AdrianMF Posted December 29, 2016 Share Posted December 29, 2016 (edited) Hello All, As a slight diversion from my Privateer, I started a Lindberg/2nd Round re-pop of the old Inpact Bleriot Monoplane just before Christmas. For a change, I did my research first - this isn't quite the aeroplane that flew across the channel and looks like it may be something of a generic mash-up, so I've chosen to model it as a "representative example" - meant to be fun, right? [So it seems I have two modes of operation: do the research and then ignore the findings, or; build the kit, do the research and then change the kit. Ewww] The kit was first released in 1968 and still holds up today in my opinion. The moulds appear to have lasted well too. My Dad built quite a few of them in the 1960s. I have the whole Inpact 1/48 range in my stash and this is only the second one I have built, the first being the Bulldog in the late 60s. I didn't get a sprue shot because I just piled in, but here are the main parts laid out after a little bit of assembly and painting in Hu 110 acrylic wood and a home brew acrylic off-white: They are all masked off so I could add some colour variation. Masking was not the most time-consuming part of this kit! I stippled them with a mix of off-white and Humbrol acrylic 93: Underneath I went for a bright white stipple with a hint of spar shadow: It was an experiment and underneath, you know... I gave everything a wash of Hu 93 to blend it all together after unmasking. I added all the fuselage cross bracing from stretched sprue painted silver by dragging it under a permanent silver marker. The kit has an ingenious way of assembling the fuselage halves by presenting all the cross struts on a runner that you cut away after assembly. I decided to add them individually after bracing the bay (sides, top, bottom and end-on cross bracing) - this was the time sink! Threading the rudder and elevator control wires through the spiders nest of the fuselage was a particularly interesting challenge. I ended up using stretched sprue for all the rigging, including the wing bracing threaded through the wing and pulled tight. Time will tell if it lasts! The rest of the construction was uneventful until I got to the wheels. The kit wheels are in brown plastic with raised spokes on them. This is a downgrade from the original kit, which moulded the wheels in clear plastic with raised spokes on them. Clever stuff. However, I googled away and came across a terribly helpful video posted by Arni here in the Vehicle Modelling forum. This shows a simple method for making them. I managed to mark out 12 stations 30 degrees apart using schoolboy geometric constructions, and set up the jig: Very high tech as you can see! The idea is that you make the wire wheel in the rim and then stick it inside the tyre from the kit. For me, this would mean making a 0.5mm thick rim using my Olfa circle cutter at its smallest radius (5mm and 5.5mm), which I didn't think I could do. So I made a hoop the size of the rim and the tyre: Then I made two hoops the size of the tyre, rounded off the inside edges and painted them dark grey. I painted the rim-plus-tyre silver and then stuck the "tyre" sections to the outside of the rim-plus-tyre sections. This meant that I didn't have to worry about painting the rim/tyre demarcation. I then sanded the outside edge to a rounded cross-section and touched up the dark grey. Done! A picture is truly worth 1000 words here! The last thing was to paint up the pilot (looks like Louis Bleriot with his huge moustache) and it was finished. Great fun to build: I will get some more pictures when I have a mo (off to see relatives today) and do an RFI. Now, about that Privateer.... Thanks for looking, Adrian Edited December 29, 2016 by AdrianMF replace thumbnail with proper pic 21 Link to comment Share on other sites More sharing options...
Martian Posted December 29, 2016 Share Posted December 29, 2016 An excellent little build! Martian 1 Link to comment Share on other sites More sharing options...
woody37 Posted December 29, 2016 Share Posted December 29, 2016 Superb Adrian, what a great tip on making wheels and a lovely finish to the whole aircraft too 1 Link to comment Share on other sites More sharing options...
CarLos Posted December 29, 2016 Share Posted December 29, 2016 Very nice build, Adrian. The wire wheels makes the old kit something special. Carlos 1 Link to comment Share on other sites More sharing options...
Crossofiron1971 Posted December 29, 2016 Share Posted December 29, 2016 Oh WOW!!! What a fantastic build! Love the way you call this a 'diversion'... 1 Link to comment Share on other sites More sharing options...
Brandy Posted December 29, 2016 Share Posted December 29, 2016 Lovely job, I particularly like the linen effect with the washes. Ian 1 Link to comment Share on other sites More sharing options...
The Spadgent Posted December 29, 2016 Share Posted December 29, 2016 Blown away. Those wheels are something else. Amazing work. 1 Link to comment Share on other sites More sharing options...
invidia Posted December 30, 2016 Share Posted December 30, 2016 Great looking build. Those wheels are fantastic. 1 Link to comment Share on other sites More sharing options...
Bandsaw Steve Posted December 30, 2016 Share Posted December 30, 2016 Congratulations on a great job. I think the wheels are especially good - a good technique to know about. 😄👍 1 Link to comment Share on other sites More sharing options...
TheBaron Posted December 30, 2016 Share Posted December 30, 2016 Absolutely gorgeous work in all respects Adrian. I've seen the spoke technique before, but not done to this standard. Bravo! We were staying with a pal of mine back in the summer - a retired C&E officer - and he gave me a photocopy of the original customs paperwork he'd discovered in the archives, produced when Bleriot made the Channel crossing. It's a typically semi-farcical British piece of bureaucracy, being the report of the customs officer who visited Bleriot onsite on the day of the landing, annotated later by a case officer working out the implications of whether import duty was chargeable on anything! Tony 1 Link to comment Share on other sites More sharing options...
AdrianMF Posted December 30, 2016 Author Share Posted December 30, 2016 Thanks for all the kind comments! Inpact/Lindberg did all the heavy lifting for me on this one. I think it's my second 1/48 kit ever. A nice change and good fun. 1 hour ago, TheBaron said: I've seen the spoke technique before, but not done to this standard. Bravo! Well it's all about having the right high-tech, no-expense-spared equipment... That piece of balsa was last used to provide the blank for my Privateer tail turret! And strictly speaking, I guess he did import "one aeroplane, slightly used"! Regards, Adrian 1 Link to comment Share on other sites More sharing options...
stevej60 Posted December 30, 2016 Share Posted December 30, 2016 Superb build and finish Adrian,some great detailing adds to the finish. 1 Link to comment Share on other sites More sharing options...
Sergey Posted January 5, 2017 Share Posted January 5, 2017 1 Link to comment Share on other sites More sharing options...
Jessica Posted January 5, 2017 Share Posted January 5, 2017 I'm going to have to steal that spoke-making idea to do my kits. I've finally managed to assemble the whole collection of Inpact/Pyro/Lindberg "Magnificent Men" models and have been at a loss as to how to do a dozen wire-spoked wheels until now. These are delightfully delicious, but the price for sufficient wheels for all is rather more than I care to pay. 2 Link to comment Share on other sites More sharing options...
AdrianMF Posted January 6, 2017 Author Share Posted January 6, 2017 (edited) I'm glad I was sitting down when I got to the price!! The method I used is really easy and I got some "good enough" results in an hour or so, which is what I wanted from a quick build. With more care I'm sure they will turn out a lot nicer than mine, and you could go for a double sided wheel too (mine was flat). One thing I think is important for those kits is to have a good idea of how the light falls on (or through) the fabric. I'm not sure that the almost-white rib positions that I used quite work, and I will go darker next time, especially for the ribs underneath. I need to go back and look at my photos of the real ones in museums again... Hope you enjoy making yours! Regards, Adrian Edited January 6, 2017 by AdrianMF 1 Link to comment Share on other sites More sharing options...
Vadim Posted April 3, 2017 Share Posted April 3, 2017 Hey Adrian. While rigging my Swordfish I was wandering through BM and found this beautiful build! Dunno how I missed it. I'm not a fun of this era, but this is an amazing work. 1 Link to comment Share on other sites More sharing options...
