I started this kit in 2014. It's actually the reason I was put in touch with White Ensign Models' liquidator - I had just bought the kit from WEM but was going to buy the paint later, then they announced they had ceased trading a week later!
I've never run any threads on this, just chipping away at it on and off in my own time. Due to WEM's demise I bought Flyhawk's detail-up set and their resin turrets to go with, but ended up needing a WEM set later when they were back in production. The deck is from Pontos Model and that was a liberation from Sovereign stock also. As we all know, I did get my paint in the end . I've learned a great deal more since I started this through close contact with a few select contacts I've made since starting Sovereign Hobbies, and mostly that translates to my current fine PE parts work being better than it was when I started this, with particular emphasis on gluing pieces in place. I've tried my best at this one and there are deficiencies (some glaring) in my execution, but I'm going to finish this one, move on, and try to get the next one better as is always my approach.
Overall, I think it's probably fair to say that I've done a lot of experimentation with different techniques on this one. Some I like and have formed part of my style, others I haven't done well with (but I've tried them).
Magnificent work Jamie, and you've definitely done the HMS Hood the full justice in which she deserves.
I really need to try and find some PE tutorials on you tube to learn this skill, the workmanship that you've shown is going to help spur me on.
First Rate model Sir!
Also much impressed and interested to see how you take things forward.
What was the source of the 3D view of the Air Defence Platform?  I am keen to find out whether the UP mountings on Hood had dedicated control sights.
36 minutes ago, Chewitt said:
 Can only use word for this   "WOW"
Coming from you Chris, I think that's overstating it a bit, but I thank you for your kindness none the less :)
I've picked up a lot but there are bits I'm not happy with! I fairly mangled the crane on the mainmast and the funnel cap stays are wonky too. Bending and forming has come relatively naturally to me and it was assembling and gluing I struggled with. Somewhere amongst the above is the chopped sewing needle tool I tried which I made following a tip elsewhere using thin CA. I have to admit I didn't have much success with that other than in some special circumstances, and I have found an Acupuncture needle and medium CA easier to cope with. I use two straight scalpel blades (for cutting and folding), one small diameter round object & piece of kitchen towel (for rolling curves), a sanding stick (to smooth off burrs where cut from the fret), a pair of conventional tweezers and a pair of needle tweezers for everything PE related. I'm aware that there are special PE tools around but I seem to manage fine with the above.
The book is the Kagero publications book on HMS Hood - https://www.abebooks.co.uk/Battlecruiser-HMS-Hood-Super-Drawings-3D/14068327864/bd
It's not perfect, but better than nothing. There's a huge amount of information on the HMS Hood Association website http://www.hmshood.com/, and Frank Allen from there contributes in detail to at least one ship modelling forum.
Thanks to each of you for your encouragement. I'd like to get this one finished some time soon! It's dragged on long enough now ... :)
Great work so far James I think I, am in the same kind of build process as yourself learning as I go from others on this site and another
I started the King George V a while back but have since been doing smaller builds in 1/350 scale to try and build up my skill and techniques
This will hopefully let me get back to KGV soon so I can do that to a level I will be happy with then I can get started on some of the others I have ready to go in the stash  :whistle:
keep at it slow and steady it looks like a winner to me so far  :yes:
Beefy
Snap Beefy - my KGV stalled a bit when I checked some reference material and realised I needed Carley floats. I could have built around that issue whilst the Carley floats were posted but I picked up Hood instead. There's nowt wrong with what's been done so far on KGV, and it'll get finished at some point. I want to be able to call Hood done though. :)
Good build and particulary nice paint job on the hull - is that pastel weathering?
I have this in the stash, must buy turrets for it some day.
It is indeed pastels. It's fairly idiot proof, which is a good thing for me :D
Most unusually, I spent all day on this with some extra PE folding/assembling labour from Gill (my wife / VP webstore, packing and posting).
Despite that, not much seems to have changed. There are far fewer holes in the decks left, but it looks pretty much as before.
I spent a while rusting the anchor chains before fitting them. Not convinced it was worth all the time but it's done anyway
Thanks Jamie re Kagero publications for info
A general question about Colourcoats if I may - what matt varnish (preferably spray can) would you say works best?  I made the mistake of using the Humbrol 49 spray acrylic on a hull with an Admiralty Light disruptive pattern and found the bits I had painted with B6 going crinkly in several places even though the bits that are 507B were unaffected.
Hi Francis,
I can't profess to have thoroughly tested them all, but I can't honestly recommend aerosols on top of enamels in general. The propellants are extremely aggressive in aerosols and in my experience almost all aerosols that I have tried are capable of wrinkling any enamel brands I have tried them on.
In terms of clear coats generally, Humbrol Matt, Satin and Gloss Cote works fine, as does any of Hannants' clearcoats in Xtracolor or Xtracrylics form. If you still have any old WEM VG, VS or VM varnishes which we have discontinued they work too.
We are working on a new clear coat system to replace the WEM varnishes, a quicker drying, airbrush and paint brush friendly colourless clear to be exact.
Whilst that's still in development though I don't think I could look past a Windsor & Newton Galleria clear coat.
7 hours ago, Reconcilor said:
Looks awesome! Didn't spot any of your 'glaring issues'
You're too kind! I've mangled the boat crane cables on the mainmast. The funnel stays proved a catalyst for getting a foolproof gluing method (which I think I'm now happy with) but the stays themselves are mostly stretched and bent from over handling whilst struggling with thin CA. There are some bad seams on the plastic parts I'm noticing now despite investing half a tonne of filler on these dubious early Trumpeter mouldings! I wasn't aware of the misshapen aft 4" gun station and splinter shield. A correction is provided in the WEM set but I had already applied the wooden deck by this point so I'm stuck with it. The letter "H" is wonky on the starboard quarterdeck bulkhead nameplate.
I think the main topmast was actually white in spring 1941 rather than grey, which I can maybe still rectify as the mainmast isn't glued in place yet.
Jamie that is quite superb work. Every time I see Hood I feel choked up, such a beautiful but tragic vessel. You appear to be doing her more than justice, :)
Steve.
Tonight I made up 2 40" searchlight platforms. These are rather nice resin castings that came with the Flyhawk turret set. The gusset plates I used are also from the Flyhawk set but the WEM set includes loads of gussets and similar types of details. At first glance the resin platforms look pretty much the same as the kit parts, but on closer inspection the kit part is a bit chunky thickness wise. I'd say these resin bits were a "nice to have" rather than essential but the turrets were essential and as a result I have the platforms, and they're better than the kit bits so I'm using them :)
The ship is getting busy rather quickly so I put the bits together (not glued) to take a few more snap shots. I also decided not to be shy in showing my "improvement areas" up close.
It's a spectacular level of detail that's achievable with PE at such a (relatively) small scale, and until recently I had no idea how fiddly some of it can be (then I got the Ark Royal), so I've been catching up with this with some new-found interest.  It's the painting of the ship in stages that's the most terrifying part to me, being an aircraft and AFV modeller at heart.  You must live with battleship grey in the airbrush! :frantic:
Keep up the good work :)
12 hours ago, Mike said:
<snip>  It's the painting of the ship in stages that's the most terrifying part to me, being an aircraft and AFV modeller at heart.  You must live with battleship grey in the airbrush! :frantic:<snip>
Hi Mike,
You're right it can seem a bit daunting. Early on I tied myself in knots trying to work out the most efficient way to do it with minimum number of airbrush 'activities'. It rapidly became apparent that I was getting nowhere fast worrying about it.
At this point I'm trying not to get too hung up on painting. I'll mask and spray what's practical to spray, and I'll touch up or paint in with a brush what's left. It's important to choose a paint which can be applied and dries the same shade by either method. For airbrushing, I'm saving up a few sub assemblies at a time now. I've made peace with the fact that the airbrush needs loaded a cleaned many times over building a ship!
Having tried to pre-paint some parts on the sprues, I'd say that was a complete waste of time both specifically to this Trumpeter kit which has needed loads of remedial work to clean up parts but also in general as often little plastic bits need cut off and replaced with a PE part if doing the detailing too. Overall it seems better to sub-assemble then paint for most things.
That Tetra Model Works set for Ark Royal set is gorgeous and I'm really looking forward to building my own kit with one in the hopefully-not-too-distant future! :D
I'm down to the last handful of plastic parts to fit now (there are still many brass parts to go however) and tonight I decided to ditch two more kit bits.
The aft Quadruple 0.5in Vickers gun platforms are moulded with splinter shields all round and with shapes to represent ammunition lockers. The supporting gusset plates are also moulded on, typically thick. There are brass gussets to replace the latter and the ammunition boxes, and according to my references there was no splinter shield but rather a railing
I figured it was easier to scratchbuild the platforms. Unfortunately my compass cutter only goes down to 10mm, but the plans say the platforms should be 8mm diameter, so I cut guides from masking tape using my cutting mat and chopped/sanded the plasticard to match the tape circles.
I made new posts from heat stretched sprue. It took a few goes to get the sprue heated gently over a wide area to get quite a thick draw to the right diameter.
It was just a case of dressing up with PE then and they're ready for the guns which I'm going to have to make very soon.
I've no idea why, because I have never delved into the model this deep until now, but I had some deep rooted suspicion that something wasn't right with the two ammunition lockers as shown on the kit (and both detail sets).
I spent most of tonight's modelling time looking at references, and found myself depressed looking at Evert Jan Foeth's scratchbuild 1/350 Hood on his webpage. I don't think there's a man alive today who knows HMS Hood more intimately than EJ Foeth (a fanatical modelling Dutchman) or Frank W Allen (of the HMS Hood Association). That two together have had a great deal of input to the new Pontos Model 1/200 HMS Hood set and frankly (no pun intended) Pontos' offering is miles ahead of Mk1 or anything Eduard will come up with thanks to the combined knowledge of those two and Keumo Kim's willingness to listen. Still, E.J. has answered the immediate question - these aft Vickers platforms only had one locker mounted each. The second was down on deck.
http://ontheslipway.com/?paged=11
So, umm, this is it for tonight!
