Solo 962 Posted December 24, 2016 Share Posted December 24, 2016 This is my first Russian aircraft ever built, I am making it just for order, not for me. The model must be good looking (or just impressive), not so dirty, in flight pose, fully armed. Ok, so I am doing it. Zvezda made very nice, good detailed kit, but the problem is the surface of the hull, especially vertical planes - you can find there very rough surfaces in many places. Especially on the sides of engine nacelles. There are also a little bit to wide panel lines, very shallow, so I believe it could be a problem during wash time. We will see. I have started the cockpit, as usually. The cockpit is very simplified, so few things should be made from sratch. Instrumental panel is just a plane piece of plastic, there is only decals with all displays and instruments. The quality of decals is very nice. I have added some details onto antiglare shield, and later I am going to make air-conditioning device inside the canopy. Air intakes. The technically those parts are made very well, generally the fit of all parts is just perfect. I prepared something I can find on the bottom of those intakes, kind of lattice - using jut piece of polistyren and masks. It is much easier then paint it inside the inlets. Inlets are painted and ready to assemble... ...and assembled. The cockpit is ready and in place. The same is with inlets. Finally the hull is glued and ready for next steps. The fit is, once again, just perfect. I am really surprised of this good engineering of Zvezda. 6 Link to post Share on other sites
ya-gabor 1,163 Posted December 24, 2016 Share Posted December 24, 2016 Nice work! Best regards Gabor 1 Link to post Share on other sites
Solo 962 Posted December 25, 2016 Author Share Posted December 25, 2016 I stopped by for a while to paint exhaust nozzles. Usually the most challenging part in models of Su-33 are engine covers and exhaust. Really difficult but almost always not really succesfully reproduced on models. I hope I will make it better. I have started with light metalic colour. Then I have added some oil paint. And some Alclad laquers. And the same with second half of those parts. Result is not so bad I believe. 6 Link to post Share on other sites
Centollaman 6 Posted December 25, 2016 Share Posted December 25, 2016 Like a surgeon!! 1 Link to post Share on other sites
Christer A 5,276 Posted December 25, 2016 Share Posted December 25, 2016 Those exhausts are something extra! 1 Link to post Share on other sites
Solo 962 Posted December 26, 2016 Author Share Posted December 26, 2016 (edited) Thank you guys. For the first time I am going to use black basing technique. I hope it is worth of such lot of work. So, I used Gunze black primer on the whole body of model. Also painted all missiles I am going to use. Then I used first (gray) colour: mixed Gunze C307 and C308 (1:1) on the bottom surfaces and grey parts of camouflage on the upper surfaces. Really lot of work... Here you can see the comparison: how big is this Su-33... And then second and third colours: (Gunze H025 and H045 1:1, and the dark blue marble is Gunze GX-5). Edited December 26, 2016 by Solo 7 Link to post Share on other sites
Solo 962 Posted December 30, 2016 Author Share Posted December 30, 2016 Here are the next steps. First colour applied. Miexed Gunze H307+H308 (3:2). I have also made all weapons. Second colour: Gunze H025+H045 (1:1). The missiles with decals applied. Final masking and the last colour (Tamiya XF8). And... flight pose. 9 Link to post Share on other sites
Solo 962 Posted January 13, 2017 Author Share Posted January 13, 2017 Getting closer to the end. This time - the decals. Very good decals, thin and strong, easy to apply. 9 Link to post Share on other sites
mrobeson 49 Posted January 14, 2017 Share Posted January 14, 2017 That is absolutely beautiful. The black basing looks fantastic with the camo 1 Link to post Share on other sites
Valkyrie 4,286 Posted January 17, 2017 Share Posted January 17, 2017 Wow, quick work, super results, black basing looks like it works a treat, i have only just discovered using base coat.. 1 Link to post Share on other sites
Solo 962 Posted February 13, 2017 Author Share Posted February 13, 2017 (edited) After a long break I have just finished engine cowlings. It was not so easy to make it like this, but I hope you like it. Engine exhausts are just dry fitted. Top: Bottom: I also try to prepare the stand: Edited February 13, 2017 by Solo 5 Link to post Share on other sites
PanzerG 135 Posted February 13, 2017 Share Posted February 13, 2017 Your flanker is beautiful! And the black basing method works very well the way you do it. Really nice! PZR 1 Link to post Share on other sites
NontasB 482 Posted February 13, 2017 Share Posted February 13, 2017 Excellent build!!! I'm a big fan of your work!! Regards, Nontas 1 Link to post Share on other sites
Valkyrie 4,286 Posted February 13, 2017 Share Posted February 13, 2017 Wow that burnt metallic blue on exhaust nozzles, looks like you could lick your finger touch it and it would go tssssssss. Lovely work! A beaut so far 1 Link to post Share on other sites
Valkyrie 4,286 Posted February 13, 2017 Share Posted February 13, 2017 Solo, what is that blue colour? Thanks 1 Link to post Share on other sites
Solo 962 Posted February 13, 2017 Author Share Posted February 13, 2017 Blue colour on nozzle petals is Alclad's Hot Metal Blue (and also the Violet), painted onto the bright metal background with a little W&N french ultramarine oil paint dabs. On engine cowlings there are mostly Mr. Paint colours, including Burnt Metal Blue and Violet. Link to post Share on other sites
Valkyrie 4,286 Posted February 14, 2017 Share Posted February 14, 2017 It's a great effect you have Solo, outstanding job, its art 1 Link to post Share on other sites
Flyingdutchman 195 Posted February 14, 2017 Share Posted February 14, 2017 Very nice build and dito paint effects, inspiring to see. Evert 1 Link to post Share on other sites
Solo 962 Posted February 26, 2017 Author Share Posted February 26, 2017 Plane has bee assembled, and now is ready for wash and weathering. 2 Link to post Share on other sites
Robertone139 150 Posted February 26, 2017 Share Posted February 26, 2017 Superb. 1 Link to post Share on other sites
Solo 962 Posted March 5, 2017 Author Share Posted March 5, 2017 (edited) My Su-33 is ready now. You can find it in my RfI here: Edited March 5, 2017 by Solo Link to post Share on other sites
