nimrod54 Posted March 30, 2017 Share Posted March 30, 2017 With my 1/144 Rapide build nearing completion and there being some time to the end of this GB, I decided to make a start on a third build. I thought that it would be good to try and add another aircraft type and so I have selected this Matchbox HS125, which I will probably finish in RAF colours. Fellow Britmodeller @jean will be glad that I have gone for a subject in a larger scale and I hope that this will allay any concerns he may have about my sanity. Finally, if it is looking like there is still time, I may revert back to type and build this 1/144 Heron 1 from Welsh Models. 4 Link to comment Share on other sites More sharing options...
DAG058 Posted March 30, 2017 Share Posted March 30, 2017 Excellent Nimrod!! Really looking forward to this one. I like the sound of the RAF colours too. Your plans for a third build also look very good, fingers crossed you go for it. Link to comment Share on other sites More sharing options...
CliffB Posted March 31, 2017 Share Posted March 31, 2017 A nice with the 125, John. I was thinking of building one too (albeit in 1/200), but I think I will save it now for next year's Hawker GB Cliff 2 Link to comment Share on other sites More sharing options...
Grandboof Posted April 2, 2017 Share Posted April 2, 2017 Will be watching this Martin H 1 Link to comment Share on other sites More sharing options...
jean Posted April 4, 2017 Share Posted April 4, 2017 On 3/30/2017 at 2:34 PM, nimrod54 said: With my 1/144 Rapide build nearing completion and there being some time to the end of this GB, I decided to make a start on a third build. I thought that it would be good to try and add another aircraft type and so I have selected this Matchbox HS125, which I will probably finish in RAF colours. Fellow Britmodeller @jean will be glad that I have gone for a subject in a larger scale and I hope that this will allay any concerns he may have about my sanity. Hi John, You just don't know how relieved I feel to see that rigging a 1/144 biplane was only a temporary lapse of reason.... It happens to the best of us, I was told. But be careful because you have been known to have a history of (very) small scale OCD symptoms... As far as the present build is concerned, I wholeheartedly approve, but trust Matchbox to chose the right colors for a white plane... Buy a gallon of white paint! I will be following this build! And don't forget to detail the galley stove and the silver cutlery. Have fun JR 1 Link to comment Share on other sites More sharing options...
nimrod54 Posted April 4, 2017 Author Share Posted April 4, 2017 15 minutes ago, jean said: As far as the present build is concerned, I wholeheartedly approve, but trust Matchbox to chose the right colors for a white plane... Buy a gallon of white paint! I will be following this build! And don't forget to detail the galley stove and the silver cutlery. Hi Jean, I have just placed my order for 25L of Gloss Appliance White, I am hoping that this will be sufficient to fill the trench-like panel lines and cover the multi-coloured parts at the same time. Funny that you should mention the galley stove, I had considered leaving the door open which would mean adding some detail in that area, not sure if my scratch building skills would be up to it though. If I wasn't building it, this one could be worth following. 1 Link to comment Share on other sites More sharing options...
nimrod54 Posted April 5, 2017 Author Share Posted April 5, 2017 I made a start on cleaning up some of the main parts and also did a little bit of assembly and then had a trial fit of parts. The clean up didn't take long, just some bits of flash from a few windows and another couple of apertures in the fuselage. The initial fit was very good and I don't expect too many dramas when I come to glue things together permanently, I think my main problem will be dealing with the 'San Andreas Fault' panel lines. 5 Link to comment Share on other sites More sharing options...
Col. Posted April 13, 2017 Share Posted April 13, 2017 Lovely choice of subject John. As for the wild plastic colours, best way I found was to undercoat with a medium then light grey before going to white top coat. A bit of extra work but less so than trying to get a solid white from multiple coats. 1 Link to comment Share on other sites More sharing options...
nimrod54 Posted April 14, 2017 Author Share Posted April 14, 2017 I have spent the past day or so working on the crew figures that are included in this kit. It's not something that I normally include on my builds, but I thought that this could be the type of simple task which may give my modelling the kick-start that I seem to be looking for at the moment. This afternoon I glued the cockpit and crew assembly into one half of the fuselage, added some weight in the gaps around this, and then closed up the fuselage. 6 Link to comment Share on other sites More sharing options...
Ozzy Posted April 14, 2017 Share Posted April 14, 2017 Those figures look fantastic Nimrod, 1 Link to comment Share on other sites More sharing options...
nimrod54 Posted April 15, 2017 Author Share Posted April 15, 2017 22 hours ago, Ozzy said: Those figures look fantastic Nimrod, Cheers Ozzy. Like I said, it's not something that I normally do but I am quite pleased with the result this time around. I checked over the fuselage and I had to fill in a few sink marks on the top surface of the fuse, two around the spine, two just behind the cockpit and two more on the nose. The filler was also out to blend in the nose cone. I added some thin plastic to the nose wheel bay to avoid a difficult clean up job and the only other work required was a sand along the join. I will recheck all of these areas once I get some primer on, Following this it was time to 'locate and cement' the wings and tailplane in position, the fit isn't too bad with just a small amount of filler and a light sand needed to complete these. Two of the sink marks that required filling. Nose cone filled and blended. Thin plastic card added to the nose wheel bay Wings and tail assembly completed. Maybe just a small amount of filler and a sand required to tidy things up. Looks as though I may have some work to do when I add the cockpit glazing though, as there is a gap that will have to be filled. My initial thoughts are to fix this at the lower edge first, then fill the gap with some plastic strip and fair everything in. 4 Link to comment Share on other sites More sharing options...
nimrod54 Posted April 17, 2017 Author Share Posted April 17, 2017 This has now had a first coat of grey primer and Needs some further work on the top fuselage seam and the canopy before I start the man painting 6 Link to comment Share on other sites More sharing options...
Max Headroom Posted April 17, 2017 Share Posted April 17, 2017 Scrubs up well. I wonder why Revell never reissued it? Trevor 2 Link to comment Share on other sites More sharing options...
nimrod54 Posted April 18, 2017 Author Share Posted April 18, 2017 16 hours ago, Max Headroom said: Scrubs up well. I wonder why Revell never reissued it? Trevor It goes together really well Trevor. Sanding the top surfaces of the wing to thin the trailing edges has reduced the depth of those panel lines, and I am hoping that some white primer and a top coat will help with those on the fuselage. Like you I am left wondering why this hasn't been reissued. Link to comment Share on other sites More sharing options...
John_W Posted April 19, 2017 Share Posted April 19, 2017 I built this aged around 12. I lost count of how many coats of brush painted white it took to kill the red. 1 Link to comment Share on other sites More sharing options...
jean Posted April 19, 2017 Share Posted April 19, 2017 There should be a law about selling kits sporting colored plastic fit to give nightmares to the least strong among us! But the elegance of the plane comes out with a simple coat of primer. That's going to be real nice. So what are you going to do with all the gloss white appliance paint that will be left over? Great show John. JR 1 Link to comment Share on other sites More sharing options...
nimrod54 Posted April 19, 2017 Author Share Posted April 19, 2017 1 hour ago, jean said: That's going to be real nice. So what are you going to do with all the gloss white appliance paint that will be left over? Not sure Jean, I could always re-spray the kitchen appliances. I don't think that Caron would be too happy though, she has got use to the stainless look Link to comment Share on other sites More sharing options...
nimrod54 Posted April 22, 2017 Author Share Posted April 22, 2017 OK chaps, I have hit a bit of a snag with this one, and I am hoping that someone may have an easy fix to the problem. The plan was to finish this as per the box version in white using Halfords GAW as the topcoat. Taking on board the sound advice from @Col. about painting multi-colour kits I applied some Halfords grey plastic primer to the kit. Several filling and sanding sessions have taken place since then with a light primer coat reapplied to these areas after each session. In preparation for a final check of the joins before starting to apply the topcoats, I decided that I should go over the grey with some white primer and this is the result. As you can see the red colour of the wing has come through the primer giving it a pink cast, it is particularly bad on the underside where a recent sanding session has taken place, but the doors had no sanding on this occasion and look almost as bad. My initial thought was that this was due to me using ordinary white primer and that the solvent from this had permeated the grey, reacting with the plastic, so I re-primed these areas with a coat of white plastic primer to see if it would seal this, but it is still pulling the red colour through. Looking back at the photos of the model in grey primer I think that there is a slight pink tinge to that colour too, making me more convinced that it is a paint solvent v plastic problem, but that could be me looking for something that isn't there. I was wondering if a light sanding to smooth the surface off, then sealing over this with Klear would help to resolve the issue. I could then go over that with some acrylic gloss. Any advice would be most welcome 1 Link to comment Share on other sites More sharing options...
dude_gan_ainm Posted April 22, 2017 Share Posted April 22, 2017 Try black primer.The red plastic would seep through the lighter paints over time. Jimbob.. 1 Link to comment Share on other sites More sharing options...
nimrod54 Posted April 23, 2017 Author Share Posted April 23, 2017 17 hours ago, dude_gan_ainm said: Try black primer.The red plastic would seep through the lighter paints over time. Jimbob.. Thanks Jimbob, the black primer sounds like a good plan to me. Link to comment Share on other sites More sharing options...
nimrod54 Posted April 24, 2017 Author Share Posted April 24, 2017 Jimbob's black primer tip worked a treat, my choice for this was Humbrol Acrylic Matt Black. This was then covered with a couple of coats of Halfords White Plastic Primer and then some Gloss Appliance White. I will now leave that a few days to harden up. Cheers @dude_gan_ainm, that has been filed away for future use. 8 Link to comment Share on other sites More sharing options...
dude_gan_ainm Posted April 24, 2017 Share Posted April 24, 2017 No problem Nimrod.I've got a Matchbox 125 in the stash & that was my plan after getting the tip from a more experienced modeller than myself who no doubt experienced the bright plastic colour seeping through the paint through the years.Looking good now your back on track. Jimbob. .. Link to comment Share on other sites More sharing options...
Mr B Posted April 25, 2017 Share Posted April 25, 2017 Both are lovely choices ........great work on the hs 125 crew rgds 1 Link to comment Share on other sites More sharing options...
Mr B Posted April 25, 2017 Share Posted April 25, 2017 Both are lovely choices ........great work on the hs 125 crew rgds Link to comment Share on other sites More sharing options...
jean Posted April 27, 2017 Share Posted April 27, 2017 Hi John, Your model definitely looks sleek and virginal, a rather rare state nowadays. So the final product can only be special. Well done! JR 1 Link to comment Share on other sites More sharing options...
