BIG X Posted June 4, 2017 Share Posted June 4, 2017 I have been using the gloss version of this... ...with a broad flat brush for a month or two now - prior to decaling and I've been very happy with the results so far. I just wondered - does anyone use it through an airbrush. If so - does it work just as well and can anyone recommend the matt or satin versions. Advice and opinions as always - gratefully received. Thanks - Steve Link to comment Share on other sites More sharing options...
IanC Posted June 4, 2017 Share Posted June 4, 2017 Hello Steve I've used Humbrol Clear gloss undiluted it in my airbrush and it goes on ok. I have to say though that while it's easier to get a nice uniform finish, I can't seem to get a really high gloss when spraying. I actually find I can get a glossier finish by brushing on several coats. I've not used the matt or satin versions as I use W&N Galeria, which also sprays very well. Ian 1 Link to comment Share on other sites More sharing options...
BIG X Posted June 4, 2017 Author Share Posted June 4, 2017 Hi Ian I have to agree it works brilliant with a brush and maybe it needs a few coats with an airbrush - but I'll need to experiment. I was looking at W&N Galeria and I thought I could get it at Hobbycraft - but the only Galeria stuff they had was in the clearance area and no varnish to boot. Can I ask - what did you use to clean the airbrush with the humbrol - I simply use water when brushing - so assume water / airbrush cleaner for the airbrush? Also - what cleaners are required for the W&N Galeria stuff? Thanks for coming back, Steve Link to comment Share on other sites More sharing options...
IanC Posted June 4, 2017 Share Posted June 4, 2017 (edited) Hi Steve Yes I use water for both the Clear and the W&N stuff. I flush it out quickly and then finish off with Vallejo airbrush cleaner. No problems so far. Btw I got my Galeria from Amazon. Nice big pot which should last ages. Edited June 4, 2017 by IanC 1 Link to comment Share on other sites More sharing options...
BIG X Posted June 4, 2017 Author Share Posted June 4, 2017 58 minutes ago, IanC said: Hi Steve Yes I use water for both the Clear and the W&N stuff. I flush it out quickly and then finish off with Vallejo airbrush cleaner. No problems so far. Btw I got my Galeria from Amazon. Nice big pot which should last ages. Thanks Ian, That would be my preferred method of cleaning too. I have some credit on amazon - so I'll take a look. Thanks a million - Steve Link to comment Share on other sites More sharing options...
BP85 Posted January 12, 2019 Share Posted January 12, 2019 On 04/06/2017 at 21:28, IanC said: Hi Steve Yes I use water for both the Clear and the W&N stuff. I flush it out quickly and then finish off with Vallejo airbrush cleaner. No problems so far. Btw I got my Galeria from Amazon. Nice big pot which should last ages. Hello, sorry for coming to this late but after reading this thread I've just ordered myself a half litre pot of W&N. How many coats and at what pressure do you usually spray it? 1 Link to comment Share on other sites More sharing options...
BIG X Posted February 24, 2019 Author Share Posted February 24, 2019 On 12/01/2019 at 09:10, BP85 said: Hello, sorry for coming to this late but after reading this thread I've just ordered myself a half litre pot of W&N. How many coats and at what pressure do you usually spray it? Sorry for the late reply - I spray a single coat - but quite heavy - until it goes 'shiny' - that sounds crazy but I know I've got it all covered and it does dry to a dead matt in a very short period of time. Pressure wise I spray everything at a very low 15 - which drops to about 8 when you get going. I hope that helps - Steve Link to comment Share on other sites More sharing options...
