Colin1967 Posted July 4, 2017 Share Posted July 4, 2017 https://drive.google.com/open?id=0B0YTyzb37wqFOXN1T3ZpUEtlblZ2RHhqaTFvQTNQZmRaNlhZ https://drive.google.com/open?id=0B0YTyzb37wqFZnF2QWVQaDk0SkEzTzd5TlBBaHVWLUVTNVNn https://drive.google.com/open?id=0B0YTyzb37wqFWklKWDJGZk5DRklxMmotcjY3ek1fOVpyMmhn This kit has been on my shelf for some time, but, I'd thought you would like to see it, I remember the kit was a challenge and enjoyable, NO jig was employed, other than my eye and luck. Comments welcome. 4 Link to comment Share on other sites More sharing options...
stevehnz Posted July 5, 2017 Share Posted July 5, 2017 I like that, I've one on my eBay watchlist that is soon to be realised , nice to see one made, it looks good the way you've done it, I like your Norwegian Fokker too, nice subjects modelled nicely. Steve. 1 Link to comment Share on other sites More sharing options...
Colin1967 Posted July 5, 2017 Author Share Posted July 5, 2017 1 hour ago, stevehnz said: I like that, I've one on my eBay watchlist that is soon to be realised , nice to see one made, it looks good the way you've done it, I like your Norwegian Fokker too, nice subjects modelled nicely. Steve. Thanks Steve, much appreciated, I like AZUR FRROM kits very much and am now waiting for my 1/72 Northrop Gamma - China to arrive from the big H, Best regards Colin. 2 Link to comment Share on other sites More sharing options...
TonyTiger66 Posted July 5, 2017 Share Posted July 5, 2017 I like the Frrom Azur kits too Colin. You'be made a nice model out of this one I cut the parts off the sprues of one of these just last week. I do that sometimes to force myself to make something. It looks like the wing alignment could be tricky. If you have any tips on a good construction sequence to ensure it lines up, it would be most appreciated. These inter war aircraft are lovely . Hope you can share pictures of the Gamma; another inspired kit release by Frrom Azur. TonyT 1 Link to comment Share on other sites More sharing options...
Colin1967 Posted July 6, 2017 Author Share Posted July 6, 2017 15 hours ago, TonyTiger66 said: I like the Frrom Azur kits too Colin. You'be made a nice model out of this one I cut the parts off the sprues of one of these just last week. I do that sometimes to force myself to make something. It looks like the wing alignment could be tricky. If you have any tips on a good construction sequence to ensure it lines up, it would be most appreciated. These inter war aircraft are lovely . Hope you can share pictures of the Gamma; another inspired kit release by Frrom Azur. TonyT Thank you TonyT for your kind comments, I remember that I was a bit cunning getting the wing alignment right - I didn't use a jig either, I glued the middle wings to the fuselage then after letting them cure I fed the wing struts thru the openings in the wing, I did have to enlarge those holes a bit, next I glued the upper wing to the fuselage struts and then as it dried I attached the wing struts to the upper wing - Be careful here to choose the correct upper wing as one of the upper wings is for another version, I left the assembly to cure for a long time and hey presto and with luck it aligned perfectly, I then added the bottom wing and wheel struts and then the wheels. I brush painted the entire model with Humbrol Metalcote, the decals were a joy to use as well. Hope your build proceeds well TonyT and the above advice helps. Regards Colin. Link to comment Share on other sites More sharing options...
