corsaircorp Posted November 11, 2016 Share Posted November 11, 2016 Hello everybody, Here's another one of my long term model. As a great fan on naval Aviation, I have been very happy to catch an exemplary of the Douglas F3D-2 Skyknight. The Korean conflict is one my big interest and a Skyknight painted in black (Before Jagger sing it) is "de rigueur" for me. Czeck Master kit, had reproduced some rarities and this is multi media kits plastic and resin and... Short run The fuselage were 2 bananas, I worked with vapor (over the kettle to tell the Truth) and I've been able to rectify this a bit. So, I'm glad but including the engines cowlings on the fuselage is far more than Rock'n Roll, Norwegian black metal in fact. Reshaping with vapor, cooling my fingers and go again. Making this time and again, that turn almost right today. At first, the fusealge were joining just in the middle and on the tailplane. So this will be a funny game from now on. Here, I bored and shaped the cannon blisters, I'll add 4 20mm gun from Aber or thing like that. The Air intake in 3 separate parts, that mean a lot of joint to cope with... Here's the interior withe Eduard Seatbelts, antenna from a F-84, since the Skyknight were working from landbases. The resin plugs in the wing require a lot of sanding too, but it's well detailled. I will include a spar through the fuselage because there is Nothing like a peg or so... So I keep carry on, but at homeopathic dosis. Thank for watching. Corsaircorp 17 Link to comment Share on other sites More sharing options...
Rob G Posted November 11, 2016 Share Posted November 11, 2016 LMAO at 'homeopathic doses'. 3 Link to comment Share on other sites More sharing options...
corsaircorp Posted November 27, 2016 Author Share Posted November 27, 2016 Hello dears, I have had a nice modelling evening, working on old faithfull piece of glass, adorned wit my USNI badge I worked on some of my projects, listening to Rammstein and Molly Hatchet and sipping a good old blue Chimay. I finished one of the half fuselage and tested it with the metal painting, no more steps, smooth karman, have a look.. Obviously, the finished one is above, below, it is after lots of sanding and a bit more to do. I also created a sun roof for the lower radar scope, I used the metal from a table candle, that look good too It is easy to bend, pretty fine and... free of charge, recycling matters One last for the road I also worked on my F4U-4, on my would be vietnamese MiG 21 F-13, my F4U-1 and some other kits. See you later. Thank for watching. Corsaircorp 6 Link to comment Share on other sites More sharing options...
corsaircorp Posted December 19, 2016 Author Share Posted December 19, 2016 Hello Dears, again some news of the big belly beast ! How to make a seamless air intake.. I use extra fluid Tamiya, I put a lot of it and press the two parts 'till there is a tiny bit of plastic spouting from the seam, and then sanding with a hand tube of sandpaper. Using silver paint is helpfull for checking the smoothness of a sanded surface. The fuselage will be closed in a few weeks, lots of sanding ahead once again. Have a very nice day. Sincerely. Corsaircorp 7 Link to comment Share on other sites More sharing options...
Martian Posted December 19, 2016 Share Posted December 19, 2016 Just been catching up on this one. A very interesting project indeed! Martian 1 Link to comment Share on other sites More sharing options...
Tailspin Turtle Posted December 19, 2016 Share Posted December 19, 2016 While you're at it, you should consider deleting those external wiring conduits running aft on the fuselage. They were only on the Raytheon test beds. See http://tailspintopics.blogspot.com/2015/04/the-f3ds-of-flying-nightmares-in-korea.html 1 Link to comment Share on other sites More sharing options...
Killingholme Posted December 19, 2016 Share Posted December 19, 2016 (edited) Looks good. I never knew Czechmaster ever made a Skynight. It looks quite like the Sword kit, but Sword managed to make a real mess of the intakes which made it the one kit I actually ever threw away half-completed! Will Edited December 19, 2016 by Killingholme 1 Link to comment Share on other sites More sharing options...
corsaircorp Posted December 19, 2016 Author Share Posted December 19, 2016 5 hours ago, Tailspin Turtle said: While you're at it, you should consider deleting those external wiring conduits running aft on the fuselage. They were only on the Raytheon test beds. See http://tailspintopics.blogspot.com/2015/04/the-f3ds-of-flying-nightmares-in-korea.html Hello TT, Thank for the tip, I'll check it and... So sand it over. Thank you very much. Corsaircorp Link to comment Share on other sites More sharing options...
corsaircorp Posted December 19, 2016 Author Share Posted December 19, 2016 2 hours ago, Killingholme said: Looks good. I never knew Czechmaster ever made a Skynight. It looks quite like the Sword kit, but Sword managed to make a real mess of the intakes which made it the one kit I actually ever threw away half-completed! Will Hello Will, I checked it with my plans at hand, this one seem right except for the windshield and acces hatch. There has been a good study in a french magazine, with some photos, can give you the references if necessary. Thank for the kind words. Corsaircorp Link to comment Share on other sites More sharing options...
corsaircorp Posted December 26, 2016 Author Share Posted December 26, 2016 Hello Dears, No Spit but Willie the whale has improved, pilot seat finished with seatbelts, Oxygen hose are ready to be painted. Starboard air intake is cemented, the trick is that you must push the whole thing forward and then cut and adjust the lip, not easy at all, but it's a short run kit I will cut the syringe needles to make my 20mm guns. Things are going well, will show some photos tomorrow I think. Beside it, I've worked on my F4U-4, mud mover big bad wulf and hawker terror of Normandy. Have a nice day. Sincerely. Corsaircorp Link to comment Share on other sites More sharing options...
corsaircorp Posted December 27, 2016 Author Share Posted December 27, 2016 Here are pic's Unless you do so, you cannot place the intake accordingly to the détails photos. Next step, I'll put some putty on the external lip, not on the Inside, that must stay open. And then cut and sand the air intake. Details are on Air Magazine n°48 and 49 plus photos found on the net. to be continued Corsaircorp 3 Link to comment Share on other sites More sharing options...
alancmlaird Posted December 27, 2016 Share Posted December 27, 2016 See! As a new member, I've been reading post like this, which, on the face of it, I have no real interest in the actual subject. But aside from being a great build so far, for me the tip of using the aluminium from the tea-light (candle) holder is a brilliant idea and is being filed away in my head for later use. I'll try not to claim it as my own! The resourcefulness of BM modellers knows no bounds. 1 Link to comment Share on other sites More sharing options...
corsaircorp Posted December 27, 2016 Author Share Posted December 27, 2016 1 hour ago, alancmlaird said: See! As a new member, I've been reading post like this, which, on the face of it, I have no real interest in the actual subject. But aside from being a great build so far, for me the tip of using the aluminium from the tea-light (candle) holder is a brilliant idea and is being filed away in my head for later use. I'll try not to claim it as my own! The resourcefulness of BM modellers knows no bounds. Thank you, you're welcome. Sincerely. Corsaircorp Link to comment Share on other sites More sharing options...
corsaircorp Posted December 30, 2016 Author Share Posted December 30, 2016 Hello Dears, Und Foilà ! Here's the intake, first some photos ... Now the intake shaped with the lip A little bit of surfacer to smooth the whole thing And I had the air probe in the air intake... Why not ?? To be continued... Thanks Sincerely Corsaircorp 5 Link to comment Share on other sites More sharing options...
corsaircorp Posted December 4, 2017 Author Share Posted December 4, 2017 Hello Dears, Just pushing my WiP up before loosin'it Sorry. CC 1 Link to comment Share on other sites More sharing options...
corsaircorp Posted April 6, 2018 Author Share Posted April 6, 2018 Howdy aaa h I got her !! It's done, lots of sanding but I got a smooth surface on both sides ! I'm in a Korean war mood thèses times .. Seemingly ! Have a pretty good week end, a sunny one !! Sincerely. CC 4 Link to comment Share on other sites More sharing options...
CJP Posted April 7, 2018 Share Posted April 7, 2018 Nothing like a challenge Corsaircorp but you are beating this one in to submission! - I always like the tubby look of the Skynight - an interesting era for naval aircraft CJP 1 Link to comment Share on other sites More sharing options...
corsaircorp Posted April 7, 2018 Author Share Posted April 7, 2018 (edited) Hello CJP, What is stuning in the history, is that the F3D with her big bellied whale appearance was a really effective night fighter ! Lots of B-29 jocks prefered to be escorted by the Marines than by the Air Farce Starfires... About the kit, there's a lot of job on it, so I will not work on her every days... Unless she can be test flied ... Fuselages were bananas !! I straight it up with hot vapor... Not so funny for my fingers.. Then the tranparencies are not right, t' will be fun to fix too... Thanks for the kind words, Have a good modelling time ! Sincerely. CC Edited April 10, 2018 by corsaircorp 2 Link to comment Share on other sites More sharing options...
corsaircorp Posted April 30, 2018 Author Share Posted April 30, 2018 Hello Dears One more Devil in the box... null So I must accomodate 4 mm for having these 2 parts fitted I will get some plastic out from the thickness of the half fuselage... That's real short run, no more choices because the U/C leg need some more lenght... Is anyone of you has a beaver ?? T'will be handy here Look we now have one of our distinguished member in the Emoji panel...nullnullnull Guess who ?? Sincerely. CC 4 Link to comment Share on other sites More sharing options...
corsaircorp Posted April 30, 2018 Author Share Posted April 30, 2018 what where are the emoji gone...null I mean this one Hope that it will stay on CC 1 Link to comment Share on other sites More sharing options...
corsaircorp Posted May 1, 2018 Author Share Posted May 1, 2018 Hello dears, No beaver offered, Okay I'll call on mine Here's EAGA BEAVA I bought that thing in Aldi years ago for a mere 30€ and I always forget that I got one.... And as I did'nt have a real bench, set it in and out is a bit boring !! So back at our whale now... Whale Beaver.... Animal thread now ! And I got this in a matter of nimutes ! And now it's quite right, let's glue the Wheel well ! I will perhaps finish this one in 2018, but I doubt .... Have a good modelling time ! Sincerely. CC 4 Link to comment Share on other sites More sharing options...
corsaircorp Posted May 22, 2018 Author Share Posted May 22, 2018 Hello dears, Still in Korea, it's a way for me to think about my Seafire... Interior is almost done now The 2 Jet intakes are done too, again lots of sanding ! One can see that buttoning the ting up will be funny, and I alread straighten the half fuselages And I also fitted a jet pipe but it will now need an optical mask, otherwise one can see through the aircraft !! The funnies of old short run kits ! I really like that pic of my daughter and me… Really serious peoples is'nt it ??? No gents, No beer, it was breakfast, sorry Fruhstûck !! Have a good modelling time, I'm off for 4 days of evening work ! Sincerely. CC 9 Link to comment Share on other sites More sharing options...
The Spadgent Posted May 30, 2018 Share Posted May 30, 2018 Great work CC. I’m going through time with you at the moment. 🐿️ not quite a beaver, squirrel? 😂 great pic of you guys over breakfast. I’ll head on to more of your builds. 😀 1 Link to comment Share on other sites More sharing options...
Azgaron Posted May 30, 2018 Share Posted May 30, 2018 Nice work CC! Håkan 1 Link to comment Share on other sites More sharing options...
corsaircorp Posted August 8, 2018 Author Share Posted August 8, 2018 Hello Dears, I was not pleased with the exhaust of my Skyknight... It's rightly placed but ... Even with the fuselage closed, one can see through ... So I did some optical mask, here it look better Painted Tyre black on the outside and glued in place, I will look for some metal tubing, 1,5mm for the blast tubes of the guns And then ???? Some work on the emergency exit, at best guess since I did'nt found any photo... And Then ??? Buttoning up the beast, may be finishing her this year ??? My Korean serie include only one Seafire 47, I need an U.S one at least... I also worked on the fuel tanks and U.C Thank for watching Dears , Take care and Happy modelling to all Sincerely. CC 4 Link to comment Share on other sites More sharing options...
