"well,Its like a tugboat with wings"
Hi Eveybody!
This is My first Aircraft build on Britmodeller,a conversion of the venerable Revell 1/48 PBY Catalina into a Super Catalina that appeared in the 1989 Steven Spielberg Movie 'Always'.
You must remember the opening scene:-
I'll be adding some aftermarket to this build,namely the Belcher Bits replacement tail,Eduard Window Masks,Eduard Brassin wheels,Quickboost 48 554 resin engines,SAC white metal undercarriage set and Draw Decals set:-
The Super Catalina variant is re-engined from 1,200 hp P&W R1830 Twin Wasps to 1700 hp Wright R-2600 Twin Cyclones,I am taking care of these with the Quickboost set, and using a donor kit for the cowlings, in the shape of an Italeri 2650 B25 Mitchell kit (Accurate Minutures Moulds):-
Other changes required will be remove the front gun turret,modify the nose shape,scracthbuild some 'speakers?' for each side of the nose and enlarge the rudder.
I have already made a start, and will post a progress report soon.
Keep Sticking!               Cheers,  Pete
Incidently, since you're going to all this effort the real PBY / Catalina has a waisted rear fuselage at the base of the fin which the kit does not capture.
I thought you may wish to know about that in advance to address it whilst doing everything else! Belcher Bits makes a resin correction but since you need to extend the fin anyway it's probably not the way to go in this instance.
3 hours ago, SovereignHobbies said:
This is great! I love that film. Are there decals for Tanker 57 and 59 available too? (The A/B-26 Invaders)
Draw decals has tanker 59 decals available as well.
Not many users of those old A-26's but they were a great sight to see coming in to drop on the fire ahead of you...
foresterab
Hi Evertbody!
Thanks for the replies to the posts,as Foresterstab says,there are Draw Decals available for the A26 Invader,I have some tucked into the box of a Monogram kit in the stash for a future project.
Sovereign Hobbies,thanks for the info on the tail shape,I was aware of it and got the Belcher Bits replacement tail which addresses the problem,seems to be a standard fix for the kit.
I was also made aware there is an issue with the size and position of the blisters (wrong cross-section and too large and the height on the fuselage is too high),but I won't be addressing that on this build.
I was going the post some progress photos but Photobucket does not appear to be working at the moment,will try again later.
Many thanks for the interest in the project!
Well,Photobucket seems to be behaving It's self now,so some progress:-
Tailpiece and rudder pinned to replacement fuselage end with brass pins and epoxy:-
Top of tail cut off and new profile built up with plastic card:-
Then built up with filler and MORE plastic card (Ooops!,faulty ruler,cold weather!¬:wink: shown against original kit tail for comparison:-
Wings strengthened with brass box section:-
White metal undercarriage parts epoxied together using whell wells as jig:-
Nose marked out for turret fairing removal and plastic card ribs attatched:-
Front of original nacelles cut off,Mitchell firewalls prepared and parts from Mitchell kit glued to wings:-
Started fill,sand,fill,sand etc........ getting there! :-
A little weight added to fuselage!! (Catalina = Tail-sitter, Catailna + solid resin tail = !!!!!!!!!!) Approx. 200g!  Hence the metal U/C.
More soon!
Keep Sticking!
Cheers,  Pete
Will be interested in seeing how this turns out.
I've yet to see a PBY tanker in action although the North West Territories still has a couple on strength if I recall.   Just had a co-worker retire after 40 years of fire duties and he told me the PBY was still his favorite tanker to see overhead.
Looking good so far,
foresterab
Great start to an interesting project! Looking forward to how this turns out.
That does look a lot of weight... but I can't talk as I did he same to my Lib and as you say you are using a resin tail, and they are a bit hefty compared to the normal plastic.
Good luck
Rob
  • 3 weeks later...
Hi Everybody!
A quick update on the progress so far:-
Air intakes cut from original Revell nacelles,trimmed and glued in position (some basic brass exhausts fitted as well:-
Cockpit and rear section interior done and fuselage closed up:-
Popped the wings on loose for a quick 'Look-See':D :-
'Re-Tasked' the kit cockpit-top radome the give a basic guide for the 'rounded off pointy bit' on the nose:-
Took pics of the fuselage panel detail before I get the angle grinder :o out! :-
First fill-sand session:-
.....And guide primed,much more 'Fiil,Sand Prime' to go :(:rain:
It's a bit like 'Rose with the turned up Nose' :guitar: at the minute,but I'll get it licked into shape!
More in the not too distant.........
Keep Sticking!!
Cheers,  Pete
  • 3 weeks later...
Hi There!
Yes, I'm still here!!
Just been buried under a pile of dust, so not to much to show in the meantime :tired: ,  I've just about got the shape of the nose finalised,hoping to re-scribe tomorrow and get on with priming up properly! :-
Used some Vallejo Plastic Putty around the intake fairings, I've heard some mixed reports about this but found it works really well. Apparently it does not like acrylic primers,I use alclad grey filler primer and had no problems, also it is said to be not good for large gaps and building up in layers and does not sand cleanly,but I think if You use it for small seam gaps etc. it works well,it has a very fine (less than 1mm) nozzle,and can be smoothed while still wet with a damp cotton bud,leaving it ready to paint.:-
Wing landing light lenses fitted over recessed 'Little Cars' lenses, ready to clean up and polish:-
More soon, not back at work till Saturday!!!:yahoo:
Stay Tuned, and......
Keep Sticking!!       Cheers,  Pete
Great movie. Great work. I'll stay tuned for sure.
I once saw a french Canadair filling his tanks ... on something better named a pond than a lake. I just could say Wow. These flying firemen are incredible (mostly ex French naval aviation pilots, I think).
Edited by PattheCat
