1964rac Posted January 9, 2017 Share Posted January 9, 2017 Hi, I have been a bit quite on this forum for a while, have been modelling and moving houses etc, so have not had time to post. So I thought it being a new year I would post a work in progress. I have always wanted to build this kit, but the price has put me off, so when I saw the kit for £15 at Telford last year I could not resist any longer. I have already started, could not wait, so will post images of the work done so far later. The scenario is a derelict bus being taken apart, so I have had to build a new front end, thankfully there are photos online for reference. Cheers Richard 1 Link to comment Share on other sites More sharing options...
1964rac Posted January 9, 2017 Author Share Posted January 9, 2017 Hi, The web has a vast selection of images of derelict bus, which makes it so much easier to come up with a reasonable little diorama. Here are a few images, I will use different parts of each to make up the completed diorama: And, here are some images of the progress made so far: \ Lots to do. Will start on some chipping and weathering on the cab, a touch of rusting as well for good measure. I wont have any seats inside so I have removed the seating attachments and filled in the holes: Going for something like this for the interior... More WiP pics coming soon. Cheers Richard 2 Link to comment Share on other sites More sharing options...
1964rac Posted January 17, 2017 Author Share Posted January 17, 2017 Hi, Got a lot done since the last post. I should say that this is one of the best kits I have made, the fit has been excellent through out, in some case they snap together, not need for glue. Lower and upper deck assemblies finished, weathering next plus adding rubbish.. Body primed, rust added and sealed ready for the chipping solution and coat of London bus red to go on top, once dried I can start the rusting process. I have made a started on the base.. Here is the bus mocked up so I can get the dimensions for the base, did not want the base to over power the bus, so have left a small amount of space in front for the scrap yard furniture. Might have a wall or chain linked fence running from the rear of the bus, round behind the bus as if it is in a corner of a yard. Going to use the seat frames stacked up, some will be left inside as well.. Going to have a work area at the front of the bus, tools, gas bottles (cutting gear) see additional images below from Kit Form Services. Not sure about the other engine from the kit, might use that in another diorama.. Also have the above selection of items from Kit Form Services, will use a few items to enhance the diorama, going to order the items below next.. Plenty of weathering to do on the engine and engine bay.. Thats it for now, more to come this weekend. Thanks for stopping by and having a look. Have a good week. Cheers Richard 2 Link to comment Share on other sites More sharing options...
malpaso Posted January 17, 2017 Share Posted January 17, 2017 Don't get too carried away with the rust, as the Routemaster had aluminium bodywork (I think some of the double curvature panels may have been glassfibre). The really manky ones in your photos above are RTs which are the preceding design from just before WW2 though most were built post war, they still ran into the 70s. The tall thin radiator is the obvious giveaway, also the more sloping front and number box on the top of the "dome". Looks like your model will be an interesting project, even if there's no rust on the coachwork there was plenty of other steel bits for the galloping tin worm to get hold of. Also the roofs of busses always seemed to be well weathered even in service. Cheers Will Link to comment Share on other sites More sharing options...
1964rac Posted January 17, 2017 Author Share Posted January 17, 2017 Malpaso, Thanks for that, will bare that in mind when I start the weathering. Do have a few images of a bus that had been set on fire, scorch marks on the outside, so will look at that for the exterior. Regards Link to comment Share on other sites More sharing options...
1964rac Posted January 22, 2017 Author Share Posted January 22, 2017 OK, so what have I done since the last post? A lot really, here are some pics. Started on weathering the engine, added a tarp to cover up the incomplete wheel assembly, but it does add some character to the diorama. Interior of the lower section of the bus complete. Got the top deck to do. Some pics of the front and rear of the bus with some of the scrap yard furniture. And here is a pic of the diorama as it is so far.... Start on the weathering of the bus next, got this pic for reference... Plenty more to do, pics to follow next weekend. Thanks for stopping by. Cheers Richard 3 Link to comment Share on other sites More sharing options...
kpnuts Posted January 23, 2017 Share Posted January 23, 2017 That is looking great so far. Will definitely be keeping an eye on this. Link to comment Share on other sites More sharing options...
Alpha Delta 210 Posted January 23, 2017 Share Posted January 23, 2017 Great progress. I look forward to seeing the next instalment. Link to comment Share on other sites More sharing options...
Graham T Posted January 23, 2017 Share Posted January 23, 2017 Apparently, 24 of these placed end to end is the same length as a Double decker bus! Strange but true! Link to comment Share on other sites More sharing options...
1964rac Posted January 23, 2017 Author Share Posted January 23, 2017 Thanks guys for your comments, glad you like it. I have started the weathering, slow process but worth it... Started on the scorch marks.. Closer look.. More to follow tomorrow night. Cheers Richard 3 Link to comment Share on other sites More sharing options...
1964rac Posted January 24, 2017 Author Share Posted January 24, 2017 Hi, Did some more weathering tonight.. .. burning and added some smashed windows. A few close up pics of the burning. Pretty pleased with the effect, my first attempt at burning. That's all I had time for tonight, might get some more done this week. Need to sort out the roof as it doesn't fit to well, bit of a gap, think it might be due to the amount of deconstruction I did on the front end. Once I have weathered and added rubbish to the top deck I will fix the roof and fill the gap. That's All Folks. Cheers Richard 6 Link to comment Share on other sites More sharing options...
Séan Pádraig Posted January 25, 2017 Share Posted January 25, 2017 Amazing, Stunning, Masterful... inspired diorama. Link to comment Share on other sites More sharing options...
vrsmatt99 Posted January 25, 2017 Share Posted January 25, 2017 Absolutely fantastic! I really like how this is coming along. Amazing skills! 1 Link to comment Share on other sites More sharing options...
1964rac Posted January 25, 2017 Author Share Posted January 25, 2017 7 hours ago, Séan Pádraig said: Amazing, Stunning, Masterful... inspired diorama. Cheers Séan thanks for the comment. All the best. Richard Link to comment Share on other sites More sharing options...
kpnuts Posted January 25, 2017 Share Posted January 25, 2017 Wow, i mean what else can i say. Totally gobsmacked, amazing work. Link to comment Share on other sites More sharing options...
richellis Posted January 25, 2017 Share Posted January 25, 2017 Very cool! Link to comment Share on other sites More sharing options...
shood23 Posted January 25, 2017 Share Posted January 25, 2017 Richard those last few pictures with the burns on the side look bloody amazing, I really like how you made the paint curl up. Shaun Link to comment Share on other sites More sharing options...
1964rac Posted January 25, 2017 Author Share Posted January 25, 2017 19 minutes ago, shood23 said: Richard those last few pictures with the burns on the side look bloody amazing, I really like how you made the paint curl up. Shaun Hi, Thanks. I was looking for a way of getting that effect, when I remembered dropping some Plastic Weld onto a painted kit part sometime ago and the mess it caused. So I painted the area with Plastic Weld, then scrapped back the paint (it works like paint stripper) to the plastic, then using LifeColour Burn paint set, set about the burn effect. I'm sure there are other ways of doing it, but this method works for me. Cheers Richard 2 Link to comment Share on other sites More sharing options...
1964rac Posted January 29, 2017 Author Share Posted January 29, 2017 Hi, Destruction of bus coming along well. Here are some images, which show the work done so far. Rear of the bus.. (that faces away from the public when on display) Top View... Rear... Front... (Not sure about the figures) The full monty... Added graffiti, more stains, moss extra and finished the smoke damage to the roof. Just got the base to do, oil stains and a few more bits, tools etc. Thanks for stopping by. Richard 5 Link to comment Share on other sites More sharing options...
Avereda Posted June 3, 2017 Share Posted June 3, 2017 Did I see this at the Salisbury show today? If so it's even more impressive in the flesh. Link to comment Share on other sites More sharing options...
1964rac Posted June 3, 2017 Author Share Posted June 3, 2017 1 hour ago, Avereda said: Did I see this at the Salisbury show today? If so it's even more impressive in the flesh. Hi Avereda, Yes it was. Many thanks for the kind words, glad you liked it. Cheers Richard Link to comment Share on other sites More sharing options...
Kallisti Posted June 3, 2017 Share Posted June 3, 2017 Yup I saw this at the show today as well and having built a "heavily weathered" Routemaster a few years ago I was mightily impressed with this one! The look of the internals was spectacular, very well done! This was mine... Link to comment Share on other sites More sharing options...
ukmodeller Posted June 8, 2017 Share Posted June 8, 2017 Amazing! Some really good effects to bear in mind. Love the atmosphere that was created Link to comment Share on other sites More sharing options...
