1/144 P-38F Texas Terror
ajmm
A P-38F I finished this afternoon. This is a Gashapon Japanese pre-painted kit which I stripped down, rebuilt and repainted. Very satisfying and the level of surface detail is fantastic - a beautifully-designed mould that captures the original aircraft's lines very well in my view, certainly much better than anything else in this scale.
44F4B359-2BFF-4400-99A1-C2F561DCB939_zps
The aircraft is Capt. Jack Ilfrey's P-38F Texas Terror/The Mad Dash. I used the Kitsworld decals not the F-Toys decals which provide for the same aircraft (on a sidenote - Kitsworld decals are just beautiful to use).
74552039-E52F-4C7F-83F8-50BD11D4C187_zps
Ilfrey was the first P-38 ace in WW2 and he flew this aircraft in North Africa in late-1942. He had quite an adventurous time getting to North Africa, being forced to land in Portugal after engine troubles, but managed to escape internment when demonstrating to his gun-toting Portuguese guards how to start the Lightning's engines!
95DACB0B-751C-49DE-B05D-69BDD968531E_zps
I had to do a bit of filling and sanding of some of the joints between the nacelles and the wing, as well as some on the aircraft's nose, but nothing onerous. The aircraft tail-sits despite the small piece of metal that goes in the cockpit nacelle. I scratch built the mass balances on the tail, as well as the aerial under the nose and added a pitot which seems to have pinged off sometime while I was photographing it. I used pastels and prismacolour pencils to weather it.
7C26EF6E-91D8-4E5C-AA4B-14E926362C5C_zps
FFBC227C-3733-42F2-9E17-E89B2A8A0E6B_zps
And with a teeny-tiny Stout Skycar II I finished this week as well…!
2D785EA5-5A3D-41DB-AA42-8DBC09252FF8_zps
Thanks, as ever, for looking!
Very nice indeed,.....I recently built a model of the very same aircraft in 1/72nd scale in the MTO Group Build although it took quite a bit of research on my part to arrive at the correct markings! Yours looks superb.
            Tony
            Tony
Thanks Tony! I couldn't get to the bottom of whether the skull and crossbones on the nose was white or yellow - did you suss that one out? Also various profiles had more of the spinners yellow. I just looked yours up - stunning work! I reckon my prop logos are rogue but if you promise not to tell...
Thank you everyone for your very kind comments!
I bought Ilfrey`s book `Happy Jack`s Go Buggy' to use as reference on my model and the painting of `Texas Terror/The Mad Dash' on the cover shows the skull and crossbones on the nose to be yellow, along with the kill markings. The spinner yellow also appears to be quite a small area towards the rear which you have got pretty much down to a tee considering the small scale.  There are pics inside the book which support the yellow skull and crossbones and also the spinners,....here is the painting on the cover;
Image result for happy jacks go buggy book
All the best,
                  Tony
PS- Thanks for your kind comments about my model,.....it was a bitch to build and very un Hasegawa like!
Edited by tonyot
