This is just stunning work!!!!
Just found this thread and have just read the whole thing.
  I tried to build a rare planes gotha once, hand painted the lozenge camo....badly!!
Bob , Invidia ; Thank you.
Wheels made it to tire treatments , some grey/white and then a violet drop added and a glaze made for base coloring:
The violet is only on the inner edges of the tire , it will go through grey to almost white in the tire middle.
I like to remove the masking as soon as possible:
These are heat dried , sealed with gloss clear and will be left for a good while to cure.
The lavender color is subtle and hardly shows here , but I'm happy with it.
They will be embedded/weathered with the rest of the underside when its done.
Edited by krow113
Lower wing center underside gets started:
Mask , ivory primer , streaked with brown tones decals ready:
Decals in place:
Obviously some work needed still.
A good set of parts this session:
Much of it green/grey with chipping to come:
Edited by krow113
I have been through all this fantastic thread... Man this is stunning! A real masterpiece very, very inspiring! By the way what Harley(s) do you have? I have a highly customized 1200 Sporty... ( I am OT I know...)
Thanks Claudius.
Shovelheads , Evolutions , to the Revolution VRSCR I ride currently.
Work continues on the parts stream , ever-present green/grey applied and chipped , looking for the base finish of the parts :
Sealed up with the 50/50 clear:
Some of the larger detail pieces of the kit , and focal points as well.
Edited by krow113
Final work on the simulated plywood underside.
First some clear orange , then clear red:
Then the red/black/brown mix:
And smoke to tie it all together:
Finished with the clear mix.
Most of this will be covered by the light blue overall underside color , some areas will have wear with the plywood showing through.
This part is now ready for the wing painting session ahead.
Edited by krow113
Tailfeathers connected and the slight gap filled with hsp:
Figuring out the paint sequence is coming clearer.
These parts need to be connected and their seams addressed.
Looking at the top wing with an eye for assy and getting the joint seam dealt with. I think I'll make a cradle.
And so I did  a plate out of 12mm composite material:
Sizing:
Test clamping:
Final clamping and a lovely ooze from the joint:
Larger components gathered:
This plate takes the plexi model jig parts and has been setup to take A Gotha.
Edited by krow113
Smallish update.
The small sink mark gets filled:
Seams disappear.
This would be the way to do this, leaving off the VS & rudder , filling the seams with sprue:
And coming back in I stabilized the wings to the jig with some small pieces of double-tape.:
… and filled the center joints with sprue:
Looks like I made some more work for myself , too much glue and it oozed up into the strut holes.
Edited by krow113
The wing join can be done easily when the parts are stabilized.
Filled with  kit stretched sprue:
Ball masks and underside painting looming.
Ivory primer:
Royal blue :
White to begin knocking them down:
And a custom light blue mix:
Really getting there now.
Edited by krow113
Thanks HDawg…
 Pink proprietary rib tape extended decal session results in a nice coloring underside:
Edited by krow113
Masks and painted markings applied with masks developed over 4 years ago . The mask set has become comprehensive.
These worked out great:
Masked balls get gunmetal pint:
All of the undersides are now base painted and sealed.
Looking at the weathering and detailing treatments to come.
Edited by krow113
Trying to finish off the wing underside .
And the proposed bomb load is proven to be unworkeable:
Problem solved :
I'll leave the 2 outer racks empty.
And the AEG GIV kit is yielding some bomb rack gear that is well moulded , I can rob some parts and not effect the kit too much.
And lastly some pencilled in panel lines , completely spurious , and gauge bezels for the rack mounts:
Edited by krow113
Contemplation today as I think the upper camo through.
Here is the wing , a paper plot and the cut and numbered mask;
Fuse and tail:
One step further.
Defining and numbering the 5 color handpainted polygonal night camouflage in Corel today:
Stunning work as usual. Really interested to see the camo goes on. Might inspire me to finally build my zepplin stakken ( contrail 1/72 in the stash but leaning towards a 1/144 scratch)
Edited by Marklo
Thank you , Marklo.
I think this procedure may be impossible in the smaller scales though, the shapes would be too small to work with. Decals in those scales may be a better bet.
I'm warming up the house in anticipation of the first color application . Last night a review of the work resulted in the change up in colors to these :
Thank you for the interest , I'm thinking there will be a real spike in attendance here as I go through this!
