Gun Barrels & Pitot Probes. 1:48
1:48 Master
This month’s releases from Master Models include these three sets for 1:48 scale aircraft.  Two of the sets are the more usual replacement barrels for the Hawker Tempest series, and one set for the SR-71 Blackbird that contains the pitot probe.
[AM-48-132] – This set for the SR-71 Blackbird contains a three piece pitot probe, with the two brass parts joined by a resin element. Whether it’s normal to have a spare element is normal in the sets or not, but this set does. Just glue the brass and resin parts together and, having drilled a 0.6mm hole in the nose of the model, glue into position.
[AM-48-133] – Designed to be used with the any early 1:48 Tempest Mk.V they are a simple replacement for the kits barrels, these being with a full jacket. Just drill out a 2.2mm hole where each barrel is to be fitted, then glue into place, ensuring the inner barrel is inserted 1.3mm further into the wing.
[AM-48-134] – This set is designed for any Tempest Mk.II/Mk.V late, Fury or Sea Fury and contains four barrels and a pitot probe. Once the holes have been drilled out to 1.8mm the barrels are inserted so that the outer muzzle is visible just ahead of the leading edge of the wing, while the inner barrel should be 1.3mm further in so that you can just see the muzzle in the hole. The pitot probe requires a 0.8mm hole drilled out before the probe can be glued into position.
Conclusion
Master Models just can’t stop bringing new sets out for the benefit of those who like to have the highest level of detail in their models. It’s great to see older kits still being catered for too.
