sinnerboy Posted January 28, 2017 Share Posted January 28, 2017 I use wine corks ( the real cork ones ) to protect the blades fingers, with a hole drilled in the side of the cork and a short length of sprue inserted to stop it rolling. 2 Link to comment Share on other sites More sharing options...
Black Knight Posted January 29, 2017 Share Posted January 29, 2017 10 hours ago, Vinnie said: Thanks, MD. My blades have arrived, just waiting on the handle. I keep re-reading the answers and wonder if this is a good idea. I tend to be a bit ham-fisted and I think blood letting may be involved, so any advice on safety is much appreciated. Don't worry about all this talk of blood letting - its all exaggeration. Just use the knife as carefully as you'd use any other and all will be fine. You'll find that you can cut and trim parts and tape to a much finer degree with SM blades You'll wonder why you didn't get them sooner PS; don't be tempted to buy the cheaper chinese knock-offs of SM blades and handles the handles are not made to same high tolerances the blades can be both blunter and softer steel and the slot may not fit the SM bayonet fitting 2 Link to comment Share on other sites More sharing options...
Pete in Lincs Posted January 29, 2017 Share Posted January 29, 2017 And yes, change blades using small pliers. ALWAYS! 4 Link to comment Share on other sites More sharing options...
Rick Brown Posted January 29, 2017 Share Posted January 29, 2017 I was always told you are less likely to cut yourself whilst using a sharp blade instead of a blunt one. Somat to do with: 1). You are more careful 2). Less cuts are needed to achieve the results you require, therefore you have less exposure to the knife. 3). Can't remember the third reason.... Not sure if that's true, but does have some logic to it. Rick. Link to comment Share on other sites More sharing options...
Black Knight Posted January 29, 2017 Share Posted January 29, 2017 point 3 is allied to point 2 because the sharp blade cuts easier you don't need to force the blade which may delfect and into you 2 Link to comment Share on other sites More sharing options...
Rick Brown Posted January 29, 2017 Share Posted January 29, 2017 15 minutes ago, Black Knight said: point 3 is allied to point 2 because the sharp blade cuts easier you don't need to force the blade which may delfect and into you Aye, it was summat like that Chap! Rick. Link to comment Share on other sites More sharing options...
bzn20 Posted January 29, 2017 Share Posted January 29, 2017 4 hours ago, Pete in Lincs said: And yes, change blades using small pliers. ALWAYS! I use my CK double fulcrum parallel pliers. Full contact along the blade and final "click" I just push down with a small flat chisel. Don't know why they make those things so dangerous to change. Never cut myself .................yet. I know its just 'round the corner though ! I dropped it a few times and did the splits rapido . Always straight in the floor and stuck in vertical ! 2 Link to comment Share on other sites More sharing options...
bzn20 Posted January 29, 2017 Share Posted January 29, 2017 4 hours ago, Black Knight said: Don't worry about all this talk of blood letting - its all exaggeration. Just use the knife as carefully as you'd use any other and all will be fine. You'll find that you can cut and trim parts and tape to a much finer degree with SM blades You'll wonder why you didn't get them sooner PS; don't be tempted to buy the cheaper chinese knock-offs of SM blades and handles the handles are not made to same high tolerances the blades can be both blunter and softer steel and the slot may not fit the SM bayonet fitting Good advice ! Can't beat the best! Link to comment Share on other sites More sharing options...
Sgt.Squarehead Posted January 29, 2017 Share Posted January 29, 2017 +1 for SM scalpels.....I usually have several on the go at any one time, never use anything else. Link to comment Share on other sites More sharing options...
Beardie Posted January 29, 2017 Share Posted January 29, 2017 These are the rules I use after years of accidentally cutting myself. One of the most important things in handling a scalpel is to think about each cut and how you are going to make it carefully before you actually make it taking into account where your fingers will be and how you will move the knife. If the blade 'digs in' don't force it and don't try to make a cut that is too tough for the size of blade. When it comes to removing items from sprues etc. I use a razor saw wherever possible rather than a scalpel as that is not what scalpels are designed to do. Always put the scalpel down with the handle end towards you and not anywhere where it will be easily knocked off the work space. You could always stick a blob of bluetack somewhere safe on your work surface and stick the scalpel to it when not in use. 2 Link to comment Share on other sites More sharing options...
huvut76g7gbbui7 Posted January 29, 2017 Share Posted January 29, 2017 If you drop the No3 scalpel and can't see it on the floor Vinnie, it is most likely sticking out of your knee but don't worry the pain only starts when you see it (like the others above..don't ask) Richard 2 Link to comment Share on other sites More sharing options...
bentwaters81tfw Posted January 29, 2017 Share Posted January 29, 2017 8 hours ago, Black Knight said: Don't worry about all this talk of blood letting - its all exaggeration. Just use the knife as carefully as you'd use any other and all will be fine. Wot e said! 10 Link to comment Share on other sites More sharing options...
bzn20 Posted January 29, 2017 Share Posted January 29, 2017 WIP....Wounds in Progress ! 4 Link to comment Share on other sites More sharing options...
sinnerboy Posted January 29, 2017 Share Posted January 29, 2017 All this good advice given to you Vinnie, I'm surprised and, if I'm honest somewhat disappointed that none of us has asked you the most important question of all..... you are over 21 aren't you? 3 Link to comment Share on other sites More sharing options...
Vinnie Posted January 30, 2017 Author Share Posted January 30, 2017 Unfortunately, yes! Link to comment Share on other sites More sharing options...
Vinnie Posted February 5, 2017 Author Share Posted February 5, 2017 Ok, I'm convinced. They are sharp. Used it for the first time on a 109 canopy and promptly sliced it into two. Mind you, everything seems to have gone wrong with this one. I've broken the guns, aerial and tail wing support struts while cutting them off the sprue. Is it just me? Btw, how do chaps safely dispose of their used SM blades? 1 Link to comment Share on other sites More sharing options...
bzn20 Posted February 5, 2017 Share Posted February 5, 2017 10 minutes ago, Vinnie said: Ok, I'm convinced. They are sharp. Used it for the first time on a 109 canopy and promptly sliced it into two. Mind you, everything seems to have gone wrong with this one. I've broken the guns, aerial and tail wing support struts while cutting them off the sprue. Is it just me? Btw, how do chaps safely dispose of their used SM blades? Oh dear ! I cover a cutting mat with an old drying up cloth to cut my stuff of the sprue, soft so theres no distance between the object and the base, the object is supported. To get rid of my blades... I put a fold of thinnish card along the blade then I wrap them in tape,use quite a bit. You can't tell its a blade. The blade can't move on the card and "escape" out the side. As far as I know I haven't taken part in any blood letting amongst the bin man army yet ! Link to comment Share on other sites More sharing options...
Sgt.Squarehead Posted February 5, 2017 Share Posted February 5, 2017 Wrap 'em up in the wrapper from the new blade and chuck 'em in the bin. So if anyone goes poking through my garbage looking for credit card details, they are probably gonna regret it.....I get through a LOT of blades. 1 Link to comment Share on other sites More sharing options...
bootneck Posted February 5, 2017 Share Posted February 5, 2017 All blades, not just modelling ones should be disposed of in a safe manner. As mentioned earlier, if you are going put them in the dustbin, it is best to sandwich the blade between two pieces of sturdy plastic and then tape it all up. This is not for the benefit of the dustmen but to prevent birds and animals that scour the waste disposal sites from getting injured. I do use a lot of blades, I have four scalpels in use during a build, and I've found the best way to dispose of the blades is to place them in a suitably safe container and, when it is full, take it to the council tip where they will have the proper disposal facilities. The setup I use can be seen in the photo below; the container for safe disposal is a yellow 'sharps' tub and the blades I use are, from left to right: No.11 - light work, for cutting thin card, paper and small stuff No.10A - heavy work, for carving and cutting thick plastic No.9 - chisel, for scraping flat surfaces and chiselling No.10 - curved, for scraping rounded edges. Having four scalpels is useful to me as I don't have to keep changing blades for the different tasks I wish to undertake. 4 Link to comment Share on other sites More sharing options...
bzn20 Posted February 5, 2017 Share Posted February 5, 2017 Or Blue Tits or Harry Hedgehog then Bootneck ! Link to comment Share on other sites More sharing options...
bootneck Posted February 5, 2017 Share Posted February 5, 2017 I'm just an old softy! 1 Link to comment Share on other sites More sharing options...
Panzer Vor!!! Posted February 5, 2017 Share Posted February 5, 2017 Gave one these knives a go but wasn't impressed use a Stanley knife for everthing --cutting trimming etc Just couldn't get used to it D Link to comment Share on other sites More sharing options...
bootneck Posted February 5, 2017 Share Posted February 5, 2017 1 hour ago, Panzer Vor!!! said: Gave one these knives a go but wasn't impressed use a Stanley knife for everthing --cutting trimming etc Just couldn't get used to it I was going to say "Finesse comes to mind" but you are bigger than me Dave! Link to comment Share on other sites More sharing options...
Panzer Vor!!! Posted February 5, 2017 Share Posted February 5, 2017 I,m just a big old Teddy bear But to be serious I really could not use these knives I used a stanley after leaving school in my first job in a supermarket for opening boxes and other jobs got so used to it wont use anything else now ---never cut or injured myself with one either Link to comment Share on other sites More sharing options...
Vicarage Vee Posted February 5, 2017 Share Posted February 5, 2017 For removing those 'impossibly thin but moulded with two huge sprue gate' pieces that snap instantly if you try to remove them with a knife or scalpel, I find that immobilising the sprue in blu tack and sawing gently through the gate with a fine razor saw saves it all in one piece ready for tidy up. Sometimes it helps to separate a section of the sprue to make a smaller, more manageable one. 1 Link to comment Share on other sites More sharing options...
