Mike 16,655 Posted October 15, 2016 Share Posted October 15, 2016 King Tiger Sd.Kfz.182 Henschel Turret with Zimmerit – Full Interior (2045) 1:35 Takom via Pocketbond Hitler, and therefore Nazi Germany was obsessed with bigger which they equated with better, and this was reflected in almost every aspect of arms production in the run-up to, and throughout World War II. After the Panzer IV had been matched by Allied designs, the Tiger addressed the balance back in their favour, becoming the most feared combatant from any force, despite several draw-backs of its design, such as a weak transmission, and a level of complexity that meant it was slow to manufacture, prone to break-downs and expensive to repair. Expecting the Allies to bring heavier tanks to the field before too long, the King Tiger, Tiger II, or Königstiger as the Sd.Kfz.182 was known came into existence, having begun development even before the war started. Porsche's ground-breaking and complex design was unsuccessful for this reason, while the Henschel proposal was taken forward to production, using the same underpowered Maybach engine that was barely adequate for the Tiger I, and taking on the sloped armour of the successful Panther to significantly increase the effective thickness of the armour whilst keeping weight down to a staggering 70 tonnes. The initial turrets had curved surfaces that were difficult to manufacture, and a redesign was necessary to cure this and remove the shot-trap under the mantlet, with the new design being known today as the Henschel turret, while the old design became the Porsche turret, although both were designed by Krupps. A weak transmission design, coupled with the underpowered engine ensured that many vehicles broke down in the field, and plans were in progress to improve both aspects with fuel-injection and a new drive-train, but were curtailed by the end of the war. Most of the initial order of 1,500 units were built under difficult circumstances due to bombing of the factories and the encroaching Allied forces, and despite its problems it became one of the icons of German tank design of WWII, with a number surviving to be placed in museums, with some still running. The Kit We have had a few King Tiger (KT) kits in 1:35 over the years, but nothing new for quite a while, and at times the preferred brands have been hard to come by with prices reaching silly levels on eBay. Takom's new range of KT kits aims to provide a full set of these imposing tanks, with and without Zimmerit anti-mine coating, with Henschel and Porsche turrets, and with or without interiors. This should cater for almost every possibility, and if you like your tanks buttoned up, you won't be wasting the interior if you buy wisely. If you're unfamiliar with Zimmerit, it was a paste containing sawdust that was applied at the factory beginning in December 1943 and ending in September 1944, designed to prevent magnetic mines from sticking to the sides of tanks. It was applied in a number of different patterns, but was mostly seen in short horizontal ridges as depicted on this kit. Late war production eschewed this protection to speed production and remove the danger of fire hazard, the latter turning out to be false. This is a complete new tooling from Takom, and the first to feature a full interior from the box in this scale, although more new KT kits are on the way shortly. The box shows the tank cut in half to show off the interior, on a white background, and has deep sides to accommodate the contents, although my box didn't survive shipping very well and will need a bit of repair. Inspecting the parts shows that the Zimmerit coating has been well-done, showing individual tooling marks for each indent and "crowding" of the marks around raised areas on the mantlet and rear bulkhead, meaning that someone has spent a lot of time researching and producing this aspect, rather than just copy-paste (excuse the pun) of blocks of texture onto the CAD designs. The weld seams have all been reproduced too, and the skin has been quoted as being of scale-thickness to accurately depict the interior size. This has been done by laminating parts around the hull, rather than risk sink marks on the delicate Zimmerit texture. The interior has been faithfully reproduced within the limits of injection moulding too, and really does beg you to leave open as many hatches as possible so that all the detail isn't lost to darkness. There are bound to be some modellers tempted to do a partial cut-away to expose yet more of the detail, and I'm sorely tempted myself, but will probably chicken out eventually. Inside the box are a lot of sprues, taking up almost all the available space. There are fifteen sprues, two hull parts and upper turret in a grey styrene, one sprue of clear parts, two sheets of Photo-Etch (PE) brass, two decal sheets, and three bags of tracks, with one each for the tracks and their links, plus another for spare links for the turret sides. The instruction guide is in the by-now-familiar Takom format, in landscape A4, with glossy cover and painting instructions to the rear. A separate interior painting guide is provided that works for either turret design, with labels showing which is which. Construction begins with the whe… No, the hull, actually. The lower hull is decorated with cross-members internally, the final-drive housings at the front, and along the interior sides inserts add all the extra detail as well as scale armour thickness that will be visible around the interior parts. Torsion bar bearings are added across the hull in long lines, which receive the two-part axle/torsion-bar combination later on. Various internal equipment enclosures and fuel tanks are added to floor, along with the driver's controls. Even the lower escape hatch is depicted, and has handles and locking wheel added before it is installed in the front floor. The road wheels are built into pairs and attached to the axles, with long bearings on the inner sets and short ones on the outer, so that they all line up. The driver's seat is a complex arrangement that is attached to the floor, with the final drive unit to its right, supplying the motive power to the two bell-housings and drive-sprockets. It also includes the steering column, with a quadrant style wheel on the left. The rear firewall of the crew compartment is then detailed and added at around two-thirds of the way back, creating the engine compartment with drive-shafts and transfer boxes reaching from the bulkhead to the rear of the final drive housing. The engine compartment is split longitudinally into three main compartment, with the power-pack in the central section, a radiator bath with fans on either side, and a pair of slope-sides fuel tanks using up the space over the rear wheels inside the sponsons. Each section is separated by bulkheads, which are inserted before the engine is built up from a large number of parts over a couple of pages of the instructions, with colour call-outs on the interior painting guide. Add some wiring, some grease and grime, and it should look superb. Additional hoses, panels and a final centrally mounted fuel tank are added behind the engine, all of which were interlinked to allow the driver to select where to draw the fuel from, and were even filled centrally from the rear filler cap. Parts of the hosing are included for good measure, although some is hidden from view. The two radiator housings are identical, and are topped off with a fan each, with another fuel tank outboard, as previously mentioned. A tread-plated panel with a large circular cut-out for the turret base is added to the aft of the crew compartment, along with a webbing across the forward section of the area, with ten machine-gun ammo bags attached ready for the bow gunner's use. All of the space over the sponsons is then filled with ammunition storage, which is represented by four trapezoid packs of shells in racks, which are built up from two or three layers of shells moulded to their racks, with PE percussion bases for each one. At this point all the lower hull parts are completed, with only the parts attached to the inside of the upper hull left to install, so that's where we go next. The upper hull has a separate panel including the driver and gunner's hatch, which fits into the hull along a fairly prominent panel line on the real thing. The edges of the insert are recessed and have recessed bolt-holes to allow the modeller to leave it off, or loose to show off the interior. Its underside has detail too, and a few raised ejector pin marks that are near some rivet lines, but away from much of the detail. The underside of the upper hull has some recessed ejector pin marks too, which will need filling level if you are serious about the realism of the interior, which will also behove you to remove the product code from the ceiling to the right of the insert. A selection of pioneer tools are included for attachment to the outer hull sides, and these have been supplied with little PE clasps that you bend into a U-shape to replace the kit lugs to better mimic the latches used by the Germans in WWII. These could have been done completely in PE, but would probably have alienated most purchasers, as they are notoriously tricky to complete, so this is a good compromise that promotes their use, while leaving the PE averse to use the plastic option rather than cut the lugs off. The engine deck is also separate from the upper hull, to allow for the subtle differences between production runs, whilst squeezing the maximum detail out of the area. The central armoured section has a large access panel with two mushroom vents in the centre, and this can be removed entirely (requiring a hoist for the real thing), or the inner section hinged open to reveal some of the detail of the engine. The radiator housing covers both have the circular armoured vent that is covered with a PE mesh guard, plus the two intake ducts, which are also covered over with PE mesh panels, but the right panel holds the extinguisher cartridge, while the left has the wire/bolt cutters lashed to it with another optional PE clasp. These covers hinge toward the centre, and have the hinge-notches laid out to allow them to be posed open or closed to further increase the detail on show just for the hell of it, or for diorama purposes. The array of towing cables are supplied as moulded parts with the barrel-cleaning rods moulded-in, which is perhaps a little retrograde in terms of detail, but makes the job of fitting them a lot easier, and with some sympathetic painting, they should look just as good as braided wire or cord. Flipping the upper hull over, the glacis plate is thickened to scale with an insert that has the kügelblende aperture moulded in, and the side armour is scaled by adding another insert on each side. Externally, the kügelblende's ball-mount is inserted from outside, then covered with a two-part armoured dome, which has the Zimmerit coating moulded into its surface, giving it a faceted look. The sides of the upper hull are coated entirely with Zimmerit patterning, which extends under the side skirt mounting points, which I have seen described as wrong, but after a little research, it appears that it was sometimes done at the factory, although never (or seldom) on the side skirts themselves. These were mounted by paired brackets on the hull, which are present in the moulding, in case you wanted to remove any or all the panels, and the skirts are provided as single parts from each side, with recesses in the back to accommodate the brackets without any cutting. Although moulded from styrene, the skirts have been given a very nice slender edge by chamfering the mould, the trick of which would only be exposed if you decided to remove any sections, or elected to inflict damage to the panels, as was frequently seen. If you intend the former, trimming the thickness at the breaks between panels will see you right, but the latter is probably better done using an aftermarket PE set to obtain the best scale thickness and ruggedness of the metal parts. Inside the upper hull the bow machine gun is installed with a pair of ammo bags of the kind attached to the bulkhead (and the rear of the turret ring too), and the raise/swivel mechanism for the hatch openers are also made up and inserted under the hinge-point on the deck. The front fenders attach to lugs moulded into the upper hull, and have the same chamfered edge to fool the eye into thinking they're thinner than they are. They are attached and have three small PE jointing parts locking them to the sloped edge of the side-skirt, and between them is fitted the single headlight and bracket with a styrene part portraying the wire coming from a small armoured gland on the front of the deck. Two armoured covers for the vision blocks are added to the tops of the driver's rotating periscope and the bow-gunner's fixed 'scope to finish off the upper hull. Tracks can be pretty tedious to put together, and if you ask different modellers, rubber-band, individual link, link-and-length, or full metal workable track links are the only way to travel. Speaking personally, it's only rubber-band tracks that grate on my nerves, as they merely bend around the end-of-run, and you don't get that faceted look that is present on many of the real things. In this kit you get individual links in two bags, as each track link is made from two sections that interlink. They are also handed, and only go on the sprockets one way – fact that isn't mentioned in the instructions, which also omits the number of links you'll need to make a complete run for each side. 96 of each type are included in the bags, so it's a fair bet that it's around 45 pairs per side. Gluing up the tracks into a run using liquid glue along a straight-edge and then wrapping them around the wheels and fixing them in place will usually result in a good finish, but if you want to paint them off the vehicle, it might be as well to build them in two sections so they can be removed. That's up to you of course! Each link has four very small ejector pin marks on the interior surface, which can be buffed off in seconds with a sanding stick, although you'll need a skinny one for the mark between the two guide-horns. Equally, you could just slather the tracks with some muck to hide these from view and forget all about them! With the tracks on, the upper hull is joined to the lower, and the front of the lower hull receives the big armoured plate-ends and final drive protection that incorporates the towing eye holes, with the towing shackles clipping over the holes and giving the impression of the real thing. RB Productions do a lovely set of brass shackles to upgrade the look here if you feel inclined. The rear bulkhead is detailed with the armoured access panels, the C-shaped track tools and jack-block, plus a multi-part jack that fits on long brackets at the bottom of the bulkhead. The exhausts are two parts each, and have hollow tips, but you will need to hide the seamline after gluing, which are then covered by large cast armoured shrouds with separate lifting lugs on their sides. The rear mudguards butt-fit on the bulkhead against the hinge-detail that is moulded into the panel, and the whole assembly is glued to the rear of the hull, being careful to line up the exhaust pipes with the holes in the bulkhead, which also has a couple of ejector pin marks to fill while we're there. Another pair of shackles clip over the holes in the aft of the side armour, and we finally get to the fun part. Who doesn't like a big turret? With a separate roof making removal of the (sadly necessary) ejector pin marks easier, they will be the first task, followed by mating the roof with the side shell and the front. Inside are a number of items such as the fume extractor, periscopes, extinguisher and the interior portion of the commander's cupola, plus the gunner's hatch with optional open or closed positions of the ram that controls its movement achieved by swapping parts, as per the scrap diagram. The large rear hatch was partly for escaping a doomed tank, but was also the only way of extracting the big 88mm gun without dismantling the turret. This version has the pistol port, and attaches to the rear of the turret by two large armoured covers that allow it to hinge down flat to the deck for ease of exit. On the roof the various mushroom vents, shell cartridge ejection port and lifting lugs are all glued in place along with all the track hangers on the turret sides, which fit on little pips moulded into the Zimmerit finish. The topside of the cupola is built up with the covered vision blocks and a mount for the commander's machine-gun, with the lift/rotate hatch fitting neatly in the centre, while the gunner has to slum it with his simple opening hatch as described earlier. The spare track links are bagged separately, but I can see no discernible difference between them and the tracks themselves, so I guess someone put them in as a last minute addition? With most builds, the turret would be almost finished, but with a full interior, the basket, breech and sighting gear are required, and these are built up on a circular base that fits into the bottom of the turret, with a serious amount of detail and plenty of parts making for a good looking assembly. You will need to curve a few PE panels around the inside of the turret aperture, but that's not outwith the bounds of the skills of most modellers, and leaving them off may be noticed. If you've not rolled PE before and don't have suitable tools, just fold up a piece of kitchen roll, place the PE on that and use a cylinder of some kind (pen barrel or X-Acto knife handle) to apply pressure as you roll it over the part gently. Keep testing the fit, and stop when you get there. The glue will hold the parts in place from thereon in, just remember to use Super Glue (CA). The bustle contains a pair of ready-ammo racks with 11 shells on each side of the access-way, which are supplied in the same style as the shells in the lower hull. The finished assemblies fit to panels that mate with the turret floor, and again there are PE bases to each one. The long-barrel Krupp 88mm KwK 43 L/71 was considerably longer than that mounted on the Tiger I, and could propel the shell significantly faster due to the new design, increasing its penetrating power immensely with the new Armour Piercing (AP) shells that were designed for it. Typically, the KT carried a mix of AP and High Explosive (HE), and this is accommodated on the second decal sheet, which includes the correct stencilling and painting guides. The full breech is depicted, and the part count is high, as you'd expect, with the completed assembly fitting unglued between two supports that attach to the floor of the turret to enable it to elevate once completed. With the breech fitted and the glue cured, the upper turret is slipped over the end of the breech and glued together, the circular mantlet is built up from three sections, and the one-piece barrel are both then glued to the breech, with the three-part muzzle brake added to the end of the solid barrel to give it a hollow tip. Before the turret is dropped into place on the hull, a pair of PE mesh panels are added to plastic frames and applied to the front of the engine deck. The turret is just drop-fit, so remember this when you're handling the finished model. Markings You get two options in the box, and of course the decal sheet is small – this is an armour kit afterall. Registration, colour density and sharpness are all good though, and from the box you can build one of the following: Tiger II Ausf.B, 3./s.H.Pz.Abt.503, No.301 Mailly De Camp, France, July 1944. Tiger II Henschel s.H.Pz.Abt.503, No.233 Budapest 1944. Both are painted in Dunkelgelb, Olivegrun and shokoladebraun camouflage but in different patterns, and the colour call-outs are in Mig AMMO, who also drew the profiles, with small advertisements to the sides showing the new paint sets that Takom and AMMO have collaborated on to coincide with this release. We've got a couple of sets in for review, so watch out for that in due course. The second sheet of decals contains stencils for the many shells, the driver's instruments and even the red cross for the first-aid box, all of which are small details that improve the look of any model. Conclusion This is a very nice kit of the lumbering pinnacle of German WWII armour, and there have been some nice examples of attention to detail and careful tooling of the moulds to improve or preserve detail. The full interior is well worth the additional effort, and despite my initial concerns that none of it would be seen, there are plenty of opportunities to leave various panels off that will allow you almost full access without cutting into the model. Very highly recommended. Review sample courtesy of UK Distributors for 10 Link to post Share on other sites
Sgt.Squarehead 7,615 Posted October 15, 2016 Share Posted October 15, 2016 This kit (or one of their other KTs) could well become my fifth 1/35 purchase. Link to post Share on other sites
Tim T 262 Posted October 15, 2016 Share Posted October 15, 2016 That does look utterly lovely. The problem I have is that Meng are also releasing the KT and it will also be a state of the art kit. I suspect it will be down to price and availability at the end of the day and how much interior detail you want / need. We're spoilt aren't we? Link to post Share on other sites
Billydick 622 Posted October 16, 2016 Share Posted October 16, 2016 Really good and comprehensive review Mike. Thanks. BillyD Link to post Share on other sites
TonyG 75 Posted October 22, 2016 Share Posted October 22, 2016 I picked up one of the 'Porsche'-turreted versions at the Southwell show recently. I'm looking forward to building it (maybe it'll be a Christmas project). I'm also thinking of getting a second one to do as a cutaway version. Link to post Share on other sites
593jones 1,147 Posted October 25, 2016 Share Posted October 25, 2016 This kit looks a beauty, they have some in my LMS and I'm sorely tempted to spend some of my upcoming redundancy money on at least one. It can be my retirement project Link to post Share on other sites
Bozothenutter 260 Posted December 21, 2017 Share Posted December 21, 2017 anybody have this and using Am tracks? the kit tracks seem a bit shallow. other reccomendations on am?, the voyager stuff seems nice? Link to post Share on other sites
Whitewolf 148 Posted July 30, 2019 Share Posted July 30, 2019 Looks very impressive, especially with the beautifully moulded Zimmerit. This is going on the Shopping list! Link to post Share on other sites
