As promised in January, here are some pics of my Eduard 190A. its the first kit I've finished in about 18 months- severe mental illness doesn't make for happy, finished models...
So this is a bit of a victory in many ways. Hope you like.
PS sorry about the pics- a photographer I ain't. If you look in one of them, you can see George looking appraisingly..
  • Like 26
Mainly out of the box, sprayed with MR Paints, using Kyle's Top Notch masks. Hypodermic needle guns- a swine to cut! I've left off the pitot tube- the kit one broke, and despite best efforts I couldn't reattach it. Likewise the aerial. I wasn't going to risk spoiling it trying to get EZ Line to stick.
This looks great! A very nice build of what is a lovely, but not easy to build, kit.  I have one of these making its way down the production line, this inspires me to keep on flogging it!
I curious how the kit decals behaved for you? They look great in the box but I haven't tried them out yet.
I've recently picked some Albion micro-sized brass tubing, and have hopes it will be much easier to use than steel hypo needles!
I've built two now, and I found that on both, the common problem wasn't getting the fuselage to fit, but getting the starboard wing to close at the root, and then to get the wing to fit to the fuselage. I found that carving away the inside of the top wing half at the root, and then doing the same to the undercarriage bay insert, the problem disappeared. You have to be fairly confident (and brave!) because you go quite close to digging a hole in both pieces, but it does work. If you drop the undercarriage bay in place, and sort of shake the lower wing, the bay finds its own location. The same thing happens with the upper gun bay hatch. Tamiya Super Thin is your friend with this kit, but don't use the brush in the lid. It's too 'all or nothing'. Use a fine paint brush. Take your time and you won't need filler, but it's not a 'shake-n-bake'. I've thought about brass tubing, but I'm a cheapskate. It's the only way I can afford MR Paint.
The kit decals were fine, by the way. A few needed some solvent, but the majority were no problem. The wing walks were a pain, but only because I couldn't get them straight.
Edited by Andy Robbins
really great looking finish. I am one of those modellers that gives up far too often at the 90% stage, but as can be seen from your build, going that last "half mile" really does make all the difference. Thank you for finding time to share.
Very interesting comments, thanks for those.
My A-8 is almost ready to paint, and I've been keeping an informal building notes log on another forum here:
http://z15.invisionfree.com/72nd_Aircraft/index.php?showtopic=8321
By the way, I'm giving my age away here, but have always used an old-fashioned bow-type drafting pen for liquid cement. Adjustable and highly controllable.
Wow! Not used one in years. My dad taught me how to use one. He was a loco builder and used them for lining out. He was originally a draughtsman. When I learned drawing, they were out in favour of Rotring pens...
Nice job on this Andy, I'd have taken it for 48th if you hadn't said. I've a couple of these in stock, I'll try :unsure: to remember your tips re wing fit.
Steve.
  • 3 years later...
