RidgeRunner Posted February 1, 2017 Posted February 1, 2017 (edited) Finally I got my latest build finished. I had been running her along side the FJ-4 Fury that I posted recently. She is a Super Mystere B2 “Sa’ar” as operated by the Fuerza Aerea Hondurena from La Ceiba air base. This machine, with others, took part in Operacion Danto ’88 against the Sandinistas when they crossed the Honduras-Nicaragua border to chase the Contras. It was a fairly large scale US-FAH operation. She is the latest in a line of models I’ve built that depict South or Central American operators and, in fact, follows on from a Honduran Sabre that I completed a few months ago. She has taken three months or so, on and off. I am a bit slow. It is the AZ kit – an easy build. Of course, my start of this kit has spurred Special Hobby to announce a new moulding! Hey ho, I was too far down the line by the time that news came out. So what did I do to her? Well: Added the wired ducting along the port side with Plastruct half-moon rod Added a UHF aerial to the fin and another ahead of the cockpit Added the pressure sensor under the rear fuselage with Plastruct .8mm round rod Added the small bullet fairing at the rear of the fin I removed the moulded plate on the fin where the elevons/tailplane were to be fixed and made two new plates from plastic card and hinged the tailplane on a rod through the fin. The tailplane always sat tilted backwards when at rest. Made plastic card weapons pylons Used Heller Etendard wing tanks Inserted cannons using Plastruct .8mm round rod Cut the canopy so that I could mount it open. The supporting fairing was made using rectangular section plastic rod Installed a MB seat as the Hondurans had (a Mk5, or as close as I could find) Used stencilling from Isrdecals I opted not to cut out the NACA inlets and instead used home printed decals. Serials and flag from the kit, although the flag isn’t entirely accurate (no stars). Printed the Armament panel on the port nose I think that was it ;). The paint scheme is standard US two-greens/tan and underside of grey. All Humbrol enamels (116/117/118/28) I painted a number of subtle stains in the various colours by simply adding a spot of a darker shade to each and painted them on using a fine brush. The rear section has two distinct darker tan patches where the squadron marks were removed. I then dirtied her up with Flory Dirt and finished with a matt cote. I hope you like her. Martin …. Next is a C-Model Super Sabre to keep my Sabre line going. I have an Obscureco wing and fin set to incorporate after I’ve figured out the Aires cockpit set and jet pipe set J . She’s going to be a Turk based on an Esci kit! Edited November 2, 2017 by RidgeRunner Moved from PB to Flickr and updated image 46
exdraken Posted February 1, 2017 Posted February 1, 2017 very neat build of an interesting plane! especially if you think about its long history and Sa ar conversion!!
Gary West Posted February 1, 2017 Posted February 1, 2017 Neat job - the extended jet pipe looks so weird though
RidgeRunner Posted February 1, 2017 Author Posted February 1, 2017 Thanks chaps. She is sitting in my Latin line-up now Martin
Darren Rhodes Posted February 4, 2017 Posted February 4, 2017 Nice build of a beautiful looking subject. And thanks for spurring on Special Hobby to bring us a new tool, much appreciated! Darren
Wez Posted February 4, 2017 Posted February 4, 2017 Martin, Cracking job and something you don't often see (Super Mystere's are quite rare, Honduran one's more so). A question about your next build, are you converting the Esci kit using the Obscureco conversion because you have it or because there's something fundamentally wrong with the Trumpeter kit? If so what? I've got a number of Airfix Super Mystere's but I too am holding out for the promised Special Hobby kit, hope your efforts will have spurred them on (I've got plenty of decals for French subjects). Thanks again for showing us your work - and BTW, you're a much quicker builder than me!
RidgeRunner Posted February 4, 2017 Author Posted February 4, 2017 Hi Wez, my my understanding is that the Trumpeter falls short on accuracy whereas the Esci scores points from everyone. Chris at Obscureco sent me a C-model set that looks good, while a little dimpled. Even so it is better on outline etc. For example, the Trumpeter fin is wrong, for sure. I do have a Trumpeter C that I will use for spares - it has a ladder etc. I see see where all the Airfix SMB2s are lurking good luck.... Martin
Antoine Posted February 4, 2017 Posted February 4, 2017 Splendid! On 01/02/2017 at 1:43 PM, RidgeRunner said: She is the latest in a line of models I’ve built that depict South or Central American operators and, in fact, follows on from a Honduran Sabre that I completed a few months ago. Got to dig out some of your topic then,
72modeler Posted February 4, 2017 Posted February 4, 2017 Antoine, Impressive build! I am saving this, so I can use what you have done to figure out how to crosskit the Airfix and AZ kits, or maybe since you have done all of this fine work, Special Hobby will finally release theirs and give us a better kit to work with- you do know that's how this works, right? Seriously, I can only hope I can do as good as you have. It sure does look weird with that extended exhaust! Mike
RidgeRunner Posted February 6, 2017 Author Posted February 6, 2017 On 04/02/2017 at 9:17 AM, Wez said: A question about your next build, are you converting the Esci kit using the Obscureco conversion because you have it or because there's something fundamentally wrong with the Trumpeter kit? If so what? Hi Wez, If you are interested: As you can see, I am posting a little about my build on Ed's thread. M
dolphin38 Posted September 29, 2017 Posted September 29, 2017 A nice unusual subject and air force and a really neat build
RidgeRunner Posted September 30, 2017 Author Posted September 30, 2017 Thanks Red Dot and Dolphin38. I was very pleased how she turned out. Martin
RAGATIGER Posted November 2, 2017 Posted November 2, 2017 Hi Martin Wondergul kit!!! Best modelling Armando
replicant Posted November 2, 2017 Posted November 2, 2017 I like yours!!!!! I started recently a Tigermeet SM too! Thomas
RidgeRunner Posted November 3, 2017 Author Posted November 3, 2017 Hi Thomas! Thank you. She fills a nice gap in my Latin air arms line up, which is slowly growing. I don't turn them out as quick as you! Martin 1
replicant Posted November 3, 2017 Posted November 3, 2017 3 minutes ago, RidgeRunner said: Hi Thomas! Thank you. She fills a nice gap in my Latin air arms line up, which is slowly growing. I don't turn them out as quick as you! Martin But only posting (older ones), not building. 3 per year, i mostly missed that goal!
RidgeRunner Posted November 3, 2017 Author Posted November 3, 2017 ah ha!!! Well, the quality speaks a lot!!! I love your unusual builds. I like the unusual too. Martin
