Sign in to follow this
Julien
GAZ-233115 STS Tiger-M SPN SPV Sagged Wheel Set -1:35 Meng Model
1:35 Meng Model
Gorkovsky Avtomobilny Zavod, or GAZ for short are the leading manufacturer of commercial vehicles in Russia, and specialise in all-wheel drive heavy duty trucks, buses and light commercial vehicles. The Tiger is a development of the GAZ 2330 4x4 that is designed as a troop carrier for police and military forces, with good offroad capability, high speed and good handling on sand and steep gradients. The Tiger is an upgraded vehicle with ballistic protection to the sides and roof, with a large two-man turret-ring on the roof to allow both a machine gun and grenade launcher to be used simultaneously.
It is known colloquially as the Russian HUMVEE, and like the HUMVEE it does not provide much in the way of IED protection, other than a suite of electronic countermeasures. Its flat ladder chassis differs from the newer designs like the American M-ATV, which has a sloping hull to deflect blast away from the occupants. It has plenty of space for radio gear, the aforementioned ECM fit, plus ammo stowage and of course four troops in the rear, with a two man crew in the front seats. This boxing is for the newer Tiger-M vehicle which features a slightly revised body style and additional armour.
The Set
This set is designed as a direct replacement for the kit wheels. Unlike some sets they replace all four main wheels and the spare. The pour blocks for the resin are cleverly designed to follow the tyre tread pattern and should be easy to remove. The casting is superb, nice and crisp with no visible defects.
Conclusion
This is a good update set for the GAZ Tiger if you don't feel the original rubber tyres are not up to the job, or you just don't like rubber tyres.. Recommended.
Review sample courtesy of
