AndrewE 1,700 Posted March 11, 2017 Share Posted March 11, 2017 I dug this out from the stash this morning, been meaning to build a few float planes for SPLASH SIG and this is a great excuse to build one. I shall be using a st of Max decals and finishing it as a float plane operated by the RAAF in Antarctica in 1962. 5 Link to post Share on other sites
DAG058 3,801 Posted March 11, 2017 Share Posted March 11, 2017 Nice choice Andrew. Good luck with the build. 1 Link to post Share on other sites
Basilisk 3,379 Posted March 12, 2017 Share Posted March 12, 2017 Nice to see a Beaver in this GB. Cheers, Peter 2 Link to post Share on other sites
Grandboof 1,687 Posted March 14, 2017 Share Posted March 14, 2017 Nice choice Martin H 1 Link to post Share on other sites
CliffB 8,908 Posted March 14, 2017 Share Posted March 14, 2017 A Beaver on floats Cliff 2 Link to post Share on other sites
TEMPESTMK5 8,209 Posted March 15, 2017 Share Posted March 15, 2017 Good afternoon Andrew Very nice choice I will follow your build .. Patrice 1 Link to post Share on other sites
TonyTiger66 5,471 Posted March 15, 2017 Share Posted March 15, 2017 I would like to follow this thread Andrew . I have the same set of decals, but have no kit. Both the Hobbycraft and old Airfix one are hard to get hold of at a reasonable price here in Australia. I'm not sure which one to get, so I'm interested to see how your Hobbycraft goes together. I love polar subjects, great choice of scheme Best regards TonyT 1 Link to post Share on other sites
AndrewE 1,700 Posted March 16, 2017 Author Share Posted March 16, 2017 This is progressing nicely so far. The clear plastic fuselage takes some getting used to, not many builds require the first task to be masking but at least the tedious job that is out of the way now. Masking required inside and out (remember to remove the inside before buttoning up the fuselage!) I am not worrying too much about the interior as no doors will be open so nothing will be too visible. I shall add some detail to the floats in the form of inspection hatches and pulleys. Apart from the fuselage doors there is very little in the way of panel lines on the kit. I have rescribed the doors as the outline would probably have disappeared under a couple of coats of paint. I may do some extra panel lines on the wings but other than that I shall leave it as it comes. 4 Link to post Share on other sites
TEMPESTMK5 8,209 Posted March 17, 2017 Share Posted March 17, 2017 Good morning Andrew Very nice start , I am considering building one myself .. Best regards Patrice 1 Link to post Share on other sites
Paul J 9,157 Posted March 17, 2017 Share Posted March 17, 2017 GOOOD Choice. Despite it being a basic kit and has hints of Airfix in one or two areas. BUT watch out regarding the location points for the front float struts!!!!! The locations are TOO HIGH> You should drill the holes lower down practically on the bottom edge corner of the fuselage but in line with the wrong holes. Check all the many images on line and especially the highly recommended website dhc-2.com Whose markings will it wear? 2 Link to post Share on other sites
AndrewE 1,700 Posted March 19, 2017 Author Share Posted March 19, 2017 On 17/03/2017 at 8:32 AM, Paul J said: GOOOD Choice. Despite it being a basic kit and has hints of Airfix in one or two areas. BUT watch out regarding the location points for the front float struts!!!!! The locations are TOO HIGH> You should drill the holes lower down practically on the bottom edge corner of the fuselage but in line with the wrong holes. Check all the many images on line and especially the highly recommended website dhc-2.com Whose markings will it wear? Thanks for the warning but on looking closely at the fuselage there are no attachment holes for the floats, maybe I have a fuselage for the wheeled Beaver instead. I tried dry fitting the float struts and ran into problems straight away. Firstly the rear set have the lower attachment points on the float set too far apart and the rear most strut is not long enough as photos show it attaching to the fuselage just below the rear corner of the main door. The second problem is the front struts do not seem to fit properly either, and the carpet monster has claimed a set this morning anyway so it looks like I shall be making replacement ones all round. I have added some detail to the floats from plastic sheet and then sanded down so hopefully when painted they are only just proud of the surface. The inter float struts were attached but after finding a plan on the internet they seem to be a scale 12 inches too far apart so this has been corrected. On the fuselage I have added the antenna housing? on top just to the rear of the wing. This was made from bits from the spares box and sanded to shape. Also added is what I presume is an external fuel tank below the fuselage. This tank appears in all of the photos of A95-205 that I can find and I have used a spare slipper tank from a Spitfire suitably narrowed by removing about a third of its width from the middle. This looks to be approximately the right shape and size. 5 Link to post Share on other sites
Paul J 9,157 Posted March 19, 2017 Share Posted March 19, 2017 The forward float attachment points are just visible on the inside fuselage halves. You can just make them out in your top photo . They are just below the forward doors as little circles. But it looks like you are getting along swimmingly so far. 1 Link to post Share on other sites
AndrewE 1,700 Posted March 19, 2017 Author Share Posted March 19, 2017 39 minutes ago, Paul J said: The forward float attachment points are just visible on the inside fuselage halves. You can just make them out in your top photo . They are just below the forward doors as little circles. But it looks like you are getting along swimmingly so far. Well I thought I was getting on OK as well but on closer inspection of photos I realised that the fuel tank should be offset to the left presumably so that it did not interfere with the exhaust which comes off the engine on the right. Currently I have removed the tank and am making good again before re attaching. I think I have all of the attachment points for the float struts now worked out. Once I get the engine and fuel tank on I shall put it into a jig to cut and position new struts. 1 Link to post Share on other sites
Mr B 2,383 Posted March 19, 2017 Share Posted March 19, 2017 Nice choice will be following this rgds 1 Link to post Share on other sites
DAG058 3,801 Posted March 20, 2017 Share Posted March 20, 2017 This looks to be coming together nicely Andrew. Good spot on the fuel tank, sounds like you've managed to sort it. 1 Link to post Share on other sites
MickE 713 Posted March 23, 2017 Share Posted March 23, 2017 Nice work it is looking good. Mick 1 Link to post Share on other sites
Grandboof 1,687 Posted March 26, 2017 Share Posted March 26, 2017 Great work so far Martin H 1 Link to post Share on other sites
AndrewE 1,700 Posted April 4, 2017 Author Share Posted April 4, 2017 Time for a big update as things have progressed nicely over the last couple of weeks. Firstly I have rectified the external fuel tank by shortening it somewhat and adding the plumbing to the front end. I have also added the covers to the small fuselage windows, these were made from slices of small bombs from the spares box. I think the windows themselves were actually tilted downwards but I have left them as they are. The next job was to make a jig so that I could make the new struts for the floats. Blue tack is actually much more sticky than you think and the rear strut between the floats was a casualty of this method on two occasions but it worked alright in the end. And the result with some more details added in the form of pulleys for the control lines to the rudders. Next the wings were added. And all ready for painting. Mixed up an orange from Tamiya Orange darkened with liberal amounts of red. The floats were sprayed with Alclad Airframe Aluminium. Now putting on a few coats of Johnsons Klear before the decals. This picture was taken after the first coat of Klear. 12 Link to post Share on other sites
TEMPESTMK5 8,209 Posted April 6, 2017 Share Posted April 6, 2017 Good afternoon Andrew so far Patrice 2 Link to post Share on other sites
jean 4,559 Posted April 9, 2017 Share Posted April 9, 2017 First Beaver I have seen being built. Impressive so far! JR 2 Link to post Share on other sites
TonyTiger66 5,471 Posted April 9, 2017 Share Posted April 9, 2017 Great work on the floats, tank and additional details. Your colour looks spot on. TonyT 1 Link to post Share on other sites
AndrewE 1,700 Posted April 14, 2017 Author Share Posted April 14, 2017 Finished this off earlier in the week and just taken some pictures for the gallery. The attachment of the floats to the fuselage went OK and everything is reasonably squared up so I guess the scratch built struts worked out OK in the end. Research can be as frustrating as it is rewarding sometimes and although it helped sort out the details of the belly fuel tank it only provided tantalising clues as to how the rear rigging was routed through/around the tank. In the end I have omitted these two rigging wires altogether. I made a change to the decal s as provided by Max Decals as research clearly shows that there were no roundels on the wing but instead the ARNE lettering was present (top and bottom). The decals only provided enough lettering for the top so spare letters were sourced from the spares box. The biggest disappointment was the presence of some plastic swarf inside the cockpit which has stubbornly remained attached to the inside of the windscreen despite shaking/tapping. 13 Link to post Share on other sites
Gorby 6,181 Posted April 14, 2017 Share Posted April 14, 2017 Beautiful model! 1 Link to post Share on other sites
TEMPESTMK5 8,209 Posted April 14, 2017 Share Posted April 14, 2017 Good evening Andrew Very you have done Patrice 1 Link to post Share on other sites
nimrod54 12,526 Posted April 14, 2017 Share Posted April 14, 2017 That is a lovely build Andrew and well done on the scratch built struts, everything looks fine from my armchair. 1 Link to post Share on other sites
