreward mounted 12 pounders that fire from ports at the forward end of this “flying” flying, as you won’t get them in once the deck is glued down. The superstructure longitudinal bulkheads are then attached, as are PE four inclined ladders, four side mounted windlasses, two boat booms and the anchor chains. To the upper deck, four, three piece winches, sixteen 12 pounder guns and five deck houses are fitted. This deck is then covered by a two piece 03 deck, with the aft section supported by six vertical columns. The main bridge deck is then attached foreward and small mezzanine decks aft with two inclined ladders leading to the 12 pounder deck.
Each of the two funnels are made up from two halves, a base and funnel cap. To these, PE funnel cap grilles are added, along with PE hand and foot rails, and two auxiliary vents. The three piece armoured bridge, two deck houses and the two piece ships wheel are attached to the bridge deck. The two funnel assemblies are then glued into place along with two vertical columns aft. The boat deck is fitted out with eighteen PE boat cradles and a rescue float. There are fifteen boats in total, most of which come with separate hulls and decks, and some also have separate rudders. The three steam pinnaces and eight rowing boats are glued to their respective cradles, and then two other rowing boats are crutched within a larger boat.
The main mast is made up from lower mast section, a two tier observation top with PE support brackets, upper mast section and yardarm. The lower section is then fitted with three PE blocks, and the three piece goose neck for the boat crane boom, which is also fitted with PR blocks and a PE hook. This is then fitted aft of the boat deck and supported by two angled support arms, finished off with two PE vertical ladders. The foremast is of similar construction, just with a slightly small boat handling boom, three yardarms and a searchlight in the lower of the two tier observation top, it is then glued just aft of the armoured bridge deck house. The PE bridge house surrounding the ships wheel is then folded to shape and glued into place, with another deck above it supported by two PE braces. Two binnacles are attached to this deck and inclined ladder. Six 12 pounder guns and eight searchlights are fitted around the boat deck and the PE bridge wings attached wither side of the bridge deck.
The bridge deck and aft boat deck railings are then attached, as are the two long ladders to the foremast observation platforms, and two pairs of davits to the aft end of the superstructure. Four more two part ships boats are assembled and fitted to the two pairs for davits either side of the quarterdeck. The anchors, fourteen anti-torpedo net booms are then attached to the hull, along with the two PE rear mounted accommodation ladders and the PE folded netting that is fitted to each side to the ship. Each of the two main gun turrets and six secondary turrets are made in the same way with the barrels fitted with separate trunnions and trunnion mounts glued to the base with the turret slid over the barrels and glued into positions. Some of the turrets are fitted with 12 pounders and some with 3” gun on their roofs and all have PE vertical access ladders attached. Once assembled, they are fitted into their respective barbettes. Finally the main PE railing is attached to the main deck, completing the build. Well, I say completed, but if you want to do a proper job you will probably spend more time with the complex rigging than you had done for the whole build. Good luck with that.
Decals
The single decal sheet contains a selection of White Ensigns and Admirals flags as well as a pair of funnel bands. They seem pretty well printed, with good opacity and in register.
Conclusion
At last, a British pre-Dreadnought in injection moulded plastic, and another on its way, with hopefully more to come, a golden age of modelling, or what?  This does look an excellent kit and is not too large so can be displayed in a relatively small space. The rigging will, however, be taxing, to say the least if you want to go the whole hog, but will look good with a representative amount should you blanche at the idea.
Review sample courtesy of
Great review Shar2!
It's nice to more pre-dreads in plastic rather than resin. I just hope that Hobby Boss release a German pre-dread.
Nice review Dave. I have just got this as I fancied something different for a WWI GB
Julien
