Hello everybody!
The old ICM kit (repack by MSD). The main problem of the kit, it's the absolutely wrong canopy form. So the canopy and some of the other elements were made by hand.
List of the handmade parts:
- gun barrells and pito tube were turned of steel;
- exhaust tubes were turned as well of copper wire and then painted by lifecolor acrylic;
- restraining strap on the bonnet was turned from aluminium rod as a thin ring. Yes I know, to cut out from aliminium foil is more simple way, but so it's looks better.
There is no historical prototype for camouflage scheme.
Thanks for looking, any comments are welcome.
Edited by maverick_62
She's a beauty mate, I'd definitely go for the ICM kit if I built another I-16 B)
Stew
Small masterpiece
small related to dimension of the model :)
Great Polikarpov
Bets regards Djordje
Very nice result!
J-W
A splendid little Rata,Mosca, Siipiorava or any of the other names this aircraft was called.Well tidy indeed.:clap2::clap2:
With as much detail as some put in to 1/32 builds, that is a great model, mate.
Martin
Hi Maverick,
Lovely I-16.
Would you mind providing more details of how you did the bonnet strap? It looks great (and I have an ICM I-16 in my near future).
Regards,
David
Hello, David!
Bonnet strap in this case, it's simple aluminium ring was made on the lathe. Thickness approx. 0.05mm, width something about 0.8mm and diameter equal bonnet diameter.
With best wishes,
Sergey
That's a real beauty and some fine modelling.  I know how small this aircraft is in 1/72 which makes the paint finish even more impressive.
4 hours ago, maverick_62 said:
Hello, David!
With best wishes,
Sergey
Hi Sergey,
Thanks for the information. I hadn't considered using a metal lathe (although I do have access to my fathers lathe...).
Kind regards,
David
