I've been longing to build a model of one of the coolest Star Wars ships of all time, Boba Fett's Slave I. Like all Bandai kits, this 1/144 scale version of his iconic ship comes premolded in various colors but unlike most Bandai Star Wars kits, this one has to be painted if you want to accurately represent the ship. Having the parts organized by color makes painting it pretty easy given how complex the rear of the ship is. I removed and cleaned all of the parts from the sprue and organized them by what color they were to be painted.
After I got all of the rear pieces organized, I started painting the cockpit. Most sources show that the cockpit should be army green but I much prefer grey, which was Tamiya Neutral Grey (XF-53) in this case. I highlighted a few bits with some Vallejo light grey and silver and gave everything a wash with MIG Dark Wash (enamel). The front console was painted with Tamiya Deep Green (XF-26), I applied some liquid mask with a sponge and then gave it a coat of NATO Black (XF-69).
The bottom dark grey layer of the rear was painted with Tamiya German Grey (XF-63) and given a wash with MIG Dark Wash enamel. The engine nozzles were undercoated with Tamiya Buff (XF-57), had some liquid mask applied with a sponge, and then given a coat of coppery brown mixed with a few Vallejo reds and browns. I preshaded the green bits with Tamiya Flat Black (XF-1) and gave them a coat of Tamiya Field Green (XF-65) followed by a wash with MIG Dark Wash enamel as the first pass of weathering. The grey parts were preshaded with Tamiya German Grey (XF-63), painted with Mr Color 315 (Gray FS16440), and given a wash with MIG Neutral Wash enamel. I also applied a few of the small decals on the grey parts.
I love how layers of parts are stacked on top of each other to make a complex surface. There is even parts that can't really be seen unless you hold it just so; it really is quite impressive. After all of the pieces are in place, more weathering will be added to dirty everything up, mainly chipping on the raised areas, more enamel washes, and possibly some pigments.
The stabilizers were painted with Mr Color 315 (Gray FS16440), the yellow markings/chips were painted with a mix of Flat Yellow (XF-3) and Yellow Green (XF-4), the red strip was painted with a mix of Flat Red (XF-7) and Hull Red (XF-9), and the entire assembly was given a pin wash with MIG Neutral Wash enamel. After everything dries, they'll get a coat of matte varnish and then more weathering.
Moving on the the front "skirt," I started with the base coat of pale green. According to the painting guide supplied with the Fine Molds version of this kit, the "correct" color is supposed to be Tamiya J.A. Grey (XF-14). This was a little too green for my taste, I mixed in some Tamiya Medium Grey (XF-20) and Flat White (XF-2) in a ratio of 3:2:2 to get this wonderful pale green. Also, I took this photo while experimenting with a new 50mm lens I bought for my Nikon. I would like to take all of my work in progress shots like this but it's much easier to grab my iPhone and snap a few quick pictures.
After giving the skirt a nice coat of chipping fluid, I sprayed on the redish brown. All and all, I'm not entirely happy with it. I decided to use chipping fluid instead of liquid mask applied with a sponge. It's not bad, it's just not the finish I was aiming for. I guess it will be cool because the chipping on the skirt is going to be different than the hull, where I will be using liquid mask. The colors I used were Hull Red (XF-9) and Buff (XF-57) for the red, Pink (X-17) for the chipping, German Grey (XF-63) over Medium Grey (XF-20) for the grey panels, and Vallejo Model Air Tank Brown (71.041) for the brown panel. After this picture was taken, I managed to get a panel line wash on with MIG Dark Wash enamel. Once that is sealed in with some matte varnish, I'll move on to more weathering.
Edited by ScootyPuffJunior
I wasn't happy with the front skirt but I also didn't really want to change it. After sleeping on it last night, I woke up and was content with how it turned out. Not happy, but willing to leave it as is. I then spent the next twelve hours at work and my dissatisfaction with it grew throughout the day. After I got home and had a lovely dinner with my wife, I head to the studio and decided to fix it. Needless to say, I am much more pleased with the end result. I used the same grey-green base color, applied a layer of liquid mask, sprayed a coat of pink made with Tamiya Pink (X-17) mixed with a little Tamiya Deck Tan (XF-55), applied another layer of liquid mask, and finally gave it a coat of the same red-brown from the first go around only with a tiny bit of Flat Red (XF-7) added.
25 minutes ago, Dermo245 said:
This is so good..:worthy:
Ok if I bookmark it when I come to build mine?
Dermot
Thanks!
Of course you can bookmark it! I've noticed there aren't than many builds of this model so I'm trying to record everything as best I can. If there's something particular you want to know about what I did, feel free to ask!
Thanks and much appreciated!
Here's a question straight away - can it be built with the boarding ramp open to display the standing figure?
Looking great, I love all the detail and colour on the back plate.
Will
Thanks guys!
I worked on the the fenders last night. The one on the left was painted with Tamiya J.A. Gray (XF-14) and had liquid mask applied to mimic the weathering on the studio model. It was then given a coat of J.N. Green (XF-11) mixed with a touch of Field Grey (XF-65). The one on the right was painted with a witch's brew of Tamiya greens and had liquid mask splattered on it by dipping a piece of torn foam in liquid mask and using air from my airbrush to apply it. A coat of the same green color as the other fender was applied and the masking was removed. The underlying green was a little too bright so I sprayed some heavily thinned dark green over it to tone it down.
It's coming together amazingly well. The chipping looks spot on & I'll also be coming back to this thread when the time to build mine comes. Great work!
Your first take on the skirt looked great, but you really nailed it with the repaint. The fenders look great too. A lot of people seem to miss the fact that the two sides have completely different chipping.
Andy
very nice work and such a great looking ship if ever there was one..... just like the Avenger class from the films.
I'm having a bit of a mid-life crisis. I'm in between building model kits in my hobby room in Hamps, alongside Star Wars UCS Lego kits as the girlfriend doesn't approve of glue and paint in the lounge and my model studio is not at her house (yet...!) - so I have started to build the Lego UCS Star Wars kit in the lounge while she watches her drivellous soap rubbish on the telly.
BINGO - Tonight see the start of Lego UCS Slave 1 for me !!
Keep up the great Bandai work there
Andy
Thanks Andy!
Your fantastic build of the 1/72 scale Fine Molds version was a big inspiration for this build. I also have that kit in my stash and I hope to get around to building it some time soon.
I sprayed the first coat of green, which is the going to be the darker of the two on the hull, over the entire area. It's essentially the Tamiya equivalent of RLM 02 and I made it by mixing RLM Grey (XF-22) and Khaki (XF-49) in a 1:1 ratio with a tiny extra bit of XF-22 added.
Using the studio model as a guide, I applied masking fluid with torn pieces of sponge. Give the nature of the original paint job, no model will ever match it exactly, however, the goal here was to just get close. This color is Tamiya J.A. Grey (XF-14) with a tiny bit of Deck Tan (XF-55) added to it.
After I painted the dark green panels with J.N. Green (XF-11), I did a quick dry fit of the major hull pieces just to see how it looked. I thought that the RLM 02 color was a little dark so I sprayed the entire hull, sans the dark green pieces, with a very thin coat of J.A. Grey to tone them down.
I weathered the wing supports with a handful of MIG enamel washes stippled on with a sponge and then blended into the surface. This was probably overkill because they are barely visible one the "fenders" are added and the entire assembly is inserted into place.
The panel lines were done with a mix of MIG Dark and Neutral Wash and then cleaned with a some enamel thinner.
I still have a couple small pieces of the wing supports to paint as well as the laser cannons and then I can move into the final stages of the build; more weathering.
this is coming along a real treat - looking forward to seeing it completed. My Lego Slave 1 is going back into production for a few hours tonight - not quite on the same par as yours though...
