Sign in to follow this
richellis
AMT Volkswagen Scirocco Mk1 (1977 model)
Volkswagen Scirocco
1:25 kit from AMT
Some of you may know but I’m a VW fan, having owned many different Vee-Dubs over the years, and still have a Mk1 Golf GTi in the garage for summer fun, and in my time 2 Sciroccos have passed through my hands. The Scirocco was a replacement for the Karmann Ghia coupe and was launched 6 months before the Golf so any teething problems could be sorted before the Golf hit the roads. Although it is biased on the Golfs platform (chassis) it was modified extensively to give a sportier ride, with its front mounted engines, with front wheel drive and sleek coupe body penned by  Giorgetto Giugiaro. When I saw the re-issue of the old AMT Scirocco I was very excited, I’ve a stash of VW kits ready to build scale replicas of some of my favourite cars from my past so I could now add one of my ‘Roccos’ to the fleet!
The AMT kit comes in the normal AMT style box with a lift off lid, and a box full of plastic. Most is moulded in a light grey plastic, with a clear single piece glazing part, and a chrome sprue, with all sprues being bagged individually. The body comes as a single part with the lower front and rear valances to be added and a separate bonnet.
The body is a nice casting and it looks in proportion and the lines look good to my eye. The kit is an early Mk1, with US specification side markers, if you are building a European model these will need sanding off the shell and won’t be too hard to do. The car has the single wiper moulded on the shell and this helps date the car to a 1977 model to convert to an earlier version this can be sanded off and twin wipers added.
Construction starts with the engine, slipping my VW anorak on, it looks like the 1.6l petrol engine with the 4 speed manual gearbox. The shape of the engine looks good and the parts are well detailed, a quick look online will bring up lots of pictures to help you add detail should you wish to show off the engine on your model. This kit can be built as either a stock ‘road’ car or as a race car with wide wheels, stripped interior roll cage and body kit. The instructions now split the road and race builds and your spares box will benefit from some left over parts. The car only has a left hand drive dashboard so for a British car some cutting and modification will be required here. The parts for the interior are well detailed with the door cards and rear interior being well done, and the interior tub has ‘rough’ casting to represent the carpets, and the seats are textured to mimic the stitching and pattern on the fabric. For the race car a multi-part roll cage needs making up and a deep race bucket seat is needed omitting the rear and passenger seat.
Construction then moves onto the chassis, this is a single part and the underside has all the complex pressings and mouldings found on the 1:1, there is some flash present on the review sample that will need some work around the edges. Again there is optional parts between the race and road here, the race car has a straight through exhaust, exiting at the side, with a more conventional rear exit with silencer exhaust for the road.
Construction now starts on the body, under the bonnet the firewall and internal wings are built up, I would glue this into the body before painting, along with the front and rear valances I would also glue the bonnet in place if you want the model closed. This is where the body kit is added if wanted, with 4 wide wheel arch extensions and a big front valance with air dam and spoiler.
Finishing off your build are the wheels, some nice VW standard alloys or a big wide set of BBS race wheels topped off with some nice rubber tyres, there are 8 in the box 4 narrow ‘road’ tyres and 4 wide tyres, they all have nice side wall and tread detail.
A single decal sheet has the stripes, race numbers sponsor logos and VW badges for the race car along with some ‘Scirocco’ dealer plates all nicely printed and sharply done.
Conclusion.
It’s great to see this kit back, it will fill a hole in my collection. With the crisp lines of the Scirocco captured and the option of road or race versions should make it more popular.
Bad points, other than no right hand drive dashboard nothing!
Review sample courtesy of
