HP Victor B.2 1/144 [GWH+ShelfOddity]
My white 1/144 whale is ready to go public.
GWH kit with my pe fret and refueling probe and pitots from Master.
This is XL164 B.2, Blue Steel aircraft. Modelled without Blue Steel. With no evidence to the contrary I assumed that when no missile was carried, the bomb bay doors had been replaced. This is an important factor/excuse, as I tried to be reasonably accurate, but still be able to finish the model within a decade.
ACtC-3dVK2uAQ8wIB-w3lGxxf57pw6SKBnrlLUuM
The base is supposed to represent Cottesmore taxiway after storm, drying quickly in scorching tropical sun of England. Why the aircraft itself is dry? - you may ask. Well it has just landed after good weather flight.
Post-flight ministerial inspection is about to begin.
ACtC-3fotbSyFS1c8wrpH2yktWnau5y-O11tht98
ACtC-3eOzzWFbUuTOgdy3NCcp-jKfrjwnLh-3ugP
ACtC-3f1E-vF57Ow7OnsxPDqwSzyQkOMUOBeGPYS
ACtC-3c6_I5wLdRRsKAI590SJvCurhpW1OFsa0zz
The Conways were known for their power output and reliability rather than cleanliness:
ACtC-3eYZ53G2IcSVMb_hHZDedlVxenBQCfyY1Zd
ACtC-3c4WcHYycASkOWlH3V7TbA-MW8F_VkWFmX2
ACtC-3f5muHhCeaULYVn31s9pj-DoGA3dxjOjR_d
ACtC-3cl_3ykoPPPeeLWZxNoS_f4P2gUdViet6ck
ACtC-3eCh31BLw-oZABYz3iE7dE4D-MStulNi4nF
ACtC-3d5Yog1Hr3R9CU3swXc_LZGpdy6OKLrNQhF
ACtC-3dyVspJ757fWg4prswQVGAB4KXnaSJD0tAC
It took some effort to photograph the subtle effect created by polishing panel centers and leaving panel lines matt.
ACtC-3eqGwm2JdfAuSy-P4yTp8KyMZBFfTMfo8Gw
ACtC-3clOtgWbRa9wrYfGNeAw-nFbt96sgG9Gbn9
As mentioned - it is very subtle, and easier to spot when moving around the model. Shaprer lighting helps to bring out sheen variations (a little)
ACtC-3c-nYFftGUgec5vLLEr8amYVyiiEpWtzo20
ACtC-3fy26qx4jiFoH6R1H6JBbgVwKbWOpTtEUik
Edited by Lejgo_inc
image re-link
  • Like 35
The blisters are made of 1mm plastic rod cut diagonally and sanded to get approximate shape. After this generous use of black paint did the smoothing.
Actually there was no varnish at all. I used Gunze Mr. Base White in multiple layers and then soft felt for polishing.
Thank you!
I am still wondering if my decision to leave bomb bay door in place of Blue Steel missile recess has any basis in fact - does anyone know?
(Victor will be making public apperances at Wrocław Model Show, Poland (1-2. April, we hope to have larger group of 1/144 models on display there) and three weeks later at Moson Show, Hungary)
  • Lejgo_inc changed the title to HP Victor B.2 1/144 [GWH+ShelfOddity]
