Sign in to follow this
Shar2
Miscellaneous Items for IBG Rosomak APC. 1:35
1:35 Master
The IBG Rosomak Polish armoured personnel carrier is a superb kit in its own right. But, naturally, MASTER models have found a way of improving it with the three sets reviewed here.
[GM-35-013] – Although designed for the IBG kit, this single straight aerial set could be used on other vehicles. The set includes the aerial, the aerial spring base and two elements, as MASTER describe them. These elements are attached to the base, and are in fact protective covers for the aerial base if the aerial itself is removed, so you only need to fit one. Suffice to say they are very small and well protected in their foam square within the package.
[GM-35-014] – Another aerial set for the Rosomak, or any other vehicle with a similar aerial set up. This set includes the aerial, bent spring base, the same elements as above, a small sheet of etched brass and a length of fine cord. The aerial is glued to the base unit along with the elements, then, one of the PE tensioning rope rings is bent to shape and slide over the top of the aerial, while another pair of rings are attached to the turret with two brass rivets, for which a 0.5mm hole is required. The cable is run from one turret ring, via a carabineer and cable mounted eye ring, through the aerial ring and back to the other turret ring, with the same set up as the first ensuring it has the right tension.
[GM-35-015] – Smoke grenade launchers. This set is for the Rosomak vehicles with the 30mm turret. It consists of a resin plate, brass launcher tubes, two types of resin covers and five brass rivets. The brass tubes are fitted into the tubes on the resin plate, the choice of cover decided upon and attached. The plate is then fitted to the kit turret and five 0.5mm holes drilled, into which the brass rivets are glued.
Conclusion
Here we have three more very useful and attractive sets. The aerial look great, but are easily bent and care should be taken if displaying near children, particularly at shows, as they are very sharp and could easily hurt someone looking too closely. The smoke launcher set is very nice, but prepare to test your eyes with the rivets. This goes for the cable attachment points on the bent aerials set too.
