Lex77 Posted January 1, 2017 Posted January 1, 2017 Hi guys, will be joining this GB with a 1/48 Tamiya F-16C and it will be in the aggressor markings. Not quite sure it will be the brown or blue markings, I will be using the Tamiya F-16C/N boxing. Will have to finish a Kinetic F-16 first. 3
trickyrich Posted January 2, 2017 Posted January 2, 2017 welcome aboard, nice choice there, we may see a few of these! Actually this is the model I should have bought, this kit has all the parts to do most of the C series, you just need the Dragchute for the European F-16C's. Well good luck with the build and look forward to seeing her in the gallery. 1
modelling minion Posted January 2, 2017 Posted January 2, 2017 7 hours ago, trickyrich said: welcome aboard, nice choice there, we may see a few of these! You certainly will, I'm just about to start my thread for the same kit. Still not 100% as to which scheme to finish it in, we shall see. Look forward to your build Lex, should be a good one. Craig. 2
SimonT Posted January 2, 2017 Posted January 2, 2017 Just now, modelling minion said: You certainly will, I'm just about to start my thread for the same kit. Still not 100% as to which scheme to finish it in, we shall see. Look forward to your build Lex, should be a good one. Craig. You cant go wrong with Aggressors, they look good in camo, the more the merrier I say! 4
Lex77 Posted January 22, 2017 Author Posted January 22, 2017 Started building parts together but came across a problem pretty soon! Somethings missing!!
Shaun Posted January 22, 2017 Posted January 22, 2017 That's strange for Tamya, pretty shocking on a £50 kit... 1
modelling minion Posted January 22, 2017 Posted January 22, 2017 That really is bad Lex, one of the worst moulding errors I have seen recently. I hope you are able to get a replacement very soon. 1
Lex77 Posted January 22, 2017 Author Posted January 22, 2017 Got another Tamiya F-16C/N in the stash so maybe will be taking parts of that one but sure hope Tamiya is going to replace that part. 1
modelling minion Posted January 22, 2017 Posted January 22, 2017 2 hours ago, Lex77 said: but sure hope Tamiya is going to replace that part. I should hope so considering how much the kit costs! 1
trickyrich Posted January 22, 2017 Posted January 22, 2017 gosh I haven't seen something like that for years! QC had a bad day that day. If the worse comes to the worse it occurred in a relatively good place to repair it. Plank over the hole from the underside and a few thin layers on filler and it should disappear. But they should replace that for you free of charge, that was always the great thing with Airfix!! 1
Lex77 Posted January 24, 2017 Author Posted January 24, 2017 Anyone experience with replacement parts from Tamiya? Where can I ask for them? Got a reply from the company who supplies the Dutch market but they aren't really helpfull.
Pappy Posted January 24, 2017 Posted January 24, 2017 8 hours ago, Lex77 said: Anyone experience with replacement parts from Tamiya? Where can I ask for them? Got a reply from the company who supplies the Dutch market but they aren't really helpfull. G'day Lex, Have you tried the kit seller? This may not help if you bought the kit at a swap meet, but if you bought from a model shop (even on-line) I would attempt to get the replacement part through them first. I have taken a kit back to the shop in the past and I was able to swap the kit without any hassle, but I had not started the kit yet. cheers, Pappy 1
Lex77 Posted January 24, 2017 Author Posted January 24, 2017 Hi Pappy, Thanks for the reply but unfortunately I bought it at a kit swap.
trickyrich Posted January 24, 2017 Posted January 24, 2017 Was it the same company as this? http://www.tamiya.de/ I looked up Tamiya's service agent list from there main site, not sure if you found this or not. http://www.tamiya.com/english/agent/agent.htm 1
Lex77 Posted January 25, 2017 Author Posted January 25, 2017 Thanks Rich but unfortunately it was that company! They say I have to go to the company in my country and gave me a mail adress but no reply from that company at all.
trickyrich Posted January 25, 2017 Posted January 25, 2017 that was real helpful of them! I think in the long run it maybe easier to repair the hole. As mentioned earlier the position of it isn't too bad for repair work. Just laminate the inside with thin sheet plastic, fill the hole as best you can again with small bits of thin sheet plastic. Then 2 or 3 thin layers of filler, but mask the area around first to stop filler damage of the surrounding detail. A bit of careful sanding and you would know there was a hole there in the first place. 1
Lex77 Posted January 25, 2017 Author Posted January 25, 2017 Thanks Rich but finally got a reaction. They are going to replace te part but it has to be ordered in Japan and that could take up to 6 weeks. But I got another Tamiya F-16 in the stash so will be using the part of that one for this build. 3
Lex77 Posted January 31, 2017 Author Posted January 31, 2017 The other F-16 I'm working on for another GB is moving on so got some time on this one; And the together with the Kinetic F-16 3
Jabba Posted February 12, 2017 Posted February 12, 2017 Coming along nicely, pity about the original part, you don't often see that from Tamiya. 1
Lex77 Posted March 2, 2017 Author Posted March 2, 2017 Almost a month ago with not much building time and time to look at all the other builds. So it's time for an update. 2
