DIY Lightbox MK2
Following on from my rather disastrous conversion of IKEA Skubb Laundry Hampers into a photography lightbox: (in the end the fabric started to tear, and the lightbox was rather wibbly wobbly), here is my build log for my MK2!
Here is my purchased materials:
6 sheets of A1 foamcore board.
2 sheets of black a1 card, and 2 sheets of white a1 card (for the curved backdrop, plus spare incase it gets creased).
2ft 18W flourescent battens (will replace the tubes with daylight simulation tubes once I get it all wired up and running)
Now for lighting the interior I am going to fix the 2ft fluorescent strip lights to the roof of the light box. Hopefully this should give enough light which will reflect off the side walls to give a nice soft light.
Unless it would be better to cut a square section out of either end, cover with tissue paper, so that they could be illuminated by diffused light from desk lights?
Any other things I should consider? I'm aiming on building the light box to be ~2ft cube in size, as I do like building 1:12 scale cars! It should fit under my modelling desk when not in use, however perhaps I can build it so that it can be dismantled / folded away...
Even though the top lights will be soft I think you'll need two fill lights, from 45* each side low down.
I'm drawing my plans for a new light box too, the same size as yours.
I have a 18inch fabric cube which I light from above with a daylight LED light but I also need a frontal light to fill shadows etcetera.
I'd not use lamps from outside again. They're a pain plus they make the 2ft cube take up 3ft minimum side to side.
I'm checking out the possibility of using LEDs on a rope strip; up one side over the top and down other side, towards the front and another towards the rear.
If you can, make it so its permanately up, not foldable/dismantable, you'll loose its effectiveness
Got the top panel finished!
I was originally going to make the top solid, then I thought it'd be handy to be able to take photos from above, so I made a rectangular cutout.
What I'm thinking of doing is to cut squares out from either side panel, add some thin fabric (shower curtain material?). That way I can get some diffused fill lights either side by using my two anglepoise task lights which I have mounted either side of my desk.  This might be better, as it could be more controllable? Failing that I may "borrow" the led strip lights I added to the spray booth shroud...  Hmmm...
  • 6 months later...
