All the work on the cowls and nose was well worth it. It's vastly superior to the kit and it shows. The whole model is streets apart.
Brilliant job!
Dave
On 4/29/2020 at 1:14 AM, limeypilot said:
I'd be more than happy with that rigging. Attaching it to those gussets is not the easiest of tasks and you've done a great job.
Thanks Ian - though I think you're operating on another level with your multi-winged builds!
She's gorgeous, but I assume there's still a prop, or prop disc to come...
Ah, no sorry, I've elected not to include the prop blades as my mount shall be an attempt to induce a sense of speed in flight.  I looked around at various ways other clever people do this - discs, blurs - then came across someone building WWII fighters with spinners but no blades and found that most convincing.
I did have a 'great' idea in the middle of the night, and immediately in my semi-sleep state ordered some very fine clear optical fibre, thinking wouldn't that make an awesome ring out at prop-tips!!  I still have that stuff somewhere ... in the cold light of day I couldn't recall what my corresponding 'great' idea was for the link between spinner and said prop-tip ring.  I've never been able to solve that convincingly in my mind (in daylight hours!).
On 4/29/2020 at 3:06 AM, Courageous said:
Great stuff Greggles, stunning.
Thanks Stuart - I have a celebratory Malteser on standby for when it's finally mounted & done.
On 4/29/2020 at 4:44 AM, rob Lyttle said:
A couple of weeks ago I scratch built one 4-blade Hamilton prop in 1.48 scale. It's my first effort on such a job.
My sense of achievement and glow of satisfaction in achieving a result FAR exceeded anything that can be bought in the aftermarket retail sector. It's priceless.
So YOU can be feeling joy and satisfaction in abundance with this project ‼️🤩
Thanks very much Rob, & yes I do agree it is quite satisfying seeing the end result.  And it's not in some sort of self-congratulatory way, it's with full acknowledgement of the set-backs, errors, corrections & remaining embedded inaccuracies ... & yet in spite of all that it is there & done!
On 4/29/2020 at 10:05 AM, AdrianMF said:
It looks magnificent! I hope you are pleased with it.
Regards,
Adrian
Thanks Adrian, yes, not abandoning the hobby - enthusiasm maintained!
There's one vote for plastic surgery it seems 😉 Thanks for your research help &  input along the way - most appreciated.
On 4/30/2020 at 12:20 AM, DMC said:
Just beautiful! Top marks for this one.
Dennis
Thanks Dennis, here's to more such thoroughbreds for our stables!
Sooo, last time I posted I thought I was that close to having this wrapped up ...
Well here she is again, back in the jig (her natural state?!)
Mount_1
Unfortunately the clear glue I had used to bond the supporting clear acrylic to the float steps displayed an unhelpful property.  It has maintained the bond, but the cement itself has a measure of unwanted flex (subsequent deeper internet research revealed this is a known property I ought to have noticed).  While test-fitting it into the slot on top of the base I noticed a very   ....   slow   ....   disturbing  ...   lean back on it's haunches.  It met a limit, but if I merely tipped the centre of gravity forward a little then this resulted in     ...    a very   .....   slow   ...   disturbing   ...   wallow forward.   Not ideal.  So will be going back & editing that post in the preceding thread lest anyone follow my lead!
Mount_2
So it has been reinforced with the next chemical of choice: an 'ulta-clear' two part epoxy resin promising stupendous strength.  Test runs on off-cut acrylic confirmed it won't cloud or fog the transparency.  So it's been applied, & 16hrs to cure ...
In the meantime the slot has been sawn & chiselled into the top of the timber, & the graphic transplanted down into the slot.  Base is ready ...
Mount_3
... so close ...
Just found this thread. Amazing to read. I saw the kit advertised many years ago and (wisely,  goven my skill set) didn't  buy one. Hell, I'm still fighting an aerotech S6...
Interesting you say that, I was under the impression they were bespoke jewellery like items for modellers of the next level.  Keep at & would love to see some WIP shots ..
My thoughts exactly.
Good idea but considering how long the packet has been open, they may be a little soft...
As far as your first mounting failure, you're on the way your second option, hope all goes well.
Stuart
Expensive, certainly! I saved up, because I really like Schneider cup racers. This was back when there was only the 6b. There were huge problems with the kit and Aerotech kindly replaced it with a 6.
