Spitfires Forever Posted June 13, 2017 Posted June 13, 2017 Hello, I just received an old Hasegawa 1/48 F4U-4 and I have a question regarding the use of the A and B model of this Corsair variant during WWII. I want to build a WWII aircraft but it seems that WWII decals are not as available as the Korean! If at all (although the old Monogram kit did offer WWII decals along with the Korean War markings back in the day, if I remember correctly.) As I understand it from the small amount of info on the net, they didn't start arriving at front line carriers until 1945. Did both the -4a model and cannon equipped 4b both make it onto carriers and into battle? How much mor effective were they in the ACM environment. Any info would be appreciated. Cheers
Troy Smith Posted June 13, 2017 Posted June 13, 2017 (edited) Hi Randy There are decals for WWII F4U-4's, eg http://www.ultracast.ca/products/Limited Stock/AeroMaster/48-Scale/48-254/ The Hase/mania kit has an underserved reputation, I spent some time trying to make the Academy F4U-4 better, and then got a Hase F4U-4, and was rather surprised to find that they apart from the over wide spine/fin and canopy on the Academy kit they are basically the same, and compared to a Tamiya F4U-1, the fuselage is too deep and slab sided, and the wings too low. Anyway, check the above links, there were a lot more -4's used in WW2 than usually thought is the answer, but they are not very exciting schemes, and photos don't seem very common. cheers T PS AFAIK, the -4's were all standard gun wing, the cannon -4B are post war Edited June 13, 2017 by Troy Smith add details 1
Guest Posted June 13, 2017 Posted June 13, 2017 Thanks once again Troy, always there to help. I am glad I didn't buy the kit. I know Hobby Boss has a -4b but that would be too late of a version for me. Would a Tamiya F4U-1D with a Hamilton Standard four bladed prop do the trick, or are there too many additional components that would be difficult to add?
Troy Smith Posted June 13, 2017 Posted June 13, 2017 10 minutes ago, Spitfire addict said: Thanks once again Troy, always there to help. I am glad I didn't buy the kit. I know Hobby Boss has a -4b but that would be too late of a version for me. Would a Tamiya F4U-1D with a Hamilton Standard four bladed prop do the trick, or are there too many additional components that would be difficult to add? no, the entire front end from firewall is different. Hobyboss do an early F4U-4, probably available cheaper in the US from a far east mail order, it has some issues, but overall decent AFAIK, it's late, I can dif out info on the glitches. IIRC, Gear door shape, cowl intake and prop? the -4 are the only HB Corsairs worth the bother BTW, as the -1 are done better by Tamiya, and the F4U-5/AU-1/-7 by Hasegawa
Guest Posted June 13, 2017 Posted June 13, 2017 3 minutes ago, Troy Smith said: no, the entire front end from firewall is different. Hobyboss do an early F4U-4, probably available cheaper in the US from a far east mail order, it has some issues, but overall decent AFAIK, it's late, I can dif out info on the glitches. IIRC, Gear door shape, cowl intake and prop? the -4 are the only HB Corsairs worth the bother BTW, as the -1 are done better by Tamiya, and the F4U-5/AU-1/-7 by Hasegawa Thanks for the info. As we all know there are no perfect kits out there, they all have issues. The only path will be to pick the most accurate kit available and go from there. Glad to know HB makes an early version. I can scrape enough decals out of my stash to get the right markings, then with a little white paint I can get close. Thanks again my friend. Cheers
JWM Posted June 13, 2017 Posted June 13, 2017 (edited) John Glenn's F4U4: I made her once from Matchbox 1/72 kit with Esci decals (was on RFI already) Cheers J-W Edited June 13, 2017 by JWM
72modeler Posted June 14, 2017 Posted June 14, 2017 On 6/12/2017 at 9:52 PM, Troy Smith said: no, the entire front end from firewall is different. Hobyboss do an early F4U-4, probably available cheaper in the US from a far east mail order, it has some issues, but overall decent AFAIK, it's late, I can dif out info on the glitches. IIRC, Gear door shape, cowl intake and prop? the -4 are the only HB Corsairs worth the bother BTW, as the -1 are done better by Tamiya, and the F4U-5/AU-1/-7 by Hasegawa What Troy said plus don't forget that the dash four also had a true floor to the cockpit and the seat was a bucket attached to the armor plate/backrest; the exhausts were also different. It would be nice to have a decent state of the art F4U-4 in 1/72 and 1/48- with some slide molding and/or clever engineering of inserts, both windscreen and armament fits could be easily done to make an F4U-4 and 4B. Like Dusty Springfield said in the song - "'Wishin' and hopin' and dreamin' and prayin'.." Mike 1
Tailspin Turtle Posted June 14, 2017 Posted June 14, 2017 http://tailspintopics.blogspot.com/2014/03/f4u-4-modelers-notes.html 3
72modeler Posted June 14, 2017 Posted June 14, 2017 7 hours ago, Tailspin Turtle said: http://tailspintopics.blogspot.com/2014/03/f4u-4-modelers-notes.html Once again, you da man, Tommy! Thanks for sharing these references...now, all we need is a decent kit! Mike
David H Posted June 21, 2017 Posted June 21, 2017 On 6/12/2017 at 9:19 PM, Troy Smith said: Hi Randy There are decals for WWII F4U-4's, eg http://www.ultracast.ca/products/Limited Stock/AeroMaster/48-Scale/48-254/ The Hase/mania kit has an underserved reputation, I spent some time trying to make the Academy F4U-4 better, and then got a Hase F4U-4, and was rather surprised to find that they apart from the over wide spine/fin and canopy on the Academy kit they are basically the same, and compared to a Tamiya F4U-1, the fuselage is too deep and slab sided, and the wings too low. Anyway, check the above links, there were a lot more -4's used in WW2 than usually thought is the answer, but they are not very exciting schemes, and photos don't seem very common. cheers T PS AFAIK, the -4's were all standard gun wing, the cannon -4B are post war
David H Posted June 21, 2017 Posted June 21, 2017 I have a somewhat different take on the Hasegawa/ Mania kit. I agree that the rear lower fuselage keel may be a bit deep but i think the shapes otherwise are clearly better than the Academy kit. I like to re scribe panel lines, so having to do those over on the Hasegawa is not a deal-breaker for me. I think Hasegawa's treatment of the fabric surfaces is better than HobbyBoss' approach, plus the shape of the "spade" doors on the main gear struts is better. The wheel wells are (typically) shallow and if you're into re-working something like that, knock yourself out. The tyres are truly abysmal but are easily rectified with aftermarket resin. The forward fuselage/cowling is integrated into a single piece (mainly having to do with the -4s somewhat more integrated cowl flaps installation), and a separate cowling would have been nice to have. The myriad of fasteners on the Corsair front fuselage and cowling are missing from the Hasegawa kit which is too bad since they add a lot of visual interest. The Tamiya windscreen actually fits quite nicely onto the Hasegawa fuselage, if you desire to build a plane from the first half of the production run. Lastly, while the -4 Corsairs used by the Marines were admittedly rather boring, there were some very attractive "G-Symbol" Markings from air groups like BOXER, ANTIETAM and LAKE CHAMPLAIN that dont get much play. For some reason, several air groups "didn't get the email" about G-Symbols being replaced by alpha-numeric characters (Borrrre-Inggg!!) In summation, we really don't have a "great" F4U-4 in 48th scale. Any way you cut it, you're in for a fair amount of work. However, i feel the Hasegawa/ Mania kit is the lesser of three (?) evils. david
Troy Smith Posted June 21, 2017 Posted June 21, 2017 (edited) I disagree David the main parts of Academy -4 (APART from the fuselage spine) are the same as Hase/Mania -4... I was pretty surprised when I compared the two kit, given the drubbing the Academy kit gets. If you look at the link you can see the Hase/Acad have the wing too low on fuselage, by nearly 2mm, It's easy enough to trim up, it's not that hard to reshape the fuselage, where I got stuck was doing this makes the belly wrong, as the above mean reworking the centre section, as the belly line is about right. I posted the below here Quote for the wing being too low, look at this and then look at the Acad/Has -4, note the postion of wing to exhaust, and then you can see the wing is too low. this is the Acad this is the Tamiya -1 for comparison, note the extra depth on the straight lower section of the angled firewall panel on Acad above It's not really horrible, but I started out just trying to thin the Academy spine, and then found more problems with the fuselage, again, assuming Tamiya got it right....but if you look at the factory photo this clearly shows the 'egg' shape, well, the bottom of it, and this is the shape of the Tamiya rear cockpit bulkhead if then look at the Acad/hase -4, you can see it's deeper, and the bottom of the 'egg' almost has corners. I just have not had the enthusiasm to do all the comparison photos .... i did bash the Acad fuselage into shape, but then the belly went wrong, and I then put it away for a while. I suspect that fixing the belly will require cutting off the wings and making the centre section parts deeper. This then would require making up a wing spar to see the wing anhedral, and this was the point the bits went into the 'later' box more of my ramblings Quote HB -4 is better than any other 1/48th -4,as it has a fuselage that is basically the same as the Tamiya in depth and shape. This is the best photo I have found of a -4 underside remember the F4U-4 is basically the same to the firewall as an F4U-1, with a new engine added on, plus some belly modifications. Here's a -1 belly I really need to do some pics but if you do tape a tamiya -1 to the Academy -4, note that the Academy is deeper, more slab sided, and the wing roots are about 2 mm lower, I corrected the fuselage, but then that messed up the belly line, I think that the Academy wings sitting too low make the belly too flat. It's hard to explain, and it's not an area commonly visible on photos If you are basically happy with the Hase -4, then taking 2 mm out of the spine of the Acadamy kit will get it to be basically the same. Here's what I mean about the 'egg shape' of the fuselage you can see that the Tamiya rear cockpit bulkhead is this 'egg' shape, try fitting his into the Acad fuselage to see what I mean. What this means is that if you are happy with the Hase/mania, it's not too much work to make the Academy match that by taking out 2mm from the Acad spine. I don't think the wing depth problem screams 'wrong' but I've not seen it mentioned before. The Hobby Boss, for it's faults, is a much better match for the Tamiya fuselage (assuming the Tamiya gets it right) I got the Hobby Boss cheap, but their retail new is too much, and their other versions, apart from the -4, are really not worth the bother. Sorry if this is not the clearest post, it's blinkin' hot at the mo (by English standards) and my brain is melting! But, I certainly agree that a good OOB F4U-4 would be a boon! cheers T Edited June 21, 2017 by Troy Smith 1
warhawk Posted January 29, 2021 Posted January 29, 2021 A rather interesting decal sheet has been released: https://www.scalemates.com/kits/dp-casper-72033-corsair-f4u-4-at-wwii--1328990 1
Geoffrey Sinclair Posted January 29, 2021 Posted January 29, 2021 On 13/06/2017 at 10:16, Spitfires Forever said: F4U-4 and I have a question regarding the use of the A and B model of this Corsair variant during WWII. I want to build a WWII aircraft but it seems that WWII decals are not as available as the Korean! If at all (although the old Monogram kit did offer WWII decals along with the Korean War markings back in the day, if I remember correctly.) As I understand it from the small amount of info on the net, they didn't start arriving at front line carriers until 1945. Did both the -4a model and cannon equipped 4b both make it onto carriers and into battle? The F4U-4 began production in December 1944 and a number saw combat. There were 300 cannon armed F4U-4C built probably by end June 1945 but someone needs to look at the first 1,300 or so F4U-4 individual aircraft cards to see exactly when. The F4U-4B began production in April 1946. The 200 cannon armed F4U-1C were built between August 1944 and January 1945.
EwenS Posted January 30, 2021 Posted January 30, 2021 My notes indicate that the 3 USMC squadrons in MAG14 (VMF-212, 222, 223) traded in their well worn F4U-1 for brand new F4U-4 aircraft while on Samar in the Philippines on 15 May 1945. They then moved to Okinawa at the beginning of June 1945, flying their first CAP operation on 10 June and claiming their first kill there the next day. The USN squadrons began receiving them in Feb 1945 initially as odd aircraft in squadrons working up. The first fully equipped squadron seems to be VBF89 on Antietam. By 4 Aug 1945 there were 5 squadrons with them on board 4 Essex class carriers in the Pacific Fleet which had all seen combat. Data is from official USN squadron aircraft returns accurate to with 7-10 days allowing for compiling the data. Hancock VBF6 (on board from July 1945) Intrepid VF10 & VBF 10 (on board from June 1945) Wasp VBF86 (on board from July 1945) Lexington VBF94 (on board from May 1945) Plus another two carriers in the final stages of working up Antietam VBF89 (possibly the first USN unit to receive them swapping F4U-1 for F4U-4 late Feb/Early March 1945 while still working up in the Atlantic) Boxer VBF93 Plus VBF14, VBF19 (destined for Hornet in Sept), VBF80, VBF84, VBF95 all working up with a mix of F4U-1 & -4 aircraft. Over in the Atlantic VBF3, VBF20, VF-75A & B (destined for the FD Roosevelt), VBF150, VBF152, VBF153 were fully equipped and working up while VF74B & VBF74B (destined for the Midway) had a mix of F4U-1 & -4. It seems units were originally equipped with F4U-1 aircraft and then switched to the new model before embarking in carriers bound for the front line. Each USN squadron would have had approx 36 aircraft. 2 2
