Built this a while ago, trying to get back into the habit of posting builds. The old Frog kit is greatly superior to the very old Airfix but still has its issues, but I just added a very basic cockpit and the bracing struts - they are not wires. To get the aerofoil shape I built a jig out of scrap sprue and glued two lengths of 0.08 monofilament fishing line side by side with thin superglue, which worked perfectly. The struts could be tightened up with heat in the normal way and paint filled what was left of the central grove.
Paint is Humbrol, good old 'silver' 11 does a rather good salt weathered metallic aluminium. I went for a fresh paint look, just out of the factory or into the museum.
The only problem was the decals instantly fell apart, which I expected. So I painted the tail - which got the blue matched - and replaced the serials with Model Decal British pre-war serial numbers and scraps were used for the float trolley markings.
Would be nice to see this historic plane retooled or in larger scale plastic, plus other Schneider racers (there are resins out there - I'm tempted to take the plunge). It may not have guns but what an engine!
Edited by TallBlondJohn
That's a belter, and a great tip about making thin struts.
Very nice work.
Testors released a 1/48 S6B and Smer released a 1/48 Macchi Castoldi M.C. 72. As you've noted, these racers were beautiful aircraft.
If you decide to pick up the Smer, be prepared for some work, that kit is the flash king and the detail is soft.
Who tells that old Frogs are not comparable with modern kits? OK - a bit of hard work and skills and result is excellent! :)
J-W
Really fantastic S6B!!!
It seems that you really have captured all the spirit of this wonderful racer!
Great job. Congratulations.:clap2:
:wow::goodjob::wow:
I'll give it a like when I get my likes back but in the meantime. I really like this. :)
Steve.
Looking very nice! Ingenious approach to the bracing.
Hear, hear!!
And there's Karaya's (resin) Short Crusader.
.. & in that close cowl fuselage it really makes the pilot seem like a mere passenger slipstreaming along behind that engine. Great stuff.
