Falklands Sea Harrier - La Muerta Negra
Pappy
22 hours ago, Martian Hale said:
The weathering on those drop tanks looks pretty much spot on to me. :goodjob:
Martian
Thanks Martian,
G'day people,
I have painted a few more basic colours onto the SHAR, I think it may be time for a clear coat,
cheers,
Pappy
  • Like 11
G'day people,
I managed to get the pylons glossed up,
The pylons  were given a quick brush over with Future then, while still wet, the decals were applied and they were given another brush over with Future. I find that this 'Future sandwich' works very well when using small stencils which can be prone to silvering,
cheers,
Pappy
  • Like 9
  • 2 months later...
G'day people,
Still limping along,
I have added the makeshift chaff fit to the airbrake well.
The SHAR was not equipped with a dedicated CMDR system when the task force set sail, so in something akin to a Blue Peter episode, an improvised system consisting of chaff bundles  stuffed into the airbrake well was devised. The bundles were held in place by welding rods connected to the airbrake door by wire. when the airbrake was opened, the rods were released allowing the chaff to be deployed,  crude but effective!
cheers,
Pappy
G'day people,
She is sitting on her pins and decals are on
Plus a little mock-up just because!
enjoy
Pappy
  • Like 17
11 hours ago, Martian Hale said:
I am, big time!
Martian
You are very welcome Martian
11 hours ago, exdraken said:
Great to see she progressing!
I am, big time!
Martian
11 hours ago, The Spadgent said:
Excelent work. :clap:
John
Glad you are all enjoying the build,
Today's update,
All the fiddly bits done
Better pics when I get the chance
Pappy
  • Like 20
Really nice build!!!
Nice detail and the pilot is amazing! Paint chips are very realistic as well as the tanks and loads.
I love that tractor.Must be the same used by Ex-FAAWAFU for his Sea King. What manufacturer makes it? I've got several FAA subjects to do and I'd like to add it to one of them!
What will it be your next build?
14 hours ago, Courageous said:
Excellent work Pappy.
Thanks very much!
Grazie mille!
The tractor is included in the 1/48 Skunkworks models Royal Navy tractors set (48017). There are two tractors in each kit and the decals include stencils for both the old GSE yellow scheme and the current green one. It builds up very nicely and includes some ground crew, a tow bar and ladders, but make sure the ladder is installed on the right side of the cockpit as the pictures on the box are wrong. Here is a linky to some more pictures of the tractor if you are interested:
http://www.britmodeller.com/forums/index.php?/topic/234995755-vickers-royal-navy-deck-tractor/&tab=comments#comment-2234109
cheers,
Pappy
Edited by Pappy
5 minutes ago, Pappy said:
Thanks very much!
Grazie mille!
The tractor is included in the 1/48 Skunkworks models Royal Navy tractors set (48017). There are two tractors in each kit and the decals include stencils for both the old GSe yellow scheme and the current green one. It build up very nicely and includes some groundcrew, a towbar and ladders, but make sure the ladder is installed on the right side of the cockpit as the pictures on the box are wrong. Here is a linky to some more pictures of the tractor if you are interested:
cheers,
Pappy
Really helpful!!!Thanks Pappy!!!
Very nice FRS1 Pappy !
One question... why is Invincible steaming in reverse?
How do I know?
The yaw vane ahead of the canopy should be orange section forward, an easy fix to make.
Unless Invincible is steaming backwards, of course... :wonder:
Nick
Not necessarily;  the aircraft is on the deck and could be facing aft.  Also, due to the irregular course corrections that the ships had to take (zig-zagging) the ship could be sailing with the wind from aft; even during flying stations, and this would mean the aircraft took off and recovered facing aft.
Here is a painting depicting such as scene, showing HMS Hermes with one FRS.1 just landed and another about to be recovered; both pointing aft.
How do I know?
Nick
Cheers Nick!
I was just thinking I wanted the yaw vane to be pointing in a random direction, as if it was being pointed in whatever direction the prevailing wind direction on the flight deck was .What you said makes sense of course. Bootneck's comments also make sense, so I will support what he said!
Does this mean that the yaw vane would be spring loaded back to the 'normal' position unless acted upon by a yaw input
Thanks Bootneck!
I will eventually place the kit on a scenic base with a tow motor, I will just have to add that it is being towed 'downwind' now,
cheers,
Pappy
Hi Pappy,  the yaw vane swivels freely on top of the pylon so it always points into wind.  So, as Bootneck says, if parked and the wind across the deck is coming from the stern, then the vane could be pointing as is.  I would say that would have been a rare occurrence as during ops the ships would be moving forward pretty constantly to avoid being a sitting target and to avoid the SHARs having to do crosswind vertical landings wherever possible.  Harriers are very delicate in the hover in high crosswinds, which is why the yaw vane was invented for them, to allow the pilot to keep the jet pointed into wind.
Hi Bootneck, an interesting painting of Hermes; those two must have been very low on fuel to approach from there.  Yes, cross-deck landings (i.e. 90-degrees across the deck, aiming for just ahead of the flyco in the island or aft of the island - where no aircraft were parked (not as shown), were used when high crosswinds made a normal bow-facing landing impractical for SHARs.  The normal approach, as I'm sure you know, was parallel to the carrier's port side over the sea, hover level with mid-ships where the effects of roll/pitch are minimal, then transition over the deck and get it down!
SHARs would not have taken off loaded on ops during Op Corporate without using the ski-jump.  The fleet was kept well away from the islands, so aircraft on CAP had a fair haul to station and a vertical take-off would have needed a lot of fuel, resulting in minimal time over the islands for the effort expended of getting two winders there.  Without the ski-jump a stern take-off would have resulted in a ditching as the aircraft would not have reached flying speed for the wings to work and, without the upward trajectory, even a hit to full down nozzles by the pilot would not have enabled a fully loaded SHAR to avoid the briny beyond the stern.  That's why all the Invincible class plus Hermes had ski jumps fitted in the first place, to facilitate the rolling short take-off getting them airborne rather than waterborne.
Dinner calls!  Cheers for now.
Nick
Yep; I was ignorant of my own knowledge (which I shall put down to age-related :undecided:) of the fact that SHAR's needed the full run and the ski-slope when fully armed and/or fuelled.  I was just using the view of the painting "H.M.S. Hermes in action off the Falklands", by John Hesseltine, as an example of these aircraft not always pointing for'ard/aft.
Notwithstanding these comments; your model is a really outstanding piece of work Pappy!
cheers
Mike
16 hours ago, James G said:
Very nice work Pappy, look forward to seeing the finished build on a base.
Thanks James,
I am working on it,
cheers,
Pappy
  • 2 months later...
  • Pappy changed the title to Falklands Sea Harrier - La Muerta Negra
