paj66 Posted March 3, 2020 Share Posted March 3, 2020 I’ve just started this kit. I read Calum’s build and have now seen yours - now a bit disheartened by the work ahead!! I’m making a model for a good friend of mine, of the one he was shot down in over Gorazde in 1994. Amongst many other challenges, I’m trying to establish the best paint to use for the correct colour scheme during that conflict.... Beautiful build and thank you for picking out the various errors as well as the improvements that can be made. Link to comment Share on other sites More sharing options...
Pappy Posted March 3, 2020 Author Share Posted March 3, 2020 (edited) On 3/3/2020 at 6:46 PM, paj66 said: I’ve just started this kit. I read Calum’s build and have now seen yours - now a bit disheartened by the work ahead!! I’m making a model for a good friend of mine, of the one he was shot down in over Gorazde in 1994. Amongst many other challenges, I’m trying to establish the best paint to use for the correct colour scheme during that conflict.... Beautiful build and thank you for picking out the various errors as well as the improvements that can be made. G'day, It is actually a very good kit, and detail wise much better than the Tamiya or Airfix offering. The Airfix kit has a good shape but lacks recessed panel lines and the fit is not so good either. The Kientic kit does have a few traps, hopefully between Calum's build and mine, you canm be prepared for the issues. The wing underside seam was probably the most problematic fit issue, the remaining issues relate to detail corrections which is a matter of personal taste and abaility. I am looking forward to (hopefully) the release of the GR.3 variant which is the one I really, really wanted all along. Hopefully, Kinetic will correct some of the shortcomings by then as there will be a large degree of commonality sprue wise between the FRS.1 and the GR.3. Hopefully they will realise the GR.3 has different wing pylons, speed brake etc. cheers, Pappy Edited February 8, 2023 by Pappy Link to comment Share on other sites More sharing options...
NG899 Posted March 3, 2020 Share Posted March 3, 2020 SHARs were overall satin Dark Sea Grey at that time with Light Aircraft Grey inside the intakes. Being a brush-painting traditionalist, I always use Humbrol enamels thinned 10% and with a dash of white added for scale effect. For the final satin varnish coat, Vallejo acrylic. Hope that helps Nick Link to comment Share on other sites More sharing options...
ERK Posted July 20, 2020 Share Posted July 20, 2020 I too have just started building this - one glearing thing has come to me by reading this excellent build - on the front seam of the wing join behind the canopy, I always thought the gap either side of the center small square piece was a design fault (so I filled my mine with putty and sanded smooth) I didn't know they were to take the stubs of the two arials that dissapear under the canopy when it pushed back into its open position.☹️ Erk. Link to comment Share on other sites More sharing options...
Pappy Posted July 20, 2020 Author Share Posted July 20, 2020 19 hours ago, ERK said: I too have just started building this - one glearing thing has come to me by reading this excellent build - on the front seam of the wing join behind the canopy, I always thought the gap either side of the center small square piece was a design fault (so I filled my mine with putty and sanded smooth) I didn't know they were to take the stubs of the two arials that dissapear under the canopy when it pushed back into its open position.☹️ Erk. G'day Erk, It sounds recoverable, why not just cut or sand off the locating pegs underneath each antenna and just butt-glue in place? If you use a slow setting glue you should have a little working time to ensure they are both straight and aligned cheers, Pappy Link to comment Share on other sites More sharing options...
ERK Posted July 20, 2020 Share Posted July 20, 2020 (edited) 1 hour ago, Pappy said: G'day Erk, It sounds recoverable, why not just cut or sand off the locating pegs underneath each antenna and just butt-glue in place? If you use a slow setting glue you should have a little working time to ensure they are both straight and aligned cheers, Pappy Thank you Pappy, yep thats just what I did - I sat them both in a dab of CA, seems to have done the trick - Erk. Edited July 20, 2020 by ERK 1 Link to comment Share on other sites More sharing options...
Cris Garcia Posted November 12, 2020 Share Posted November 12, 2020 On 26/08/2017 at 08:19, Pappy said: You are very welcome Martian Glad you are all enjoying the build, Today's update, All the fiddly bits done Better pics when I get the chance Pappy Pappy, what an incredible piece or art you did with the SHAR! Outstanding! I did the same kit a few months ago... and tried my best! But the details in yours are stunning. Do you post the final photos in other section? I can't find any related post with your SHAR. Best regards from Chile! Cris. PS: to the banned argentinian "amigo", yes, we chileans speak the most intricate spanish in Latin America, by far (intonation and pronunciation). Peruvians and Colombians, the best. Link to comment Share on other sites More sharing options...
Paulaero Posted November 12, 2020 Share Posted November 12, 2020 On 30/08/2017 at 19:31, NG899 said: Hi Pappy, the yaw vane swivels freely on top of the pylon so it always points into wind. So, as Bootneck says, if parked and the wind across the deck is coming from the stern, then the vane could be pointing as is. I would say that would have been a rare occurrence as during ops the ships would be moving forward pretty constantly to avoid being a sitting target and to avoid the SHARs having to do crosswind vertical landings wherever possible. Harriers are very delicate in the hover in high crosswinds, which is why the yaw vane was invented for them, to allow the pilot to keep the jet pointed into wind. Hi Bootneck, an interesting painting of Hermes; those two must have been very low on fuel to approach from there. Yes, cross-deck landings (i.e. 90-degrees across the deck, aiming for just ahead of the flyco in the island or aft of the island - where no aircraft were parked (not as shown), were used when high crosswinds made a normal bow-facing landing impractical for SHARs. The normal approach, as I'm sure you know, was parallel to the carrier's port side over the sea, hover level with mid-ships where the effects of roll/pitch are minimal, then transition over the deck and get it down! SHARs would not have taken off loaded on ops during Op Corporate without using the ski-jump. The fleet was kept well away from the islands, so aircraft on CAP had a fair haul to station and a vertical take-off would have needed a lot of fuel, resulting in minimal time over the islands for the effort expended of getting two winders there. Without the ski-jump a stern take-off would have resulted in a ditching as the aircraft would not have reached flying speed for the wings to work and, without the upward trajectory, even a hit to full down nozzles by the pilot would not have enabled a fully loaded SHAR to avoid the briny beyond the stern. That's why all the Invincible class plus Hermes had ski jumps fitted in the first place, to facilitate the rolling short take-off getting them airborne rather than waterborne. Dinner calls! Cheers for now. Nick Great bit of info Nick Link to comment Share on other sites More sharing options...
Pappy Posted November 12, 2020 Author Share Posted November 12, 2020 6 hours ago, Cris Garcia said: Pappy, what an incredible piece or art you did with the SHAR! Outstanding! I did the same kit a few months ago... and tried my best! But the details in yours are stunning. Do you post the final photos in other section? I can't find any related post with your SHAR. Best regards from Chile! Cris. PS: to the banned argentinian "amigo", yes, we chileans speak the most intricate spanish in Latin America, by far (intonation and pronunciation). Peruvians and Colombians, the best. G'day Chris, Thanks very much, you are very kind. I don't think I did as I never got around to finishing the base, one day. As for Uncle, he is not banned but I do find his written accent annoying at times. To be clear, I am not mocking his english as a non-native speaker, I am quite happy to make allowances for those who speak english as a second, (or even third, fourth etc.) language, I wish I could speak multiple languages and his english would be far superior to my non-existent spanish, but when he chooses to talk in babble I find it grating, especially when he can communicate perfectly well when replying to others. All the best, Pappy 2 Link to comment Share on other sites More sharing options...
Cris Garcia Posted November 13, 2020 Share Posted November 13, 2020 On 12/11/2020 at 16:39, Pappy said: G'day Chris, Thanks very much, you are very kind. I don't think I did as I never got around to finishing the base, one day. As for Uncle, he is not banned but I do find his written accent annoying at times. To be clear, I am not mocking his english as a non-native speaker, I am quite happy to make allowances for those who speak english as a second, (or even third, fourth etc.) language, I wish I could speak multiple languages and his english would be far superior to my non-existent spanish, but when he chooses to talk in babble I find it grating, especially when he can communicate perfectly well when replying to others. All the best, Pappy Well, I can wait a little more to see those final photos! 😉 Thanks again, abrazo! Link to comment Share on other sites More sharing options...
Sturmovik Posted November 15, 2020 Share Posted November 15, 2020 On 12/11/2020 at 16:39, Pappy said: As for Uncle, he is not banned He is, his profile says "banned" in big letters. How does the kit fit together? I would like to buy a Harrier for my 1982 collection (currently I have an A-4P and a Canberra). Link to comment Share on other sites More sharing options...
Tojo72 Posted November 15, 2020 Share Posted November 15, 2020 This one looks real good lots of great detail.Love the "Sharkey Ward" looking figure.Whose plane is it anyway? Link to comment Share on other sites More sharing options...
Pappy Posted November 15, 2020 Author Share Posted November 15, 2020 5 hours ago, Sturmovik said: He is, his profile says "banned" in big letters. How does the kit fit together? I would like to buy a Harrier for my 1982 collection (currently I have an A-4P and a Canberra). Oh, I didn't know that, I wonder who he upset? As for how the kit fits together, I am sure that you will find the answer in the preceding pages but basically, it does not fall together but it does fit well, you will need to do some work but it looks good OOB, even better with extra details. Don't waste money on decals, the kit ones are awesome 3 hours ago, Tojo72 said: This one looks real good lots of great detail.Love the "Sharkey Ward" looking figure.Whose plane is it anyway? I am not sure I understand the question Tojo? Link to comment Share on other sites More sharing options...
Tojo72 Posted November 15, 2020 Share Posted November 15, 2020 6 hours ago, Pappy said: I am not sure I understand the question Tojo? Does it represent any one pilots plane from the war,names,kill markings, or the like Link to comment Share on other sites More sharing options...
Pappy Posted November 15, 2020 Author Share Posted November 15, 2020 21 minutes ago, Tojo72 said: Does it represent any one pilots plane from the war,names,kill markings, or the like Aaah gotcha, Well the pilots don't get their own jet, even if a jet has a pilot's name it doesn't mean that it is only flown by that pilot. Also. during operations, it is typical for units to tone down even remove or paint over pilot names and unit insignia, pilots will also remove unit badges and name badges from their flightsuits as well. The jet I have made was flown by 'Sharkey' Ward and other pilots from 800SQN embarked upon HMS Invincible during the war. Most people would refer to it as Sharkey's jet but the reality was a pilot flew whatever jet was available at the time. A Quick google search would get you plenty more detailed info, cheers, Pappy 1 1 Link to comment Share on other sites More sharing options...
paj66 Posted January 16, 2021 Share Posted January 16, 2021 Hi Pappy - hope you’re well and enjoying building the newly released GR3! So my build is progressing and I’m looking at assembling the wings. I was watching a GR3 online build the other day and the advice was to sand to shape the outer tip of the lower wings so they didn’t overlap. Thing is, the way that section of the wing is moulded looks very deliberate, not a moulding error. That said, all the reference photos I see, that section is indeed flush. What’s your take? Also, how did you resolve the gap between the aileron hinges and the ailerons eventually? All the best Patrick Link to comment Share on other sites More sharing options...
paj66 Posted January 16, 2021 Share Posted January 16, 2021 On 3/3/2020 at 9:51 PM, NG899 said: SHARs were overall satin Dark Sea Grey at that time with Light Aircraft Grey inside the intakes. Being a brush-painting traditionalist, I always use Humbrol enamels thinned 10% and with a dash of white added for scale effect. For the final satin varnish coat, Vallejo acrylic. Hope that helps Nick Nick - thanks for this - much appreciated! Link to comment Share on other sites More sharing options...
Biggles87 Posted January 28, 2021 Share Posted January 28, 2021 I hadn't realised that this was still going, it's dropped off my ' Content I post in ' so I'd better go back a few pages and catch up; John 1 Link to comment Share on other sites More sharing options...
Pappy Posted March 7, 2023 Author Share Posted March 7, 2023 On 1/28/2021 at 11:03 PM, Biggles87 said: I hadn't realised that this was still going, it's dropped off my ' Content I post in ' so I'd better go back a few pages and catch up; John G'day John, I was intending on doing a deck scene but lost interets however, afyer receiving some great info from NG, I may have to revisit the idea, cheers, Pappy Link to comment Share on other sites More sharing options...
