Crossiant Oliver Posted May 6, 2018 Share Posted May 6, 2018 is there still room? I got an airfix P-47 here, 2 Link to comment Share on other sites More sharing options...
TEMPESTMK5 Posted May 11, 2018 Author Share Posted May 11, 2018 Good evening Oliver Welcome aboard Patrice Link to comment Share on other sites More sharing options...
zegeye Posted May 14, 2018 Share Posted May 14, 2018 (edited) Last time I didn make it on time. But my N is done. Now I do not know if I should take part. But I have some other Jugs ready to go. Edited May 14, 2018 by zegeye Link to comment Share on other sites More sharing options...
TEMPESTMK5 Posted May 16, 2018 Author Share Posted May 16, 2018 (edited) On 14/05/2018 at 17:54, zegeye said: Last time I didn make it on time. But my N is done. Now I do not know if I should take part. But I have some other Jugs ready to go. Dzień dobry Zegeye Hello and Welcome to this Gb If you have some other Jugs ready to go you are more than welcome to join us .. Best regards Patrice Edited May 16, 2018 by TEMPESTMK5 1 Link to comment Share on other sites More sharing options...
MarkSH Posted May 16, 2018 Share Posted May 16, 2018 Got the Tamiya 1/48 Bubbletop kit at the Glos IPMS show at the weekend so I all 'Jugged-up' and ready go! 1 Link to comment Share on other sites More sharing options...
Hardtarget Posted May 16, 2018 Share Posted May 16, 2018 Im in with a tamiya 1/72 1 Link to comment Share on other sites More sharing options...
wellzy Posted May 20, 2018 Share Posted May 20, 2018 Here`s the plan ,hope to get two build`s in Cheer`s Wellzy 2 Link to comment Share on other sites More sharing options...
TEMPESTMK5 Posted May 20, 2018 Author Share Posted May 20, 2018 Hi Wellzy Very nice choice Patrice Link to comment Share on other sites More sharing options...
wellzy Posted May 20, 2018 Share Posted May 20, 2018 just work out how to get then on the site lol Link to comment Share on other sites More sharing options...
wellzy Posted May 28, 2018 Share Posted May 28, 2018 (edited) My last Bolt build Edited May 28, 2018 by wellzy 3 Link to comment Share on other sites More sharing options...
zegeye Posted May 29, 2018 Share Posted May 29, 2018 And this is my N version I've built last time. 1 Link to comment Share on other sites More sharing options...
TEMPESTMK5 Posted May 30, 2018 Author Share Posted May 30, 2018 Good morning Zegeye Very good job 👍 Patrice Link to comment Share on other sites More sharing options...
wellzy Posted June 1, 2018 Share Posted June 1, 2018 (edited) Change of plan built this Tony some years ago so time for a new one https://flic.kr/p/26DHS2u Edited June 1, 2018 by wellzy 1 Link to comment Share on other sites More sharing options...
RJ-WobblyHands Posted June 16, 2018 Share Posted June 16, 2018 Real Life got in the way - I missed the Radial Rocks GB so my Jug needs building , Tamiya 1/72 P-47D , currently deciding which squadron /pilot decals to source or make - bearing in mind for accuracy that Tamiya 1/72 razorback kit is block10 - block21 please count me in if space for a little one... Link to comment Share on other sites More sharing options...
Tbolt Posted June 17, 2018 Share Posted June 17, 2018 15 hours ago, RJ-WobblyHands said: Real Life got in the way - I missed the Radial Rocks GB so my Jug needs building , Tamiya 1/72 P-47D , currently deciding which squadron /pilot decals to source or make - bearing in mind for accuracy that Tamiya 1/72 razorback kit is block10 - block21 please count me in if space for a little one... I always though the Tamiya kit was closer to a D-20 to a D-22. You can't do earlier blocks because the engine has got Turtleback mags on, but of course it's an easy fix. With the engine fixed that'll give you a D-10 to D-16, then it's only a case of fixing cowl flaps aircraft and removing oil cooler deflector plates ( some aircraft had the mods done so not always needed ) to make any earlier bugled keel P-47. Add an asymmetric prop ( factory fit, may have different prop ) and you can do the D-23 as well. Link to comment Share on other sites More sharing options...
TEMPESTMK5 Posted June 18, 2018 Author Share Posted June 18, 2018 On 17/06/2018 at 00:05, RJ-WobblyHands said: Real Life got in the way - I missed the Radial Rocks GB so my Jug needs building , Tamiya 1/72 P-47D , currently deciding which squadron /pilot decals to source or make - bearing in mind for accuracy that Tamiya 1/72 razorback kit is block10 - block21 please count me in if space for a little one... Hello RJ-WobblyHands Of course you are welcome abord this Gb ... I agree with Tbolt the Tamiya Razorback is closer to a D-20 to a D-22 Jug .. I am sure you will find good references on the net .. Best regards Patrice Link to comment Share on other sites More sharing options...
RJ-WobblyHands Posted June 18, 2018 Share Posted June 18, 2018 4 hours ago, TEMPESTMK5 said: Hello RJ-WobblyHands Of course you are welcome abord this Gb ... I agree with Tbolt the Tamiya Razorback is closer to a D-20 to a D-22 Jug .. I am sure you will find good references on the net .. Best regards Patrice Or after some interweb reading I can use the kit decals and keep with my overall build theme (WW2 USAF based in Essex) . In the kit is 'Little Chief' 276179 flown by Lt Frank Klibbe 61st FS/ 56th FG - the markings show 5 victories , this was his 3rd and final P-47D , he received the plane whilst the 56th FG was based at Halesworth but he was still flying it when the unit moved to Boxted 18/19th April 1944 - his 6th and 7th victories coming in early May 1944 And an excuse to build a 2nd Jug 'Bubbletop' in 56th FG colour's either the obvious one Gabreski's or the Group Commander Zemke's. The planes were delivered to Boxted mid May 1944 1 Link to comment Share on other sites More sharing options...
Tbolt Posted June 19, 2018 Share Posted June 19, 2018 (edited) Not long before the start of this one, I better make sure I have everything I need. Better check if I got a P-47 Kit! Oh wait..... ( Most of the Tamiya 1/72nd scale kits have two in each box ). Not sure what to build yet. I'm still working on the Tamiya P-47N, so space is a bit limited, I might go for a 1/72nd scale kit. Edited June 19, 2018 by Tbolt 1 1 2 Link to comment Share on other sites More sharing options...
MarkSH Posted June 19, 2018 Share Posted June 19, 2018 My missus questioned the need for two repeat kits in my stash, I think I may have to show her that photograph. 1 Link to comment Share on other sites More sharing options...
Tbolt Posted June 19, 2018 Share Posted June 19, 2018 (edited) 35 minutes ago, MarkSH said: My missus questioned the need for two repeat kits in my stash, I think I may have to show her that photograph. Do point out to her that there were over 15,600 P-47's made and there's lot of colour schemes and cool nose art, otherwise it would just seem weird Edited June 19, 2018 by Tbolt 1 Link to comment Share on other sites More sharing options...
MarkSH Posted June 19, 2018 Share Posted June 19, 2018 She thinks we're all weird anyway! 2 Link to comment Share on other sites More sharing options...
TEMPESTMK5 Posted June 20, 2018 Author Share Posted June 20, 2018 16 hours ago, Tbolt said: Not long before the start of this one, I better make sure I have everything I need. Better check if I got a P-47 Kit! Oh wait..... ( Most of the Tamiya 1/72nd scale kits have two in each box ). Not sure what to build yet. I'm still working on the Tamiya P-47N, so space is a bit limited, I might go for a 1/72nd scale kit. Good morning Tbolt WHAOU that'is what I call a very nice stash ..👍 I guess you have also various decals sheets ... Patrice 1 Link to comment Share on other sites More sharing options...
TEMPESTMK5 Posted June 20, 2018 Author Share Posted June 20, 2018 11 hours ago, MarkSH said: My missus questioned the need for two repeat kits in my stash, I think I may have to show her that photograph. Hi Mark Ask her if she really needs all these pairs of shoes ... Cheers Patrice 1 Link to comment Share on other sites More sharing options...
Tbolt Posted June 20, 2018 Share Posted June 20, 2018 12 hours ago, TEMPESTMK5 said: Good morning Tbolt WHAOU that'is what I call a very nice stash ..👍 I guess you have also various decals sheets ... Patrice I've got around 75 decal sheets for P-47's in 1/72 and 1/48, so maybe I should buy some more kits? 2 Link to comment Share on other sites More sharing options...
stevej60 Posted June 24, 2018 Share Posted June 24, 2018 Right forgot this one was due,no kit in the stash so better start looking around. Link to comment Share on other sites More sharing options...
