Gary w 1960 Posted November 20, 2016 Share Posted November 20, 2016 I would like to model an armoured vehicle. I love terrain building since the WW1 trench project at my daughters school inspired me to recreate a trench system about 30 by 20inches. I want a kit that is straight forward that will not require too much to get the parts to fit correctly. Any suggestions...whatever era...with or without figures....max scale 1/35 th. Will eventually start diorama build when I get to grips with the genre. kind regards Gary Link to comment Share on other sites More sharing options...
JackG Posted November 20, 2016 Share Posted November 20, 2016 For simplicity and ease of fit, can't go wrong with Tamiya. They do both 1/35 and 1/48, but the latter scale does not have as many kits to choose from. regards, Jack 2 Link to comment Share on other sites More sharing options...
bull-nut Posted November 20, 2016 Share Posted November 20, 2016 (edited) I second Tamiya, never built a Tamiya armour kit that didn't practically build itself. I prefer 1/48 myself, they are a little smaller, And the Link and Length tracks build up easily, but they also have fewer small, fiddly components. The range is still big enough that you should be able to find something you like, though be aware that many of the older armour kits in the 1/48 range have die-cast metal hulls, which can catch some people out. Check the kit description on the Tamiya website if you are unsure. Best of luck. Edited November 20, 2016 by bull-nut 1 Link to comment Share on other sites More sharing options...
Sgt.Squarehead Posted November 20, 2016 Share Posted November 20, 2016 I've only built one 1/35 kit, it was Tamiya, it fell together. I prefer 1/72 myself.....You might be surprised at just how good some modern Braille Scale kits are: http://henk.fox3000.com/index2.htm 2 Link to comment Share on other sites More sharing options...
Gary w 1960 Posted November 20, 2016 Author Share Posted November 20, 2016 3 hours ago, JackG said: For simplicity and ease of fit, can't go wrong with Tamiya. They do both 1/35 and 1/48, but the latter scale does not have as many kits to choose from. regards, Jack Thanks Jack, Tamiya does have a vast range. Link to comment Share on other sites More sharing options...
Gary w 1960 Posted November 20, 2016 Author Share Posted November 20, 2016 1 hour ago, Sgt.Squarehead said: I've only built one 1/35 kit, it was Tamiya, it fell together. I prefer 1/72 myself.....You might be surprised at just how good some modern Braille Scale kits are: http://henk.fox3000.com/index2.htm That link is one massive resource. Thanks. The size factor is attractive I will admit. 1 Link to comment Share on other sites More sharing options...
Sgt.Squarehead Posted November 21, 2016 Share Posted November 21, 2016 Yup, Henk's site is superb.....You should find every Braille kit ever made in there somewhere. You can find more detailed reviews here: http://www.onthewaymodels.com/ 1 Link to comment Share on other sites More sharing options...
Blaubar Posted November 21, 2016 Share Posted November 21, 2016 I'd suggest Trumpeters Ardelt Waffentrager. Perfect fit, easy to build and cheap. Can , but must not be, upgraded by PE parts (included in the kit). It is 1/35 scale. /Stefan As for trenches, check out the crazy Trench guy and his amazing detail. http://www.militarymodelling.com/forums/postings.asp?th=80609 1 Link to comment Share on other sites More sharing options...
Bonhoff Posted November 21, 2016 Share Posted November 21, 2016 1/35 Tamiya PzII. Kit is as old as the hills but still goes together really well in a couple of hours. And cheap as chips too. 1 Link to comment Share on other sites More sharing options...
Bullbasket Posted November 22, 2016 Share Posted November 22, 2016 My two centimes worth....Tamiya 1/35th. The M4 is long in the tooth but goes together well. Avoid at all costs, Bronco. Nothing wrong with the kits except from a newcomers point of view. They are overly complicated with some fiddly small pieces. Another good one would be Italeri's Crusader. John. 1 Link to comment Share on other sites More sharing options...
Silver Fox Posted November 22, 2016 Share Posted November 22, 2016 Tamiyas 1/48th scale armour is a good compromise for both size and complexity. The kits are generally accurate and fun to build straight from the box. They are relatively cheap compared to 1/35 and there is a wide range from motorcycles to main battle tanks.The Airfix 1/48 Bedford MW is also a cracking kit. 1 Link to comment Share on other sites More sharing options...
