Kahunaminor
1/48 Eduard Bf 109E-7 Trop, Libya, June 1941
Hello one and all,
I started this build for the MTO GB which ended in December 2016 and failed to meet the deadline. So, it was suggested that I continue the WIP here. Not to bore you all with volumes of old pages, the original WIP can be found here and I will continue the build on this thread. To bring you up to speed, here is the last post:
As I said, some slow progress. The aircraft has now had its Flory light dirt wash applied and removed. AK Interactive Ultra Matte Varnish for a protective top coat. I may have used a little too much thinner and defeated the dullness, so another light coat of less thinned is probably on the cards. The MLG oleos have had their BMF coverings, PE retraction struts and the wheels added. The BMF will be toned down a bit with some dust:
62317D1B-87CB-41C2-BDD7-F9AF3023EDC4_zps
6865BA7A-EF28-4967-BE1B-BD8CE17981D4_zps
0183FD5C-2074-47A9-B0F2-BDB0FB9D340A_zps
D76A37D1-CFAC-4E76-84FA-524044D1ED10_zps
B0138807-6EF3-4C2A-BB91-CDC5FBE19242_zps
ACA58707-0402-40B3-83F0-6F6243396F77_zps
AFC81A56-C44F-4837-B17C-7CCAD9E32F98_zps
87A71A71-D08D-44E5-8960-B32F543FCA1A_zps
The MLG angles look right from all directions so I am happy with the setup. Brake lines and MLG covers to go followed by some more lower area dirt.
Regards,
For those of you that have been following from the GB, you will know that I previously lost the port MG17 into the bowels of the closed fuselage during the build. The modelling Gods teased me with the sound of it dislodging a couple of days ago and rattling around before restoring silence. The additional sacrifice I offered (in the form of a additional purchase) must have paid off, as it dislodged last night and fell onto my desk. Photos to follow.
Regards,
With the modelling Gods appeased, the port MG 17 was affixed into position:
B5EDDA88-5B9A-4965-A03D-D90DEE05C49C_zps
The MLG have had their brake lines added and the covers added as well:
A160A552-A9F4-499B-805B-C285302AE656_zps
BC12E7BF-B9A1-430C-97AA-C328DDE714FB_zps
57C50C3E-E5ED-498E-9CB3-3CF054BDCA94_zps
Thanks for looking and regards,
Welcome back,
Free of kids and SWMBO, I had a busy morning. Put on another coat of Ultra Matte Varnish, this time thinned about 30/70 instead of 50/50 and got a better flat finish. Then like a kid on Christmas morning the masks came off as I have pretty much finished the airframe. Gunsight and grab handle to go back in the cockpit, hinged canopy armour detail and antenna then onto the engine:
9ECCF5D1-EF34-4570-90C9-240AADE13C77_zps
364692C9-CDF1-4FA5-ADDB-65B57B3DE199_zps
CA80599F-C76A-4249-95BD-E185EA4642AB_zps
164B6E01-4E7A-4604-AF85-BF21177C7B66_zps
FFD04135-A17C-47A2-B31E-2A6A2C23F39C_zps
80CE3C54-0D5D-47CA-9BC8-E16CB2CE7F99_zps
7FF59B85-B758-4C3C-ADFC-A7942A25E53C_zps
A8465185-EE18-4E16-B237-211DB6F51F9D_zps
Regards,
1 hour ago, Biggles87 said:
Looking really good, will it have a parasol to shade the cockpit?
John
Nice thought.....no, not this time.
Regards,
Welcome back,
The antenna wire has been added from Ezi line, secured with CA. A loop was made through the thin copper "spring" and the PE piece doubled over through that loop and both sides secured to form the attachment at the tail. The insulators will be added from globs of white glue and painted light grey when dry:
BC106BC3-4E45-44DC-9CDC-17765D105BAB_zps
The fuselage insulator was a small piece of 0.05mm styrene rod with a small hole drilled into it. The Ezi line was attached at one end and the rod trimmed to size and affixed to the fuselage with CA. When set the vertical wire was positioned against the horizontal and secured with CA then trimmed:
67F58835-6B33-4398-93C2-D31D6BFC7701_zps
0E5180BE-0273-4805-97F6-DA5F5A22850E_zps
The cockpit has had the gun sight and port grab handle installed and some work done on the open canopy retention strap. I used thin copper wire to "beef up" the PE piece and as a spring for the antenna wire:
36249D47-378F-4D8F-AA86-6066A5FB62FC_zps
FEC87A9D-8FC0-436E-A032-272CD271DE23_zps
6A454315-2837-419A-AA72-5C7B48CAC7F1_zps
3338EB51-DBD2-4ABF-94EE-016E43560E93_zps
As this build is destined to be a vignette, I have started blocking the scene as well:
ED55D753-4FDA-4E53-9C11-012DBF0DD69C_zps
B28FE61A-7CFD-424C-85C6-05F4200CE117_zps
Regards,
A productive morning. Worked on the engine and canopy of the Bf 109E-7, adding PE and some decals to various places. The support brackets were installed once the engine numbers taken from the kit decals were in place:
F45679A4-D564-4777-A6F1-193A82D60C01_zps
2B4C0974-0E7B-49E5-9136-E15386E96E87_zps
CB269B54-66D7-4D82-BDB9-F144143DC05F_zps
That warped resin will hopefully set correctly once it is installed. The decal is from the Aeroscale LW cockpit placards set. The canopy was next with the armour plating being installed. I had broken one of the tiny upper supports that came with the original, so luckily the PE set had a couple of spares:
0DDEED82-B764-403C-8A30-86F6F565CD52_zps
8446F907-D1A7-48E6-AC9C-5C2B76F95B2A_zps
9DC002B0-4AC6-4134-AA93-A7C4E3DACCCD_zps
7A36EC69-536D-4587-8977-8E9430C4E03D_zps
I have obtained a photo frame to use as a base for the vignette, but it may be a tad large. I may have to add another component....
Regards,
Welcome back,
I was just fiddling around and before I knew it, I had an engine installed:
A1B29F59-58CF-4CEC-8DA0-EB00EFD62132_zps
58FBC2F4-81B0-4F91-B93B-D53FE31950DD_zps
FBD9610C-7864-4212-A776-6614A95CDAB4_zps
I still have to do a wash, weather and add some wiring but its in!
Regards,
Man, that's a cool build!
Very good job on this African Emil.
Watching with interest.
Welcome back,
Just to show I haven't totally forgotten this build, here a couple of updates. Here are the exhausts and tropical intake:
7DA57E9B-5B08-4205-A270-3501AA0FB272_zps
E4300685-4C9C-494E-BB9E-04BDDAD28C0E_zps
9F146525-CE3A-47FA-948F-F8DB8419BDAA_zps
BC1CDF50-1EB6-4C7A-A1EB-93F7583D98C8_zps
New ground for me in that I plan to include at least two figures:
CA14B73A-C70F-47DD-ABD2-DBBE7CF5E910_zps
I am working on a vignette concept, so it is still in its layout phase:
21CB087E-949E-4C7B-8C50-1DCE5939A556_zps
FC942075-5DC8-4C76-B90C-647D899CB77C_zps
750F7DA7-010F-4257-AAD2-7861B79AD066_zps
459E5280-F6FE-443E-A7FE-C62F6F3D4BA4_zps
The vehicle is is 1/48 Tamiya Type 82 Kubelwagen Afrika Korps boxing. The pilot figure is also from there and the mechanic is from the Eduard 1/48 Luftwaffe 1944 boxing.
Regards,
That is a lovely job on this. Franzisket's aircraft is one of my favourite North African Luftwaffe schemes & I'm keen to do this in 1/72 with some Airfix decals I have. I'll be using this thread as a reference for how it should look. :)
Steve.
Steve.
Thanks Steve,
I appreciate your confidence in my abilities. I have been a tad distracted with my armour build but as that has hit a small impasse, it was time to get back to this build. I wanted to detail the engine a bit more as it is open for the world to see, so using this book to guide me:
CDF2813B-91AE-475B-8D55-1F457C83B9DA_zps
I set about adding some of the smaller bits of wiring that are obvious to the naked eye. This is by no means all encompassing but with some lead wire of various diameters, copper wire stripped from an old electrical cord, some swearing, some plastic rod, some BMF self adhesive foil, a lot more swearing and time, I came up with this:
F39F80D1-33C5-4727-85F2-E81B26F7E0ED_zps
92709D1C-9C35-4715-AC30-BCA222D3E255_zps
33730A8B-06A9-4D57-9040-70686C30B31A_zps
Still to be painted and weathered but a little closer to the photos than before. The steely eyed amongst you will have seen the engine appears out of alignment. It is but the addition of the spinner and its connection point  will true it up enough and hopefully hide some errors!!
Regards,
That does look staggringly well done, ample reward for your hard work, which is why I build in 1/72, I'm allergic to that much hard work. :)
Steve.
Welcome back,
As I plan to have this completed for the NSW Scale Model Show early next month, I realised I had started wasting time on side issues such as the composition of the material for the base and came to a realisation: I can have an incomplete aircraft on a half finished base or if I don't finish the aircraft, I will have nothing to show at all! So, the engine has been completed as far as it will be. There is some more wiring I could do but this is it. Exhausts lined up and inserted through the openings and spark plug covers set in place. AK engine wash has covered a multitude of sins and tied the area together. Having said that, the MG gloves need a wash to tone them down. The tyres have been flattened slightly to show weight bearing and the drop tank has been added, plumbed and fuel spills added. Some minor engine oil leaks on the underside add a used look. A flat coat with AK ultra Matte Varnish is next up followed by final chipping effects then construction with prop and spinner assembly, canopy, mass balances and pitot. The ladder comes from the 1/48 Tamiya tank maintenance set, which has a lot of interesting pieces for any maintenance setting. Still three figures but one is shirtless so no easing into figures for me!
D72C7CC2-76E2-4BE2-BEA9-9D127EB6F724_zps
B6246C8A-D09A-406B-94B8-93A38CFF8ACA_zps
C326C1DF-C403-4A36-8401-13870B2CC0A7_zps
02939596-946D-424E-B799-8BC39B852D0C_zps
BD6F42F9-6CCC-4F69-BA4D-EFDD4A274183_zps
D5FEE3F3-FC14-418E-9FC2-2094C5562010_zps
AB722278-5ECC-40E3-B1E3-265161F42F08_zps
27F55326-2CC6-4922-A4E8-164E80E01C52_zps
8FEE6B00-99AD-4871-A426-C6421E695137_zps
Regards,
Slowly approaching the end. Canopy, prop and spinner assembly, pitot and mass balance (yes singular because one has gone astray) have been added. There is only the engine cowling latches and some minor metallic weathering to go:
3896DAD9-6C11-43A8-AB2F-CF0C361C29BB_zps
2958191F-8816-457B-97FC-0A1ED9B96878_zps
5E408484-2390-4D62-BB70-52399FAFB10B_zps
4A1D3205-6916-46FB-BB58-233FC4B60CF1_zps
88484050-A097-4470-9348-2A4B28ED420C_zps
95E90A89-89CB-41B8-8E43-0C979AE9A43B_zps
07B089D2-D844-4E46-83F0-E8B972E24435_zps
EB080614-9429-4D95-BF50-538767CBFC0B_zps
33CC1EB8-361B-42FB-8FF0-5E6CCDC18742_zps
BDEFF668-0FAD-4798-8D98-38D0E9461303_zps
EF745DB2-4A83-4A40-87F7-C0A36C411284_zps
486E6028-5EC9-4A02-B685-0D1938235015_zps
BC54080A-F86B-4DE8-9FAF-28E1CF97EA64_zps
82569808-01D4-48AD-81D0-9C79CB895C06_zps
Regards
Okay calling the aircraft done:
06EAFD30-182D-4EF2-AA38-562A445BCDE5_zps
E66B6F77-8985-4140-BCC5-8CE322DFE33A_zps
0C596017-4DDE-49B4-9F19-3348EC69B542_zps
5A4E96BE-4727-457E-9C2E-8CD27321485E_zps
I wanted to create a small duckboard work area, so out came the paddle pop sticks, matches and white glue. An hour or so of measuring, cutting, scribing and gluing left me with this:
E0C949F7-B1F3-4E57-9835-54E1030046B8_zps
40862DDC-60DE-4702-B229-B997B3FCD971_zps
D57542FE-5FAC-468C-A4EE-FC77B21BAF53_zps
Some tissue paper soaked in a white glue/paper mixture gives me a rag to cover a non existent hole in the sand filter housing. The match ends will be trimmed, some nail holes added with a pin as required and some ends squared before some paint and weathering.
Regards,
Love the whole project so far Kent. The Paddle pop sticks/matches idea is a great one for the  floor/ bench.
Thanks guys,
First effort at a base, so probably over engineered a bit. Photo frame with craft sticks around the border to build a flush interior edge. Craft stick supports in each corner. Monte Marte 24 hour air dry clay (terracotta because it's closer to desert colour) rolled to within an inch of its life (with talcum powder to negate sticking) to form a thin covering over the entire insert. Secured with white glue and trapped underneath the photo frame edges. Items placed and tyre marks gently added. The wooden walkway has been gloss coated, oil washed the Promodeller wash followed by Ultra Matte Varnish. I have some sand from the kids sandpit and some commercial stuff for rocks etc. now to leave it for 24 hours plus to dry:
E53D0D98-A18E-4689-A401-1AAB0A15A2CB_zps
7B9C73A1-FD03-4E6D-A370-644B431278CF_zps
D48844D8-3D5A-4812-96EB-D4D119C1507C_zps
C7F865E2-B559-4EC4-B50F-898A40C3CFE9_zps
FF0A796B-F2F6-44C4-99BD-BDE0AAE0BB40_zps
79D72FD4-BA90-4B94-81D2-B0ACCE191A9A_zps
Regards,
Your 109 and diorama are very nice!  Can't wait to see it finished.
