ian wallace
Tamiya Porsche Boxster
Hi guys
i have decided to make a replica of a Porsche Boxster I bought brand new back in 2004
It was in lapis blue and I pumped loads of extras
IMG_1296
I found this kit on eBay for ¬£20. So I couldn't resist ūüėé
The main body and bumpers are made in a bright yellow
IMG_4710
The first mod I have had to do is the front bumper
IMG_4711
the grills on this kit are joined together vertically as you can see on the left so I have cut them out to match the grils on my car.
IMG_4712
Finished shell with front and rear bumpers attached and all mold lines removed
IMG_4713
Finished front bumper. All ready for prep work to be sprayed
Edited by ian wallace
Good morning
being a back holiday weekend I hopefully should be able to get most of the body work done in-between the other builds I am doing.
so after my first cup of tea I have cleaned and scrubbed the body work using Zeropaints Key And Clean.
This stuff is very good you can buy it in a kit with two pads and cleaning solution.
so a quick clean and leave to dry ready to be put in the booth to be primed.
As you can see this system will remove all the chemicals that they use to remove the plastic from the moulds but also it gives it a nice key for the primer to hold onto
I will let these dry for an hour or two then I will spray the primer.
I thought I would get some other parts ready also while I have some primer on the go
Hi Ian,
Love this car. I think that it and it's Cayman sibling are my favourite Porsches.
Your preparation work is meticulous. I'm sure that the primer and top coat will adhere well to that.
I shall have to take a look at the Zero Paints 'Key and Clean', as I use their primers and colour coats already.
I only wish I could afford the real thing!
Keep up the great work!
BTW. What's the other white car front?
All the best, Alan.
HI Alan
thank you for your kind words
the other car is a Porsche GT 1/12 scale
its nearly finished, I didn't think to do a build thread on this one, to be fair
this is my first build thread so far, my friend told me its a good idea to put things on hear like this so I can get advice and suggestions from people and learn new things.
and also help other people also
Ok So we are ready to start spraying
For all my cars I use the Zeropaints Grey Filler Primer.
very easy to use and sprays very nice out the gun.
Just apply 2-3 coats, at around 15-40 psi, the first coat I would do a very thin dust coat as this stuff will melt your plastic.
you don't need to thin this stuff, just put it in your cup and spray it on.
Ok so the primer is now on and drying
I will let this dry out for a few hours before I start to polish with miromesh
 Hello Ian,
   Since I rarely finish anything I do not get the body paint stage often so I look forward to following this!
 Randy
18 hours ago, RandyD said:
 Hello Ian,
 Randy
I have loads on my bench also
I'm trying to get things finished off before I start on anything new but some times it gets the better of me:lalala:
1/12 Porsche gt
back to the future cars one and two
studio scale star wars millennium falcon
The black pearl (wooden ship) don't know if this counts as its on plastci
1/16 tiger 1 tank
1.32 phantom
Ian,
Just bought a real one that looks very similar to yours. Wondered about doing what you are doing - so will watch with interest. BTW can a RHD version be built from the kit.
Regards
Nick
So back from a spot of beekeeping and back to the bench
I have started to use these little sanding pads for small models as I find them better to use
I start at the3200 grit and then finish with the 12000
and you should get a shiny thing like this
Now the front of the bonnet (boot) where it meets the bumper is a little shabby so I have used a scribing tool that my best bro told me about, :laugh:
not a great photo but the join is much nicer, I had to rub down one part as you can see the yellow showing through so I will touch that up later, when ive got some more primer in my gun
6 minutes ago, NickD said:
Ian,
Regards
Nick
Hi Nick
unfortunately not, well not as I know, as always Tamiya always puts the wheel on the wrong side, that said the kit is a very good kit
it has options
roof up
roof down
side window up or down
hard top
speedster option that sits on top of the folded down roof
'Tis a pity and why would I need to? but it is tempting...
Perhaps should finish some of my other things first though.
Thanks for getting back to me.
Nick
I guess as people are watching I should do this right and touch up the bonnet
I Was shooting some more primer for the 1/12 Porsche GT any who,
will let these fully dry over night and on with the colour tomorrow morning
Hi Ian,
That's been my experience with the zero primers. I also found this out with the Halford's primer paints as well. Dust on a protective coat (or two), let it harden for 15-20 minutes. Then a couple more coats after that, all quite fine.
I have found on the few occasions that I have used ZP primer, that a fine sand was normally enough. I have used Tamiya lapping film, which seems to bring up a shine like yours on the primer coat.
I think though, that I will look up those sanding pads. Did you get them from Hiro Boy?
Fabulous finish on the primer, by the way.
I found that the most difficult part I had was with the clear coat. I used the ZP 1K clear-coat. I don't trust myself with the 2K stuff. I don't have a respirator mask. I ought to get one anyway! I think that I need more practise.
I shall watch this thread with interest.
All the best, Alan.
38 minutes ago, Alan R said:
Hi Ian,
All the best, Alan.
Hi Alan
all the paints I have bought from Hiro Boy
here is a link for the pads
http://www.hiroboy.com/Micro_Finishing_Cloth_Abrasive_Pads__6_pad_Starter_Kit--product--10695.html
Hi Ian,
Thanks for the info. I'll have to get some.
That will have to be the next order. I just ordered a Fujimi FIAT 500 Abarth. The wife won't be too pleased if I order anything more this month! :(
All the best, Alan.
1 minute ago, Alan R said:
Hi Ian,
All the best, Alan.
Any time. fortunately I don't have that problem got fid of mine, unfortunately she took my son with her, ######
My kids are both grown up. Just paying to get them through uni...
P.S. I would have 'liked' this, but like isn't the right thing.
I hope you get to see your son.
Cheers, Alan.
Edited by Alan R
Cheers, Alan.
Yeah I see him not as much as we both might like but playing the long game. He's only 5 bless him so when he's older he can have his say
I
Hi Ian,
Nice choice of kit. I love beating the Boxsters on track!
What brand are the sanding pads? I'll have to get some.
Good morning all,
first call of today is putting the kettle on and then the compressor or should that have been the other way around?
My Porsche I bought in 2004 was in Lapis Blue, I looked at all the colours in the range, and I just loved this colour.
thankfully the guys as Zeropaints make this colour (HAPPY DAYS)
So there we have it guys one shiny car and a pot of Lapis Blue :laugh:
First coat is just a very fine dust coat as this stuff can melt your plastic also,
the idea is very fine light coats, you are not looking for a glossy finish, as this will dry matt.
Second Coat, so you can see you are just building up the depth of the colour.
This is the last coat which I will leave to dry for a good few hours or might leave until to night or tomorrow to spray the clear
