Sign in to follow this
Shar2
IJN Pre-Dreadnought Mikasa Gun Set. 1:200
1:200 Master Models
As the number of 1:200 scale warships increases so does the number of sets that Master Models release. This set is for the Merit International IJN Pre-Dreadnought Mikasa, but should also be ok to use on the recently released Hobbyboss kit. They are well up to the standard we’ve come to expect from Master Models.
[200-009] This set is a combination of turned brass and aluminium barrels, the larger items, such as the four 305mm and the fourteen 152mm are aluminium, whereas the twenty 76mm and twelve 47mm are in brass. The 305mm main guns also have brass trunnions, which are inserted into the hole near the rear of the barrel, these then fit into the kit trunnion mounts. All the barrels are so cleanly machined, so it’s quite unusual to find any swarf or imperfections, although there are one or two of the 152mm barrels in this particular set that will need some swarf to be cleaned off before use, fortunately this is only found around the joining pin, so doesn’t affect the look of the barrels.
Conclusion
Even in this large scale, injection moulding cannot always get the look and size of the barrels quite right, and this is where these amazing sets come into their own. Being meal they also have that “weighty” look that is difficult to explain, but you know when you see it.
Hopefully one day they will do a set in 1/700 scale for the recent Hasegawa release of the Mikasa.
