fightersweep Posted October 20, 2016 Share Posted October 20, 2016 Hi all; As the title says (and apologies if this has been covered before), I was just wondering what I need to do to convert the Airfix Swordfish Mk I to a Mk II. I'm looking at representing the RNHF's LS326 as she was in the early 1980's if that helps. Asking here as I know very little about the Stringbag. Have to say though, the new Airfix kit is lovely! Thanks in advance! Best regards; Steve 1 Link to comment Share on other sites More sharing options...
dogsbody Posted October 20, 2016 Share Posted October 20, 2016 The only real difference that' I'm aware of is the Mk.II had a strengthened lower wing fitted with metal skinning, for the fitting of RP launch rails. Chris Link to comment Share on other sites More sharing options...
fightersweep Posted October 20, 2016 Author Share Posted October 20, 2016 Thanks Chris! I'll have to look at some plans for that one. Imagine I'll have to lose some of the ribbed detail in some areas then. Best regards; Steve Link to comment Share on other sites More sharing options...
Daniel Cox Posted October 20, 2016 Share Posted October 20, 2016 Hi Steve, There is also the ASV Radar and all of its associated black boxes that were found in the cockpit. Cheers, Daniel. Link to comment Share on other sites More sharing options...
Dave Fleming Posted October 20, 2016 Share Posted October 20, 2016 Can't recall if it was the MK II or MK III had a different shape to the rear cockpit Link to comment Share on other sites More sharing options...
Daniel Cox Posted October 20, 2016 Share Posted October 20, 2016 Hi Dave, It was the Mk III that had the additional cockpit fairing with windows that covered the receiver unit. Cheers, Daniel. Link to comment Share on other sites More sharing options...
Daniel Cox Posted October 21, 2016 Share Posted October 21, 2016 Hi again Steve, The late Edgar Brooks posted this and although it shows the earlier radar installation associated with the Mk III Swordfish, the position of the boxes within the cockpit resemble the installation found on the Mk II Swordfish. Cheers, Daniel. 1 Link to comment Share on other sites More sharing options...
detail is everything Posted October 21, 2016 Share Posted October 21, 2016 (edited) On 20/10/2016 at 9:10 PM, dogsbody said: The only real difference that' I'm aware of is the Mk.II had a strengthened lower wing fitted with metal skinning, for the fitting of RP launch rails. Chris Two features of later production Swordfish were the deepened oil cooler on the starboard side of the forward fuselage and the rather more flamboyant generator cooling pipes on top of the nose. The RNHF's MK1 appears to sport the later MK2 generator cooling pipes (although they may have been retrofitted to some MK1s). most (all?) MK2s and all MK3s also adopted the more powerful Pegasus XXX engine. Edited October 25, 2016 by detail is everything Link to comment Share on other sites More sharing options...
dogsbody Posted October 21, 2016 Share Posted October 21, 2016 The larger oil cooler goes with the fitting of the Peggy Mk.XXX engine. Chris Link to comment Share on other sites More sharing options...
Grey Beema Posted October 23, 2016 Share Posted October 23, 2016 I think the exhaust was different as well. Short straight pipe on the MKI a longer pipe on the MKII.. Link to comment Share on other sites More sharing options...
DaveCromie Posted October 24, 2016 Share Posted October 24, 2016 I know that Pavla produce a resin set that provides the enlarged oil cooler and another part (no idea what it is!) and a second set that provides the longer exhaust pipe but other than the RP plate what would I need to do to the lower wing? I can't seem to find a single decent photograph of the area in question! Cheers DC Link to comment Share on other sites More sharing options...
Seahawk Posted October 24, 2016 Share Posted October 24, 2016 (edited) ISTR Dave Fleming posted a photo of the relevant area sometime around when the Airfix kit first came out. Just no ribbing. TBH, and IIRC, it didn't look that much different. Edit: here's a more recent thread showing Tony O'Toole's mods to the Airfix wing with a photo of the real thing: Edited October 24, 2016 by Seahawk 1 Link to comment Share on other sites More sharing options...
detail is everything Posted October 25, 2016 Share Posted October 25, 2016 On 24/10/2016 at 8:35 AM, DaveCromie said: I know that Pavla produce a resin set that provides the enlarged oil cooler and another part (no idea what it is!) and a second set that provides the longer exhaust pipe but other than the RP plate what would I need to do to the lower wing? I can't seem to find a single decent photograph of the area in question! Cheers DC The other part is the rather more flamboyant generator cooling pipes I was talking about in my previous post. . If possible check photographs of the intended airframe to see generator cooling pipe arrangement as sometimes one pipe was missing. The same goes for which exhaust was used. 1 Link to comment Share on other sites More sharing options...
DaveCromie Posted October 25, 2016 Share Posted October 25, 2016 Cheers Seahawk that link looks like it shows all I need to know. Cheers Detail is Everything I have been trying to work out what they were for ages! Sage advice re checking photos too Thanks guys, the BM posse comes up trumps as usual DC Link to comment Share on other sites More sharing options...
