2016 Builds From Plasto
Plasto
Hi,
Here is a selection of Stuff I've built in 2016..
The Year Started with a build of the Airfix 1/48 Bedford MWD with a few tweaks..
MWD%20finished%2024th%20Jan%202016%20sid
Followed by the Tamiya 1/48 IS2...
IS-2%20finished%20Jan%2021st%201%201%20o
Spurred on by Tanks I also Built a DML 1/72 Elefant....
6D75E744-3731-4A17-8A7B-D3D72A929F4D_zps
and a 1/72 A7V by Emhar...
I also built the cool 1/72 Bandai Y wing...
Followed by a F4U-5N in 1/72 for the Corsair GB its the Highplanes kit...
I also Finished a few Spitfires for Various GB's that celebrated Edgar...
Here is the 'unbuildable' Airfix VC / Seafire in 1/48
and Tamiya's VB Trop kit... Which apparently also has issues but looks nice and builds up well..
And  finally on 1/48 spitfires Airfix's Seafire XVII also in 1/48 which apparently also has 'issues' as a kit. But seems ok to me..
I switched back to 1/72 and finished a Hasegawa F-16A Netz with a few modifications and Condors MiG-25U
Back to Armour for the GPW GB and a Tamiya 1/48 T-34/57..
And a fun build in the Bandai box scale Imperial Star Destroyer..
I then got out of my comfort Zone into 1/32 and three builds of classic Hasegawa kits from the 70's All OOB for the most part.
Spitfire VI
Me-109 E
And the ME-163 Komet..
and the most recent GB completion the Hobbyboss Easy Kit P-51D
Followed by the classic 1/72 Esci F-100 D
My final Completion for 2016 being the Tamiya 'Birdcage' Corsair in 1/48 This has been sitting 90% finished since June of a bit of a push now gets it done.
There you go.. I have had fun hope you like em..
Plasto...
Edited by Plasto
added the final one more for 2016..
  • Like 22
4 hours ago, Plasto said:
Thanks... i just finished the F-100 so added that to the list...
Plasto
That F-100 is simply spectacular! The NMF is superb, I like the burnt metal effects near the exhaust very much. How did you do it? Did you use Alclad?
Jaime
Jaime
4 hours ago, Lightningboy2000 said:
Another F-100 Triple Zilch - Snap!
Superb collection of builds for 2016. :-)
Martin
Hi,
Thanks for the feedback. The finish is indeed Alclad for the main airframe. Polished Aluminium, semi matte Aluminium and some Mr Colour SM SS all on a polished base of Alclad gloss black primer.
The only downside being the Polished Aluminium is quite soft and doesn't bear handling that well.
The rear panels are in MR C SM Ti with heat effects using Tamiya clear enamels and Alclad Jet exhaust
HTH
Plasto
Edited by Plasto
Thanks for the info.  Just a few additional questions: did you apply the decals directly on the metal paints or did you use a gloss coat?  Did you use decal solutions?  Did you apply any varnish coat in the end?
I still have to build a NMF aircraft with different shades of metal, so I'd like to know the best way to preserve the metal shades and applying  the decals properly.
Thanks again.
Jaime
Hi,
on this build the decals are are directly applied to the paint. They are settled with microsol and set.
The P 51 is painted in Tamiya AS-12. Which is gloss coated with x-22 Decals applied and sealed and then a coat of semi gloss made from Tamiya x-22 and Tamiya Matt varnish all thinned with lacquer thinners.
I've tried lots of different ways of doing NMF my current favourite is using Gunze Super Metallics.
HTH
Plasto
Edited by Plasto
On 24/12/2016 at 01:42, Plasto said:
No problem,
drop me a PM if you want to discuss further..
cheers
Plasto
Thanks for the kind offer,  Plasto. I'll certainly get back to you some time in 2017, as I intend to build a P-51D in NMF
Jaime
Lovely collection there. Your finishing skills are exemplary with nicely judged weathering effects. Although not a "tankie" myself, I am particularly fond of that A7V "Cyklop" - beautifully done in that scale.
ATB
Rick
