Arniec Posted April 5, 2017 Share Posted April 5, 2017 Great start Muzz. I like the idea with the engines. I might borrow that and take it a little bit further, by removing the middle part so that I don't need to much weight in the nose to keep it's nose wheel on the ground. I am also have to look if it is possible to sweep the wings to save some room on the shelf. Cheers, 1 Link to comment Share on other sites More sharing options...
Muzz Posted April 5, 2017 Author Share Posted April 5, 2017 12 hours ago, Arniec said: Great start Muzz. I like the idea with the engines. I might borrow that and take it a little bit further, by removing the middle part so that I don't need to much weight in the nose to keep it's nose wheel on the ground. I am also have to look if it is possible to sweep the wings to save some room on the shelf. Cheers, Thanks, my plan is to leave out the middle section too! Definitely possible to sweep the wings back, in fact I'd say the kits been designed to allow out but for some reason the miss the option out in the instructions. Murray 1 Link to comment Share on other sites More sharing options...
Muzz Posted April 7, 2017 Author Share Posted April 7, 2017 Wheel bays built up, painted and wash applied. 4 Link to comment Share on other sites More sharing options...
Muzz Posted April 7, 2017 Author Share Posted April 7, 2017 Wheel bays fitted into the lower main fuselage, the front and rear sections of the lower fuselage have also been joined together. I've also added the cradle for the PaveTack pod, I didn't bother painting the weapons bay as it won't be seen. 7 Link to comment Share on other sites More sharing options...
Hewy Posted April 7, 2017 Share Posted April 7, 2017 Very nice murray, i like the wash, Glynn 1 Link to comment Share on other sites More sharing options...
mirageiv Posted April 7, 2017 Share Posted April 7, 2017 Lovely work Muzz, looks to be another great model from you! David 1 Link to comment Share on other sites More sharing options...
trickyrich Posted April 7, 2017 Share Posted April 7, 2017 That looks great! I'm actually leaving the weapons bay out of mine as you just don't see anything, I've just added sprue for some strength. 1 Link to comment Share on other sites More sharing options...
vesthepes Posted April 8, 2017 Share Posted April 8, 2017 Very nice. Great job with the wash, looks very convincing! 1 Link to comment Share on other sites More sharing options...
Muzz Posted April 9, 2017 Author Share Posted April 9, 2017 Ok folks, started to work on the vac form canopy, building up the edges of the cockpit edges with scrap plastic to help with fit and limit the amount of putty required. Having never used a vac form canopy before looking for advice on what adhesive to use, reluctant to use CA as it may fog the plastic but I'm thinking PVA might not give me the strength required to hold everything in place. 2 Link to comment Share on other sites More sharing options...
Hewy Posted April 9, 2017 Share Posted April 9, 2017 Muzz could you split the screen down the middle and widen it with a strip of card stock,or would it make the frame far to wide, I've got one of those canopys on its way from aus, but i cant see all around yours, your the guinea pig for me you see 1 Link to comment Share on other sites More sharing options...
Muzz Posted April 9, 2017 Author Share Posted April 9, 2017 Hewy, the canopy is wide enough and also flexible enough to make any adjustments. The sil around the front windscreen area is quite deep so you have to build it up so the canopy sits flush with the fuselage. I'm planning on getting it fixed into position before adding the cockpit tub as I think this will make things a lot easier. 1 Link to comment Share on other sites More sharing options...
gingerbob Posted April 10, 2017 Share Posted April 10, 2017 18 hours ago, Muzz said: I'm planning on getting it fixed into position before adding the cockpit tub as I think this will make things a lot easier. That's a good idea- allows you to get to both sides, etc. I don't think I'd actually attach the clear, but have the "landing" for it ready. One thing that might be wise is to coat the clear with "Future" (whatever name)- that apparently protects it from glue fumes, etc. bob 2 Link to comment Share on other sites More sharing options...
Muzz Posted April 10, 2017 Author Share Posted April 10, 2017 2 hours ago, gingerbob said: That's a good idea- allows you to get to both sides, etc. I don't think I'd actually attach the clear, but have the "landing" for it ready. One thing that might be wise is to coat the clear with "Future" (whatever name)- that apparently protects it from glue fumes, etc. bob That's my thinking Bob, as I didn't want any unpainted plastic or putty showing through on the inside. I like you're idea about dipping the canopy, I'll crack on with that tonight. Murray 1 Link to comment Share on other sites More sharing options...
Shaun Posted April 11, 2017 Share Posted April 11, 2017 Looking good, following your canopy correction with interest... 1 Link to comment Share on other sites More sharing options...
Muzz Posted April 12, 2017 Author Share Posted April 12, 2017 Making more progress with the canopy, it's been dipped in Klear and allowed to dry. I've added some more plastic to the cockpit sil to give more surfaces for the clear plastic to bond with. 2 Link to comment Share on other sites More sharing options...
gingerbob Posted April 12, 2017 Share Posted April 12, 2017 How did you trim your clear part? I did a rough cut on the separate clamshells this morning, and it was much more "tough" than I expected. Link to comment Share on other sites More sharing options...
Muzz Posted April 12, 2017 Author Share Posted April 12, 2017 4 minutes ago, gingerbob said: How did you trim your clear part? I did a rough cut on the separate clamshells this morning, and it was much more "tough" than I expected. I used a pair of stainless steel scissors to cut the majority of the waste plastic off then used a new scalpel blade to cut around the outline and clean up the edges. 1 Link to comment Share on other sites More sharing options...
Hewy Posted April 12, 2017 Share Posted April 12, 2017 Muzz good work may i ask what your choice of glue will be, Glynn 1 Link to comment Share on other sites More sharing options...
Muzz Posted April 12, 2017 Author Share Posted April 12, 2017 1 hour ago, Hewy said: Muzz good work may i ask what your choice of glue will be, Glynn Hi Glynn I used MEK to attach the canopy and then once dried I used CA sparingly around the outside to reinforce the join. It seems to have worked well. 1 Link to comment Share on other sites More sharing options...
Muzz Posted April 12, 2017 Author Share Posted April 12, 2017 Canopy attached as described above using MEK and CA. I sealed a few small gaps with thin strops of plastic and then went around the edges with Mr Surfacer. 3 Link to comment Share on other sites More sharing options...
gingerbob Posted April 12, 2017 Share Posted April 12, 2017 Wow, I'm surprised that it didn't just shrivel up- MEK is pretty hot solvent! Link to comment Share on other sites More sharing options...
Muzz Posted April 12, 2017 Author Share Posted April 12, 2017 42 minutes ago, gingerbob said: Wow, I'm surprised that it didn't just shrivel up- MEK is pretty hot solvent! I tested it on a bit of the scrap clear plastic first! 1 Link to comment Share on other sites More sharing options...
trickyrich Posted April 12, 2017 Share Posted April 12, 2017 nice work Muzz with the canopy, those vacform ones can be a bit of a pain at times to fit and get a nice join afterwards. I use the same method to cut them out as well, plus those nail file cards are really good as well to help shape and smooth the edges as well. Link to comment Share on other sites More sharing options...
Muzz Posted April 13, 2017 Author Share Posted April 13, 2017 Cockpit ready for fitting, canopy will be closed so not going to town on the detail. 2 Link to comment Share on other sites More sharing options...
trickyrich Posted April 13, 2017 Share Posted April 13, 2017 That cockpit looks really nice, there's some nice work there, well done!!! 1 Link to comment Share on other sites More sharing options...
