Sign in to follow this
Julien
Spitfire V.III Update sets, masks & decals - For 1/72 Eduard Kit
Spitfire V.III Update sets, masks & decals - For Eduard Kit
1:72 Eduard
The new Eduard kit is a good one, however Eduard are also offering their update sets for the kit. Here we have an update set, flaps, masks and additional decals.
Update Set (72645)
This is one brass fret. It contains parts for the cockpit bulkheads, pilots seat (and frame), rudder pedals, radiator flaps, undercarriage doors, tail wheel doors, canopy crash bar, and rear control linkages.
Flaps(72646)
This is one large brass fret which provides flaps, and wells for the kit. The ribs are those already attached which need to be bent into position. Some work on kit parts is needed.
Stencil Decals (D72013)
This small sheet provides the stencils the kit needs. Rather than a stand alone item this is ideally suited to the modeller who has purchased overtrees to use another of the kit main decal options,
Masks(CX478)
Supplied on a sheet of yellow kabuki tape, these pre-cut masks supply you with a full set of masks for the canopy, with compound curved handled by using frame hugging masks, while the highly curved gaps are in-filled with either liquid mask or offcuts from the background tape.
Conclusion
These sets will enhance your Spitfire model. Recommended.
Review samples courtesy of
